  3. Best IDE to use for MySensors projects
atmel studioeclipsedebugvisualmicroide
48 Posts 16 Posters 27.7k Views 18 Watching
    smilvert
    wrote on last edited by smilvert
    Interesting discussion!
    Has just started to try to create some nodes, but find it difficult to put up a decent environment.
    When I test platformio who want to have the following structure:
    MyNode
    ├── lib
    │ ├── DHT -> /my_arduino_libs/DHT
    │ └── MySensor -> /my_arduino_libs/MySensor
    ├── platformio.ini (config file That specifies the platform and settings)
    └── src
        └── MyNode.ino
    Platformio makes it very easy to build on different platforms, but from version 1.6 of mysensors works platformio bad. It can be solved with a lot of #ifdef but is not easy.
    Also tested with (Have steal it from the jenkins-server :) )
    Arduino --verify -v --board Arduino: AVR pro --pref build.f_cpu = 8000000 --pref build.mcu = ATMEGA328P --pref compiler.warning_level = all --pref sketchbook.path = libraries/mysensors MyNode/MyNode.ino
    but then it becomes very inflexible. (Has built a small bashscript for this)
    How do you others to keep track of your code and to build in a smooth way with a nice IDE?
    • TD22057T TD22057
      I spent part of this afternoon trying sublime text + platformio. What a pain in the a$$. The problem with all these "auto" systems is that when they break, they don't tell you enough to figure out how to fix it. I can't get platformio to include a custom include path and it's not obvious how it's managing build directories so I can't even get it to find include files that seem like they should be visible.
      I guess I'm going to try stino, Arduino-Makefile, or Arduino-cmake with sublimetext next.
      I
      I
      ivankravets
      @TD22057 thanks a lot for your feedback. If you have any problems with software (including open-source), don't forget to report them to developers.
      I'm a founder of PlatformIO and will try to answer on the all questions.
      See documentation for it http://docs.platformio.org/en/latest/projectconf.html#build-flags
      The default behaviour of PlatformIO's builder is to build all *.c, *.cpp, *.S files. If this behaviour isn't good for your project, then you can control it via http://docs.platformio.org/en/latest/projectconf.html#src-filter
      I understand that developers like to "adopt" own source code (libraries) for the specified builder and then claim other builders that they What a pain in the a$. If someone like car which works using petrol, then it doesn't mean that people who use diesel cars are What a pain in the a$.
      I've just added to PlatformIO FAQ the answer for question Can not compile a library that compiles without issue with Arduino IDE.
      P.S: Friends, we spent our spare time to improve this embedded world. Our users don't understand that we do it totally FOR FREE and share all efforts via OPEN-SOURCE. Let's respect each other.
      Regards, Ivan Kravets
      • Ph.D, Researcher and Software Architect
      • "Creativity comes from talent and never from knowledge" (c)
      http://www.ikravets.com
      Regards Ivan,
      The PlatformIO Team
        smilvert
        @ivankravets Thanks a lot!! :)
        Now I think that it works with the latest commit on github->dev-branch.
        I will try it to night and if I got time I will publish my node code/building structure as well.
        Here was my platformio.ini file that I tested with:
        [env:pro8MHzatmega328]
        platform = atmelavr
        framework = arduino
        board = pro8MHzatmega328
        build_flags = -I/(PATH_TO_MYSENSORS_GITHUB)/libraries/MySensors
        lib_ignore = MySensors
        YveauxY I 3 Replies Last reply
        • S smilvert
          platform = atmelavr
          framework = arduino
          @smilvert I'd be very interested in a short howto, once you succeed!
            smilvert
            @Yveaux I just uploaded the first version on github but currently I lacks sensors so I haven't verify the build_script but it seams to work in the console.
            (I should also add a howto when I get time :) )
            • S smilvert
              platform = atmelavr
              framework = arduino
              I
              I
              ivankravets
              @smilvert we have an issue Handle specific extra build flags from library.json which should resolve your problems. In this case, you will need to skip *.cpp/*.c files from building process using library.json.
