  3. Best IDE to use for MySensors projects
atmel studioeclipsedebugvisualmicroide
48 Posts 16 Posters 27.7k Views 18 Watching
    smilvert
    @Yveaux I just uploaded the first version on github but currently I lacks sensors so I haven't verify the build_script but it seams to work in the console.
    (I should also add a howto when I get time :) )
    • S smilvert
      @ivankravets Thanks a lot!! :)
      Now I think that it works with the latest commit on github->dev-branch.
      I will try it to night and if I got time I will publish my node code/building structure as well.
      Here was my platformio.ini file that I tested with:
      [env:pro8MHzatmega328]
      platform = atmelavr
      framework = arduino
      board = pro8MHzatmega328
      build_flags = -I/(PATH_TO_MYSENSORS_GITHUB)/libraries/MySensors
      lib_ignore = MySensors
      I
      I
      ivankravets
      @smilvert we have an issue Handle specific extra build flags from library.json which should resolve your problems. In this case, you will need to skip *.cpp/*.c files from building process using library.json.
      Regards Ivan,
      The PlatformIO Team
      • S smilvert
        platform = atmelavr
        framework = arduino
        I
        I
        ivankravets
        wrote on last edited by ivankravets
        Related issue https://github.com/platformio/platformio/issues/331
        @smilvert I've just re--tested without lib_ignore option and it works! Please don't place MySensors library to the lib directory.
        platformio.ini
        [env:uno]
        platform = atmelavr
        framework = arduino
        board = uno
        src_build_flags = -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors
        Project
        ➜  /  tree /tmp/111
        /tmp/111
        ├── lib
        │   └── readme.txt
        ├── platformio.ini
        └── src
            └── GatewaySerial.ino
        2 directories, 3 files
        Terminal
        (develop)➜  origin git:(develop) ✗ platformio run -d /tmp/111
        [Fri Nov 27 19:38:03 2015] Processing uno (src_build_flags: -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors, platform: atmelavr, board: uno, framework: arduino)
        avr-g++ -o .pioenvs/uno/src/tmp_ino_to.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -DPLATFORMIO=020306 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -I.pioenvs/uno/SPI -I/Users/ikravets/Downloads/Arduino-development/libraries/MySensors src/tmp_ino_to.cpp
        avr-ar rcs .pioenvs/uno/libFrameworkArduinoVariant.a
        avr-ranlib .pioenvs/uno/libFrameworkArduinoVariant.a
        avr-g++ -o .pioenvs/uno/FrameworkArduino/CDC.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/CDC.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial0.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial0.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial1.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial1.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial2.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial2.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/HardwareSerial3.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/HardwareSerial3.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/IPAddress.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/IPAddress.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/PluggableUSB.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/PluggableUSB.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/Print.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Print.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/Stream.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Stream.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/Tone.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/Tone.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/USBCore.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/USBCore.cpp
        avr-gcc -o .pioenvs/uno/FrameworkArduino/WInterrupts.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WInterrupts.c
        avr-g++ -o .pioenvs/uno/FrameworkArduino/WMath.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WMath.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/WString.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/WString.cpp
        avr-gcc -x assembler-with-cpp -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -c -o .pioenvs/uno/FrameworkArduino/_wiring_pulse.o .pioenvs/uno/FrameworkArduino/_wiring_pulse.S
        avr-g++ -o .pioenvs/uno/FrameworkArduino/abi.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/abi.cpp
        avr-gcc -o .pioenvs/uno/FrameworkArduino/hooks.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/hooks.c
        avr-g++ -o .pioenvs/uno/FrameworkArduino/main.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/main.cpp
        avr-g++ -o .pioenvs/uno/FrameworkArduino/new.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/new.cpp
        avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring.c
        avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_analog.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_analog.c
        avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_digital.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_digital.c
        avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_pulse.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_pulse.c
        avr-gcc -o .pioenvs/uno/FrameworkArduino/wiring_shift.o -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant .pioenvs/uno/FrameworkArduino/wiring_shift.c
