  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 54.8k Views 3 Watching
    @humblehacker
    Yes, it should be enabled by default, that's why I didn't mention it in my first advice. But it's good to double check anyway.
    Are you sure you have two different instances of the Arduino IDE running when you test? Only one serial monitor can be active at a time, per IDE. It's not enough to open a second sketch window. You have to start the IDE twice from the start menu, or however you start it. Also, check the ports. You should see different headings in the serial monitor window, specifying the port.
    What hardware are you using?
    H
    H
    humblehacker
    @martinhjelmare said:
    @humblehacker
    I had replied to this a couple days ago but it must not have posted so I apologize for the tardy response...
    I think I might've narrowed down to what my problem is but first I'll reply to your question. My first test used two different instances of the IDE running on two different systems.
    The gateway controller sketch was compiled on Windows 10 w/Arduino 1.6.6 and ran successfully on an Arduino UNO. The sensor/sender sketch was compiled on my Ubuntu MATE 15.10 laptop with Arduino 1.6.6 on an Arduino Leonardo.
    Interestingly, I just tried swapping out the hardware so the Uno connected to Linux and the Leo connected to Windows. Sure enough, the Uno works as expected running both the sensor and the gateway sketch on Linux and Windows while the Leo won't work with any MySensors sketch on either Linux or Windows... So the problem may be related to the serial port on the ATMega32u4. As I mentioned earlier, I was able to get the Leo to work with the standard RF24 library, so it must be something about the Mysensors library that doesn't get along with the ATMega32u4 processors...
    I'll try running my Arduino Nano now to see if it works with signals sent from my Uno.
    • H
      H
      humblehacker
      UPDATE:
      YES!!! The Uno connected to the motion sensor is transmitting data to my Arduino Nano gateway and I can finally see the data on the serial monitor! Now I just need to reconnect the gateway to Home Assistant to see what it picks up.
      Lesson learned as of the present is to only use ATMega328 processors like the Uno, Nano, Pro Mini etc... Most of my controllers at this point are based on the 32u4 so it would be good if we could figure out why the Leo boards don't work with MYS... Has anybody else experienced this problem?
      • H
        H
        humblehacker
        Sure enough-
        WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
        @martinhjelmare- How do I create a new gateway instance? Simply restart?
        • H humblehacker
          Sure enough-
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @humblehacker
          If using home assistant, it's enough to restart home assistant, to get a new gateway instance and reconnect.
          • H
            H
            humblehacker
            :smiley:
            Other than the fact that my log seems to think its yesterday... I just need to find out why I can't use MySensors with Any ATMega32u4 devices... Attiny85/Trinket support would be nice too but I dont need to push my luck...
            • H humblehacker
              :smiley:
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @humblehacker
              :thumbsup:
              • K
                K
                kielnino
                I'm still stuck with the import of sensors to home-assitant. Can someone please post his configuration.yaml? I Wonder if I made a stupid configuration error there.
                Do I need the "inclusion mode" of the Gateway or does home-assistant handle the detection of new sensors? In the serial monitor all the communication between the nodes and the Gateway is looking good, but in home-assistant they won't show up.
                • K kielnino
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @kielnino
                  Home assistant adds the new device after the sensor has presented itself to the gateway and sent at least one value. So proper presentation messages has to be sent by the node and received by the gateway. These include node id, sensor child id, sketch name and presentation "S_VALUE". Then one value should be sent using the correct "V_VALUE".
                  See the mysensor API documentation for the S_VALUES and V_VALUES.
                  See below for the sensors excerpt from my config. If you have multiple sensor platforms you need to increment the sensor name with a number: sensor, sensor 2, sensor 3, etc. All sensor platforms should be one continuing block in the config. Note that this is not my config for my github fork of home assistant. For that one, you need to add a separate domain in the config for mysensors.
                  # SENSORS
                  # Mysensors
                  sensor:
                    platform: mysensors
                    port: "/dev/ttyUSB0"
                  #  debug:
                  # forecast.io
                  sensor 2:
                    platform: forecast
                    api_key: ***censored***
                    monitored_conditions:
                      - summary
                      - precip_type
                      - precip_intensity
                      - temperature
                      - dew_point
                      - wind_speed
                      - wind_bearing
                      - cloud_cover
                      - humidity
                      - pressure
                      - visibility
                      - ozone
                  # time_date
                  sensor 3:
                    platform: time_date
                    display_options:
                      - 'time'
                      - 'date'
                      - 'date_time'
                      - 'time_date'
                      - 'time_utc'
                      - 'beat'
                  • D
                    drock1985
                    Hi @martinhjelmare
                    Just wanted to first say thank you for the port of MySensors to Home-Assistant. I'm currently in the process of switching from Domoticz to Home-Assistant, and have a quick question about getting my node recognized.
                    I have a Doorbell/Chome monitor, and it gets the ID from the gateway no problem. It shows up in HA after pressing the doorbell button (as a motion sensor, since that is the trigger) but I can't control the chime itself (aka, whether the bell rings if the door is pressed or not) which is set as a light switch.