              Regards Ivan,
              The PlatformIO Team
              • S smilvert
                platform = atmelavr
                framework = arduino
                I
                I
                ivankravets
                wrote on last edited by ivankravets
                Related issue https://github.com/platformio/platformio/issues/331
                @smilvert I've just re--tested without lib_ignore option and it works! Please don't place MySensors library to the lib directory.
                platformio.ini
                [env:uno]
                platform = atmelavr
                framework = arduino
                board = uno
                src_build_flags = -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors
                Project
                ➜  /  tree /tmp/111
                /tmp/111
                ├── lib
                │   └── readme.txt
                ├── platformio.ini
                └── src
                    └── GatewaySerial.ino
                2 directories, 3 files
                Terminal
                (develop)➜  origin git:(develop) ✗ platformio run -d /tmp/111
                [Fri Nov 27 19:38:03 2015] Processing uno (src_build_flags: -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors, platform: atmelavr, board: uno, framework: arduino)
                avr-g++ -o .pioenvs/uno/src/tmp_ino_to.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -DPLATFORMIO=020306 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -I.pioenvs/uno/SPI -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors src/tmp_ino_to.cpp
                avr-ar rcs .pioenvs/uno/libFrameworkArduinoVariant.a
                avr-ranlib .pioenvs/uno/libFrameworkArduinoVariant.a
                avr-g++ -o .pioenvs/uno/FrameworkArduino/CDC.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/CDC.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial0.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial0.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial1.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial1.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial2.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial2.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial3.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial3.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/IPAddress.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/IPAddress.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/PluggableUSB.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/PluggableUSB.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/Print.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Print.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/Stream.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Stream.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/Tone.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Tone.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/USBCore.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/USBCore.cpp
                avr-gcc -o .pioenvs/uno/FrameworkArduino/WInterrupts.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WInterrupts.c
                avr-g++ -o .pioenvs/uno/FrameworkArduino/WMath.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WMath.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/WString.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WString.cpp
                avr-gcc -x assembler-with-cpp -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -c -o .pioenvs/uno/FrameworkArduino/_wiring_pulse.o .pioenvs/uno/FrameworkArduino/_wiring_pulse.S
                avr-g++ -o .pioenvs/uno/FrameworkArduino/abi.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/abi.cpp
                avr-gcc -o .pioenvs/uno/FrameworkArduino/hooks.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/hooks.c
                avr-g++ -o .pioenvs/uno/FrameworkArduino/main.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/main.cpp
                avr-g++ -o .pioenvs/uno/FrameworkArduino/new.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/new.cpp
                avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring.c
                avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_analog.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_analog.c
                avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_digital.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_digital.c
                avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_pulse.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_pulse.c
                avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_shift.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_shift.c
                avr-ar rcs .pioenvs/uno/libFrameworkArduino.a .pioenvs/uno/FrameworkArduino/CDC.o .pioenvs/uno/FrameworkArduino/HardwareSerial.o .pioenvs/uno/FrameworkArduino/HardwareSerial0.o .pioenvs/uno/FrameworkArduino/HardwareSerial1.o .pioenvs/uno/FrameworkArduino/HardwareSerial2.o .pioenvs/uno/FrameworkArduino/HardwareSerial3.o .pioenvs/uno/FrameworkArduino/IPAddress.o .pioenvs/uno/FrameworkArduino/PluggableUSB.o .pioenvs/uno/FrameworkArduino/Print.o .pioenvs/uno/FrameworkArduino/Stream.o .pioenvs/uno/FrameworkArduino/Tone.o .pioenvs/uno/FrameworkArduino/USBCore.o .pioenvs/uno/FrameworkArduino/WInterrupts.o .pioenvs/uno/FrameworkArduino/WMath.o .pioenvs/uno/FrameworkArduino/WString.o .pioenvs/uno/FrameworkArduino/_wiring_pulse.o .pioenvs/uno/FrameworkArduino/abi.o .pioenvs/uno/FrameworkArduino/hooks.o .pioenvs/uno/FrameworkArduino/main.o .pioenvs/uno/FrameworkArduino/new.o .pioenvs/uno/FrameworkArduino/wiring.o .pioenvs/uno/FrameworkArduino/wiring_analog.o .pioenvs/uno/FrameworkArduino/wiring_digital.o .pioenvs/uno/FrameworkArduino/wiring_pulse.o .pioenvs/uno/FrameworkArduino/wiring_shift.o