        avr-ar rcs .pioenvs/uno/libFrameworkArduino.a .pioenvs/uno/FrameworkArduino/CDC.o .pioenvs/uno/FrameworkArduino/HardwareSerial.o .pioenvs/uno/FrameworkArduino/HardwareSerial0.o .pioenvs/uno/FrameworkArduino/HardwareSerial1.o .pioenvs/uno/FrameworkArduino/HardwareSerial2.o .pioenvs/uno/FrameworkArduino/HardwareSerial3.o .pioenvs/uno/FrameworkArduino/IPAddress.o .pioenvs/uno/FrameworkArduino/PluggableUSB.o .pioenvs/uno/FrameworkArduino/Print.o .pioenvs/uno/FrameworkArduino/Stream.o .pioenvs/uno/FrameworkArduino/Tone.o .pioenvs/uno/FrameworkArduino/USBCore.o .pioenvs/uno/FrameworkArduino/WInterrupts.o .pioenvs/uno/FrameworkArduino/WMath.o .pioenvs/uno/FrameworkArduino/WString.o .pioenvs/uno/FrameworkArduino/_wiring_pulse.o .pioenvs/uno/FrameworkArduino/abi.o .pioenvs/uno/FrameworkArduino/hooks.o .pioenvs/uno/FrameworkArduino/main.o .pioenvs/uno/FrameworkArduino/new.o .pioenvs/uno/FrameworkArduino/wiring.o .pioenvs/uno/FrameworkArduino/wiring_analog.o .pioenvs/uno/FrameworkArduino/wiring_digital.o .pioenvs/uno/FrameworkArduino/wiring_pulse.o .pioenvs/uno/FrameworkArduino/wiring_shift.o
        avr-ranlib .pioenvs/uno/libFrameworkArduino.a
        avr-g++ -o .pioenvs/uno/SPI/SPI.o -c -fno-exceptions -fno-threadsafe-statics -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO -DARDUINO=10606 -I.pioenvs/uno/FrameworkArduino -I.pioenvs/uno/FrameworkArduinoVariant -I.pioenvs/uno/SPI .pioenvs/uno/SPI/SPI.cpp
        avr-ar rcs .pioenvs/uno/libSPI.a .pioenvs/uno/SPI/SPI.o
        avr-ranlib .pioenvs/uno/libSPI.a
        avr-g++ -o .pioenvs/uno/firmware.elf -Os -mmcu=atmega328p -Wl,--gc-sections,--relax .pioenvs/uno/src/tmp_ino_to.o -L.pioenvs/uno -Wl,--start-group -lm .pioenvs/uno/libFrameworkArduinoVariant.a .pioenvs/uno/libFrameworkArduino.a .pioenvs/uno/libSPI.a -Wl,--end-group
        avr-objcopy -O ihex -R .eeprom .pioenvs/uno/firmware.elf .pioenvs/uno/firmware.hex
        "avr-size" --mcu=atmega328p -C -d .pioenvs/uno/firmware.elf
        AVR Memory Usage
        Device: atmega328p
        Program:   13988 bytes (42.7% Full)
        (.text + .data + .bootloader)
        Data:        697 bytes (34.0% Full)
        (.data + .bss + .noinit)
        Regards Ivan,
        The PlatformIO Team
        • lrtsenarL
          lrtsenarL
          lrtsenar
          I use Source Insight. Sure it's not free but it's a full featured tools never equaled (like Visual Assist plug in for Visual Studio).
          • barduinoB
            barduinoB
            barduino
            HI
            I've been trying vs code
            It has GIT integration, Arduino file format and some auto complete.
            It is also capable of verifying and uploading the sketch
            • axillentA
              axillentA
              axillent
              atmel added arduino support to their latest atmel studio v7
              not tested yet, but it should be also an option
              sense and drive
              • marceltrapmanM
                marceltrapmanM
                marceltrapman
                I've (very) recently moved from Eclipse to IntelliJ for my Java and PyCharm for my Python development.
                I am really happy and have a subscription for the whole IDE ecosystem from JetBrains.
                With that comes CLion which also has an Arduino Plugin.
                I have not tried using it yet but it looks good.
                And CLion also works with PlatformIO (http://docs.platformio.org/en/latest/ide/clion.html)
                Fulltime Servoy Developer
                • Daniel OliveiraD
                  Daniel OliveiraD
                  Daniel Oliveira
                  @smilvert I would like to know if you succeed using PlatformIO.
                  Thank you
                  MySensors rules my home :)
                  I 1 Reply Last reply
                    MySensors is on plaformio, so I guess it should work.
                    http://platformio.org/lib/show/548/MySensors
                    • Daniel OliveiraD Daniel Oliveira
                      Thank you
                      I
                      I
                      ivankravets
                      #24
                      @Daniel-Oliveira We have some problems with previous PlatformIO 2.0 Build System and MySensor Library structure. All these issues are resolved in PlatformIO 3.0 where are introduced new build system and library manager with support for 3-rd party manifests (Arduino's library.properties, ARM mbed module.json).
                      PlatformIO 3.0 has not been finally released. We released the first public alpha version. How to use it?
                      1. Install PlatformIO IDE or PlatformIO CLI and switch it to development version.
                      2. Menu: PlatformIO > Initialize new project
                      3. Open platformio.ini project configuration files (will be created in the project)
                      4. Specify project dependencies. See docs for lib_deps option.
                      5. Press build/upload button.
                      For example, the final project configuration file for the Arduino Uno will look like:
                      [env:uno]
                      platform = atmelavr
                      framework = arduino
                      board = uno
                      lib_deps = MySensors
                      You can also specify Semantic Versioning rules and depend on the specific version or range of versions. For example, lib_deps = MySensors@~2.0.1-beta means that any version of 2.0.x (including beta and higher) is allowed for your project.
                      Regards Ivan,
                      The PlatformIO Team
                      tbowmoT 1 Reply Last reply
                        @ivankravets
                        You've done a great job on plaformio :thumbsup: , finally a decent library manager with dependency handling.