                    I know from reading this thread that in order for a device to first appear in HA, it must send a command to the gateway. Is there any way for me through HA to force a command to the childid light switch, so that it will show up on its own?
                    My Projects
                    2 Door Chime Sensor
                    Washing Machine Monitor
                    • D drock1985
                      Hi @martinhjelmare
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      #29
                      @drock1985
                      Hi!
                      First I'd just want to make clear that I'm not the original author or maintainer of pymysensors, which is the mysensors API that home assistant uses. I have just made some pull requests to pymysensors and I'd like to improve the functionality, if possible.
                      To answer your question, mysensors switches are not yet supported in home assistant. That's what one of my pull requests want to solve, but it has yet to be merged. There is currently no way of forcing a node to resend it's presentation, if that info is lacking on the gateway side. This could be solved after version 1.6 of mysensors gets released but it will take more development, both on pymysensors and home assistant sides.
                      If you want to make sure that the doorbell shows up in the GUI, before the first press of the button, just send the sensor value to the gateway, in the end of the setup function in your node sketch.
                      For example, if you have defined a msgMotion for the doorbell:
                      gw.send(msgMotion.set("0"));
                      • D
                        drock1985
                        Hi @martinhjelmare
                        I decided to try this on a simplier sketch that I have, but still no luck. I added this line gw.send(lightMsgW.set("1")); to the end of void setup(). The sensor shows up at the top of the States screen in HA, but doesn't let me actually control it, and it doesn't show up in Switches or Lights.
                        Here is the sketch that I am using.
                         * Version 1.0 - 6-December-2015, Derrick Rockwell
                         *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
                         *can usually be found in most dollar stores/hardware stores and are
                         *battery powered. This sketch uses digital pins 3 and 4 to power two
                         *a string of lights each. Ex, one can control white lights the other
                         *could control multi-colour lights.
                        #define SN "HolidayLEDDeskLights"
                        #define SV "1.0"
                        #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
                        #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
                        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                        #define CHILD_ID0 3
                        #define CHILD_ID1 5
                        static int currentLevelM = 0;  // Current dim level...
                        static int currentLevelW = 0;  // Current dim level...
                        MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
                        MyMessage lightMsgM(MLED_PIN, V_LIGHT);
                        MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
                        MyMessage lightMsgW(WLED_PIN, V_LIGHT);
                         * Dimmable LED initialization method
                          Serial.println( SN );
                          Serial.println( SV );
                          gw.begin( incomingMessage );
                          // Register the LED Dimmable Light with the gateway
                          gw.present( MLED_PIN, S_DIMMER );
                          gw.present( WLED_PIN, S_DIMMER );
                          gw.sendSketchInfo(SN, SV);
                          // Pull the gateway's current dim level - restore light level upon sendor node power-up
                          gw.request( MLED_PIN, V_DIMMER );
                          gw.request( WLED_PIN, V_DIMMER );
                         *  Dimmable LED main processing loop
                        //For Multi Coloured Lights
                        if (message.type == V_LIGHT || message.type == V_DIMMER) {
                              // if (message.sensor <= 2)
                                  //0: All Dimmers
                                  //1: LED 1
                                  //2: LED 2
                                  if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                                    fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                                    gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                                    gw.send(dimmerMsgM.set(requestedLevel) );
                                  if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                                    fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                                    gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                                    gw.send(dimmerMsgW.set(requestedLevel) );
                         *  This method provides a graceful fade up/down effect
                         // For Multi Coloured Lights
                        void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
                          int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
                          while ( (*currentLevel) != toLevel ) {
                            (*currentLevel) += delta;
                            analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
                            delay( FADE_DELAY );
                        My Projects
                        2 Door Chime Sensor
                        martinhjelmareM H 2 Replies Last reply
                        • D drock1985
                          Hi @martinhjelmare
                          #define SV "1.0"
                          #define CHILD_ID0 3
                          #define CHILD_ID1 5
                                    //0: All Dimmers
                                    //1: LED 1
                                    //2: LED 2
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          As I wrote above, switches are not supported yet, in the default releases of home assistant. That support only exists in my personal branches at github.
                          • D
                            drock1985
                            @martinhjelmare
                            And how would I install your branch of home-assistant then so that I can use it?
                            My Projects
                            2 Door Chime Sensor
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              #33
                              You can test it by cloning my fork of home-assistant (https://github.com/MartinHjelmare/home-assistant), then checkout my branch "mysensors-component-switch". Then install it with pip. See my console log below. BIG DISCLAIMER: This is work in progress and under development. You are cloning my branch, which is based off the home assistant dev branch, which is not a stable release.
                              martin@martin-htpc:~$ mkvirtualenv -p python3 testhomeass
                              Running virtualenv with interpreter /usr/bin/python3
                              Using base prefix '/usr'
                              New python executable in testhomeass/bin/python3
                              Also creating executable in testhomeass/bin/python
                              Installing setuptools, pip, wheel...done.