                avr-ranlib .pioenvs/uno/libFrameworkArduino.a
                avr-g++ -o .pioenvs/uno/SPI/SPI.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -I.pioenvs/uno/SPI .pioenvs/uno/SPI/SPI.cpp
                avr-ar rcs .pioenvs/uno/libSPI.a .pioenvs/uno/SPI/SPI.o
                avr-ranlib .pioenvs/uno/libSPI.a
                avr-g++ -o .pioenvs/uno/firmware.elf -Os -mmcu=atmega328p -Wl,--gc-sections,--relax .pioenvs/uno/src/tmp_ino_to.o -L.pioenvs/uno -Wl,--start-group -lm .pioenvs/uno/libFrameworkArduinoVariant.a .pioenvs/uno/libFrameworkArduino.a .pioenvs/uno/libSPI.a -Wl,--end-group
                avr-objcopy -O ihex -R .eeprom .pioenvs/uno/firmware.elf .pioenvs/uno/firmware.hex
                "avr-size" --mcu=atmega328p -C -d .pioenvs/uno/firmware.elf
                AVR Memory Usage
                Device: atmega328p
                Program:   13988 bytes (42.7% Full)
                (.text + .data + .bootloader)
                Data:        697 bytes (34.0% Full)
                (.data + .bss + .noinit)
                Regards Ivan,
                The PlatformIO Team
                • lrtsenarL
                  lrtsenarL
                  lrtsenar
                  I use Source Insight. Sure it's not free but it's a full featured tools never equaled (like Visual Assist plug in for Visual Studio).
                  • barduinoB
                    barduinoB
                    barduino
                    HI
                    I've been trying vs code
                    It has GIT integration, Arduino file format and some auto complete.
                    It is also capable of verifying and uploading the sketch
                    • axillentA
                      axillentA
                      axillent
                      atmel added arduino support to their latest atmel studio v7
                      not tested yet, but it should be also an option
                      sense and drive
                      • marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        I've (very) recently moved from Eclipse to IntelliJ for my Java and PyCharm for my Python development.
                        I am really happy and have a subscription for the whole IDE ecosystem from JetBrains.
                        With that comes CLion which also has an Arduino Plugin.
                        I have not tried using it yet but it looks good.
                        And CLion also works with PlatformIO (http://docs.platformio.org/en/latest/ide/clion.html)
                        Fulltime Servoy Developer
                        • Daniel OliveiraD
                          Daniel OliveiraD
                          Daniel Oliveira
                          @smilvert I would like to know if you succeed using PlatformIO.
                          Thank you
                          MySensors rules my home :)
                          I 1 Reply Last reply
                            MySensors is on plaformio, so I guess it should work.
                            http://platformio.org/lib/show/548/MySensors
                            • Daniel OliveiraD Daniel Oliveira
                              Thank you
                              I
                              I
                              ivankravets
                              #24
                              @Daniel-Oliveira We have some problems with previous PlatformIO 2.0 Build System and MySensor Library structure. All these issues are resolved in PlatformIO 3.0 where are introduced new build system and library manager with support for 3-rd party manifests (Arduino's library.properties, ARM mbed module.json).
                              PlatformIO 3.0 has not been finally released. We released the first public alpha version. How to use it?
                              1. Install PlatformIO IDE or PlatformIO CLI and switch it to development version.
                              2. Menu: PlatformIO > Initialize new project
                              3. Open platformio.ini project configuration files (will be created in the project)
                              4. Specify project dependencies. See docs for lib_deps option.
                              5. Press build/upload button.
                              For example, the final project configuration file for the Arduino Uno will look like:
                              [env:uno]
                              platform = atmelavr
                              framework = arduino
                              board = uno
                              lib_deps = MySensors
                              You can also specify Semantic Versioning rules and depend on the specific version or range of versions. For example, lib_deps = MySensors@~2.0.1-beta means that any version of 2.0.x (including beta and higher) is allowed for your project.
