  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 214.4k Views 36 Watching
  • mfalkviddM
    Ah yes, the guide became invalid yesterday when a PR was merged. I'll update the guide, thanks for noticing.
    Information about how to get the rf library is available in the readme in the Raspberry folder if you want to get going.
      msantang
      wrote on last edited by msantang
      #31
      I got it working on my rb2 but i got 100% of cpu ussage.
      I read a lot of post about this but i cant found a solution.
      Some one know how to fix this?
      OitzuO 1 Reply Last reply
      • J jpbabou
        Hi
        something is missing..
        Is there a problem with the repository
        Tks a lot for your job!
        pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
        Cloning into 'Raspberry'...
        remote: Counting objects: 273, done.
        remote: Compressing objects: 100% (3/3), done.
        remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
        Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
        Resolving deltas: 100% (114/114), done.
        Checking connectivity... done.
        pi@domoticjp ~ $ cd Raspberry/librf24-bcm
        -bash: cd: Raspberry/librf24-bcm: No such file or directory
        alexsh1A
        alexsh1A
        alexsh1
        @jpbabou said:
        Hi
        Please go ahead and install the rf24 library from https://github.com/TMRh20/RF24
        The rest should be the same
        • M msantang
          OitzuO
          OitzuO
          Oitzu
          wrote on last edited by Oitzu
          #33
          The 100% cpu usage is probably due to the style of receiving new messages from rf24/serial port.
          The current state is that the PiSerialGateway tries to poll data in a endless loop from rf24/serial.
          This could maybe fixed with using the interrupt of the nrf24l01+ to signal new data and reading data from the serial in blocking mode.
          I want to solve this but using interrupts on the RPi isn't that trivial.
          • mfalkviddM
            http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/2 has information on how to use interrupts. I haven't tried it myself though.
              OitzuO
              OitzuO
              Oitzu
              Oh yeah, thanks for the hint @Bens got the exact same problem and seem to solved the rf24 part already. I hope he gets back online and shares his results. :)
              • D
                den2k
                Hi all,
                I'm following this thread and have upgraded to MySensors v1.5 and get the following error. Version mismatch.
                It looks like the Protocol version is 1.4.
                Does the Raspberry MySensors Gateway support v1.5 or only v1.4? Any ideas on how to fix?
                upload-27647566-60ff-4341-97aa-4d1186e5e670
                alexsh1A 1 Reply Last reply
                • D den2k
                  Hi all,
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @den2k said:
                  Hi all,
                  Up until now, MySensors v1.4 only for nrf24l01+ direct connection.
                  Did you upgrade the GW or the sensors or both ?
                  D 1 Reply Last reply
                    Protocol version hasn't changed since 1.4
                    https://github.com/mysensors/Raspberry/blob/master/MyMessage.h#L41
                    So you must have some other problem.. As you can see you only get zeroes in the log...
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      #39
                      You can "fake" a later version (e.g, 1.5) on the Raspberry by changing the version code in the version.h file and recompiling the Gateway software.
                      As far as I understand, the gateway will still pass the messages to the controller, even is there is a version mismatch message on the console.
                      • alexsh1A alexsh1
                        @den2k said:
                        Hi all,
                        den2k
                        @alexsh1 I know the sensors are on v1.5. As for the Raspberry Gateway, it looks like based on the info here, that is running v1.4.
                          den2k
                          @hek I'm running a custom 1Mhz build bootloader on a Pro Mini for the Sensor side. This was paired with the standard Serial Gateway running on another Pro Mini with v1.5 on both gateway and sensor. That setup was working. But I moved over to using the Pi gatway+nRF24+ radio and have this issue. I don't believe the hookup is the problem. I've seen the 0 readings before, and that usually meant node side issue or uninitiated Gateway. I have not changed the Node, so it must be the Pi gateway that is the problem. Any thoughts on what to test?
                          • D
                            den2k
                            Noob question. Any one have an idea on solving the "Permission denied" error.
                            upload-a7ed9c85-5b6b-4198-af00-909e1861374e
                            • D
                              den2k
                              Solved my own problem. Using the following command did the trick.
                              sudo chown -h pi:pi ttyUSB20
                              • D
                                den2k
                                weird. Permission Denied problem again.
                                What is the USER : GROUP that is needed for this to work?
                                • mfalkviddM
                                  @den2k I think your best chance is to post in the Home Assistant category. I don't have any experience with Home Assistant unfortunately.
                                  • J jpbabou
                                    Hi
                                    @jpbabou said:
                                    Hi
                                    The guide has been updated to reflect the updated in the MySensors Raspberry repository now. Thanks @jpbabou !
                                    • D den2k
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      #47
                                      @den2k
                                      Hi!
                                      Have you added the user that runs homeassistant to the dialout group? This group is usually owner of serial ports.
                                      Check default group of serial port (change for your port below) after connecting it:
                                      pi@martin-pi:~ $ ls -l /dev/ttyUSB0
                                      crw-rw---- 1 root dialout 188, 0 dec 18 03:21 /dev/ttyUSB0
                                      Check groups that user pi is in:
                                      pi@martin-pi:~ $ groups pi
                                      pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
                                      If pi runs homeassistant, which should be the case, and is not in dialout, add pi to dialout:
                                      sudo adduser pi dialout
                                      Changing owner of a port will only work until you disconnect it. Default owner will be restored upon reconnect, if you haven't written a special udev rule.