                        • I ivankravets
                          [env:uno]
                          platform = atmelavr
                          framework = arduino
                          board = uno
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @ivankravets
                          Great work.. One question, is it possible to install your own hardware profiles? For example for the Sensebender Micro, or the new Gateway device I'm working on?
                            @ivankravets
                            I
                            I
                            ivankravets
                            @hek thanks a lot for the feedback :+1:
                            Regards Ivan,
                            The PlatformIO Team
                            • tbowmoT tbowmo
                              @ivankravets
                              I
                              I
                              ivankravets
                              #28
                              @tbowmo Sure, it is possible in PlatformIO 2.0 too. However, we don't recommend to make integration with it. PlatformIO 2.0 has not been changed since 2014 year. It was as hobby/experimental project.
                              PlatformIO 3.0 is a new PlatformIO where all hardware related parts were moved to separated repositories. PlatformIO 3.0 is closer to open source. You don't need to contact with The PlatformIO Team (as you need to do it with PlatformIO 2.0) because you can create own development platform, clone existing or just add an own board to the existing development platform. Feel free to make PR and we will merge it.
                              We will create "Development Platforms Registry" later. It will 3-rd party developers to register own development platforms and hardware in the public registry.
                              The core idea of PlatformIO 3.0 is to provide professional cross-platform build system without dependencies with powerful library manager. It will allow others developers/companies to create awesome software basing on PlatformIO Tools.
                              P.S: Here is docs (beta) how to create development platform or integrate custom embedded board: http://docs.platformio.org/en/latest/platforms/custom_platform_and_board.html
                              Regards Ivan,
                              The PlatformIO Team
                                stedew
                                Hello Mr Kravets,
                                Can you give a hint/short explanation why Mysensors 2.0 Compiles ok in the upgraded version (the development branch). I can understand its maybe one off your internal secrets but i think that it can be benificial for others. I love a lot one off the "concurrent" IDE (Arduino Eclipse) and the (for my case) Problem is that it doesn't compile Mysensors 2.0. I assume with my limited knowledge and observations off the compiler errors the problems there are related..
                                -I Also tested the build and it took severall attempt to get it compiling. Unfotunatly i cannot reproduce it (Windows usr ;-) ) I had to fiddle severall times in the PATH var and settings and restart the IDE ....
                                Anyway I hope that Arduino ide sees one day the Light and gets some inspiration on a project like this or even better start co-operating....
                                Good work !!!
                                • S stedew
                                  Hello Mr Kravets,
                                  Good work !!!
                                  I
                                  I
                                  ivankravets
                                  This is not a secret. PlatformIO 2.0 doesn't support 3-rd party library manifests. These different manifests are suitable for the own builders. For example, Arduino IDE builder has own behaviour. If library doesn't contain src folder, then it will build only source files from the root of library (other folders are ignored). If src directory exists, then only the source code from src should be built. The another story is with ARM mbed compiler.
                                  PlatformIO 3.0 is an unique cross-platform ecosystem that replaces all builders above and allows you to build different project in the same manner. We wrote different extensions for PlatformIO 3.0 Build System that allow handling 3-rd party manifests and "configure" build system on-the-fly. What is more, we don't depend on Arduino IDE, Java or ARM mbed yotta. PlatformIO is written in pure Python and doesn't depend on OS software. The only 1 requirement is Python interpreter (that is installed everywhere except Windows).
                                  Could you explain in details? Thanks.
                                  Regards Ivan,
                                  The PlatformIO Team
                                    stedew
                                    Hmm tnx for the clarification
                                    I have a small party here (Wife birthday) so I will try to reproduce it later.
                                    Otherwise the automatic script Divorse now will start...
                                    regards,
                                    Stefan.
                                    • S stedew
                                      regards,
                                      Stefan.
                                      I
                                      I
                                      ivankravets
                                      @stedew my congrats for your wife :blush: :bouquet: :birthday:
                                      Regards Ivan,
                                      The PlatformIO Team
                                      S 1 Reply Last reply
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #33
                                        @ivankravets
                                        One more question about the framework..
                                        Right now, we only have a very minimal hardware definition setup for the Sensebender Micro / Gateway boards, and rely on arduino to have installed their board files for the mcu architecture that we are using (for example, by choosing SenseBender GW, SAMD board, you also need to have arduino zero installed as a target in Arduino IDE, to get arduino core files)
                                        Can we do the same in platformio? Or do we need to include the complete arduino samd framework in our mysensors hw repositories, to be able to build in platform.io?
                                        • tbowmoT tbowmo
                                          @ivankravets
                                          I
                                          I
                                          ivankravets
                                          @tbowmo said:
                                          There is no problem to add your custom board to existing development platform. What MCU is used in the board?
                                          See existing SAM/SAMD manifests https://github.com/platformio/platform-atmelsam/tree/develop/boards
                                          In PlatformIO you have to specify platform type for the build environment in platformio.ini. board and framework options are optional. You don't need to keep framework/SDK code within library. Development platform depends on it. See
                                          See project examples:
                                          • https://github.com/platformio/platformio-examples
                                          Regards Ivan,
                                          The PlatformIO Team