                              Regards Ivan,
                              The PlatformIO Team
                              tbowmoT 1 Reply Last reply
                                @ivankravets
                                You've done a great job on plaformio :thumbsup: , finally a decent library manager with dependency handling.
                                • I ivankravets
                                  [env:uno]
                                  platform = atmelavr
                                  framework = arduino
                                  board = uno
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @ivankravets
                                  Great work.. One question, is it possible to install your own hardware profiles? For example for the Sensebender Micro, or the new Gateway device I'm working on?
                                    @ivankravets
                                    I
                                    I
                                    ivankravets
                                    @hek thanks a lot for the feedback :+1:
                                    Regards Ivan,
                                    The PlatformIO Team
                                    • tbowmoT tbowmo
                                      @ivankravets
                                      I
                                      I
                                      ivankravets
                                      #28
                                      @tbowmo Sure, it is possible in PlatformIO 2.0 too. However, we don't recommend to make integration with it. PlatformIO 2.0 has not been changed since 2014 year. It was as hobby/experimental project.
                                      PlatformIO 3.0 is a new PlatformIO where all hardware related parts were moved to separated repositories. PlatformIO 3.0 is closer to open source. You don't need to contact with The PlatformIO Team (as you need to do it with PlatformIO 2.0) because you can create own development platform, clone existing or just add an own board to the existing development platform. Feel free to make PR and we will merge it.
                                      We will create "Development Platforms Registry" later. It will 3-rd party developers to register own development platforms and hardware in the public registry.
                                      The core idea of PlatformIO 3.0 is to provide professional cross-platform build system without dependencies with powerful library manager. It will allow others developers/companies to create awesome software basing on PlatformIO Tools.
                                      P.S: Here is docs (beta) how to create development platform or integrate custom embedded board: http://docs.platformio.org/en/latest/platforms/custom_platform_and_board.html
                                      Regards Ivan,
                                      The PlatformIO Team
                                        stedew
                                        Hello Mr Kravets,
                                        Can you give a hint/short explanation why Mysensors 2.0 Compiles ok in the upgraded version (the development branch). I can understand its maybe one off your internal secrets but i think that it can be benificial for others. I love a lot one off the "concurrent" IDE (Arduino Eclipse) and the (for my case) Problem is that it doesn't compile Mysensors 2.0. I assume with my limited knowledge and observations off the compiler errors the problems there are related..
                                        -I Also tested the build and it took severall attempt to get it compiling. Unfotunatly i cannot reproduce it (Windows usr ;-) ) I had to fiddle severall times in the PATH var and settings and restart the IDE ....
                                        Anyway I hope that Arduino ide sees one day the Light and gets some inspiration on a project like this or even better start co-operating....
                                        Good work !!!
                                        • S stedew
                                          Hello Mr Kravets,
                                          Good work !!!
                                          I
                                          I
                                          ivankravets
                                          This is not a secret. PlatformIO 2.0 doesn't support 3-rd party library manifests. These different manifests are suitable for the own builders. For example, Arduino IDE builder has own behaviour. If library doesn't contain src folder, then it will build only source files from the root of library (other folders are ignored). If src directory exists, then only the source code from src should be built. The another story is with ARM mbed compiler.
                                          PlatformIO 3.0 is an unique cross-platform ecosystem that replaces all builders above and allows you to build different project in the same manner. We wrote different extensions for PlatformIO 3.0 Build System that allow handling 3-rd party manifests and "configure" build system on-the-fly. What is more, we don't depend on Arduino IDE, Java or ARM mbed yotta. PlatformIO is written in pure Python and doesn't depend on OS software. The only 1 requirement is Python interpreter (that is installed everywhere except Windows).
                                          Could you explain in details? Thanks.
                                          Regards Ivan,
                                          The PlatformIO Team