                                      Edit:
                                      According to the readme in the mysensors raspberry repo (https://github.com/mysensors/Raspberry), the group of the device is tty. So you should probably use that, and not dialout. But you will know, when you check with ls -l.
                                        Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                                        I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                                        Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                                        This is the first draft. Any feedback is welcome.
                                        INTRODUCTION
                                        The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                                        Wiring Things Up
                                        Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                                        Raspberry Pi NRF24L01+ Color
                                        6 / GND GND Black
                                        1 / 3.3V DC VCC Red
                                        22 / GPIO25 CE Orange
                                        24 / GPIO 8 CSN/CS Yellow
                                        23 / GPIO11 / SPI_CLK SCK Green
                                        19 / GPIO10 / SPI_MOSI MOSI Blue
                                        21 / GPIO9 / SPI_MISO MISO Violet
                                        The IRQ pin on NRF24L01 is not currently used.
                                        For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                                        You should also connect a decoupling capacitor to the radio. See this guide.
                                        COMPILING THE GATEWAY
                                        Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                                        git clone https://github.com/TMRh20/RF24.git
                                        cd RF24
                                        make all && sudo make install
                                        cd ..
                                        cd Raspberry
                                        If you get the following error:
                                        pi@raspberrypi ~/RF24 $ make all && sudo make install
                                        g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                                        gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                                        bcm2835.c: In function ‘bcm2835_init’:
                                        bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                                        You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                                        #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                                        IOBASE := 3F000000
                                        VERIFY THE GATEWAY
                                        Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                                        pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                                        Starting PiGatewaySerial...
                                        Protocol version - 1.4
                                        Created PTY '/dev/pts/1'
                                        Gateway tty: /dev/ttyMySensorsGateway
                                        ================ SPI Configuration ================
                                        CSN Pin          = CE0 (PI Hardware Driven)
                                        CE Pin           = Custom GPIO25
                                        Clock Speed      = 8 Mhz
                                        ================ NRF Configuration ================
                                        STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                        RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                        RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                                        TX_ADDR          = 0xe7e7e7e7e7
                                        RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                                        EN_AA            = 0x3b
                                        EN_RXADDR        = 0x07
                                        RF_CH            = 0x4c
                                        RF_SETUP         = 0x23
                                        CONFIG           = 0x0e
                                        DYNPD/FEATURE    = 0x3f 0x06
                                        Data Rate        = 250KBPS
                                        Model            = nRF24L01+
                                        CRC Length       = 16 bits
                                        PA Power         = PA_LOW
                                        If the NRF24L01+ isn't correctly wired, the following error will be shown
                                        pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                                        Created PTY '/dev/pts/2'
                                        check wires
                                        If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                                        sudo killall PiGatewaySerial
                                        to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                                        If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                                        sudo /etc/init.d/PiGatewaySerial start
                                        to start the gateway as a background process. Verify that it started correctly by running
                                        sudo cat /dev/ttyMySensorsGateway
                                        You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                                        MAKE THE GATEWAY AUTOSTART
                                        To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                                        sudo make enable-gwserial
                                        Enable the gateway for use with Domoticz
                                        Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                                        sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                        And change /etc/rc.local from this
                                        exit 0
                                        to this
                                        exit 0
                                        OTHER NOTES
                                        • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                                        • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                                        • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                                        As always, I stand on the shoulders of giants. Related posts:
                                        • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                                        • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                                        TROUBLESHOOTING
                                        If you get this error
                                        pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                                        [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                                         failed!
                                        or this error
                                        sudo: /usr/local/sbin/PiGatewaySerial: command not found
                                        you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                                        Scala
                                        @mfalkvidd Hi there and thanks for a great and super detailed step-by-step tutorial.
                                        I've got mine running in no time with your instructions, but after a couple of minutes I've got the following error:
                                        2015-12-30 20:51:30.356 Error: MySensors: Unhandled sensor (sub-type=32), please report with log!
                                        2015-12-30 20:52:01.390 Error: Serial Port closed!... Error: End of file
                                        2015-12-30 20:52:02.315 MySensors: retrying in 30 seconds...
                                        2015-12-30 20:52:31.319 MySensors: Using serial port: /dev/ttyUSB20
                                        2015-12-30 20:52:31.320 Error: MySensors: Error opening serial port!
                                        2015-12-30 20:52:32.321 MySensors: retrying in 30 seconds...
                                        2015-12-30 20:53:01.324 MySensors: Using serial port: /dev/ttyUSB20
                                        I also attached a partial screen capture showing that it was working before 8-)
                                        Any idea on why is this happening and how to solve it?
                                        Southern regards and happy new year to all!
                                        ronnyandreR 1 Reply Last reply
                                        • mfalkviddM
                                          You are using a sensor type that your version of Domoticz doesn't support. What type os sensor is it? Which version of Domoticz are you using? Upgrading Domoticz might solve the problem (if the newer version supports this sub-type).
                                          12.5k