                              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/predeactivate
                              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postdeactivate
                              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/preactivate
                              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postactivate
                              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/get_env_details
                              (testhomeass)martin@martin-htpc:~$ cd Dev/
                              (testhomeass)martin@martin-htpc:~/Dev$ mkdir testhomeass
                              (testhomeass)martin@martin-htpc:~/Dev$ cd testhomeass/
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ git clone git@github.com:MartinHjelmare/home-assistant.git
                              Klonar till "home-assistant"...
                              remote: Counting objects: 28876, done.
                              remote: Total 28876 (delta 0), reused 0 (delta 0), pack-reused 28876
                              Tar emot objekt: 100% (28876/28876), 25.45 MiB | 1.59 MiB/s, done.
                              Analyserar delta: 100% (19679/19679), done.
                              Kontrollerar anslutning... klart.
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ cd home-assistant/
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git status
                              På grenen dev
                              Din gren är à jour med "origin/dev".
                              inget att checka in, arbetskatalogen ren
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git checkout mysensors-component-switch
                              Grenen mysensors-component-switch ställdes in att spåra fjärrgrenen mysensors-component-switch från origin.
                              Växlade till en ny gren "mysensors-component-switch"
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ pip install .
                              Processing /home/martin/Dev/testhomeass/home-assistant
                              Collecting requests<3,>=2 (from homeassistant==0.9.0.dev0)
                                Using cached requests-2.8.1-py2.py3-none-any.whl
                              Collecting pyyaml<4,>=3.11 (from homeassistant==0.9.0.dev0)
                              Collecting pytz>=2015.4 (from homeassistant==0.9.0.dev0)
                                Using cached pytz-2015.7-py2.py3-none-any.whl
                              Requirement already satisfied (use --upgrade to upgrade): pip>=7.0.0 in /home/martin/.virtualenvs/testhomeass/lib/python3.4/site-packages (from homeassistant==0.9.0.dev0)
                              Collecting vincenty==0.1.3 (from homeassistant==0.9.0.dev0)
                              Building wheels for collected packages: homeassistant
                                Running setup.py bdist_wheel for homeassistant
                                Stored in directory: /home/martin/.cache/pip/wheels/0d/98/ff/ecb5c632258e50fbc91b535762865e4a132eb966f5c28f00d7
                              Successfully built homeassistant
                              Installing collected packages: requests, pyyaml, pytz, vincenty, homeassistant
                              Successfully installed homeassistant-0.9.0.dev0 pytz-2015.7 pyyaml-3.11 requests-2.8.1 vincenty-0.1.3
                              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ hass
                              Config directory: /home/martin/.homeassistant
                              WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
                              INFO:homeassistant.bootstrap:Home Assistant core initialized
                              INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
                              INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                              INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                              INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                              INFO:homeassistant.loader:Loaded notify from homeassistant.components.notify
                              INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                              INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                              INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                              INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                              INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                              INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                              INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
                              INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                              INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
                              INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                              INFO:homeassistant.components.introduction:
                                      Hello, and welcome to Home Assistant!
                                      We'll hope that we can make all your dreams come true.
                                      Here are some resources to get started:
                                       - Configuring Home Assistant:
                                         https://home-assistant.io/getting-started/configuration/
                                       - Available components:
                                         https://home-assistant.io/components/
                                       - Troubleshooting your configuration:
                                         https://home-assistant.io/getting-started/troubleshooting-configuration/
                                       - Getting help:
                                         https://home-assistant.io/help/
                                      This message is generated by the introduction component. You can
                                      disable it in configuration.yaml.
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                              INFO:homeassistant.loader:Loaded notify.telegram from homeassistant.components.notify.telegram
                              INFO:homeassistant.util.package:Attempting install of python-telegram-bot==2.8.7
                              INFO:homeassistant.components.notify.telegram:Telegram bot is '***censored***'.
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=telegram, domain=notify>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=notify>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                              INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                              INFO:homeassistant.util.package:Attempting install of https://github.com/MartinHjelmare/pymysensors/archive/fifo_queue.zip#pymysensors==0.3
                              INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                              INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group>
                              INFO:homeassistant.loader:Loaded automation.state from homeassistant.components.automation.state
                              INFO:homeassistant.components.automation:Initialized rule Rule 1 - Door bell pressed
                              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=automation>
                              INFO:homeassistant.core:Starting Home Assistant (16 threads)
                              INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                              INFO:homeassistant.components.mysensors:update persistence: node 1
                              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=, update_type=persistence, node_id=1>
                              INFO:homeassistant.components.mysensors:adding new devices: [<Entity Sensebender Micro Bell 1.1: >, <Entity Sensebender Micro Bell 1.2: >, <Entity Sensebender Micro Bell 1.199: >]
                              INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                              INFO:homeassistant.core:Timer:starting
                              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, update_type=persistence, node_id=1>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, new_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
                              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.1: value_type 0, value = 21.0
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, new_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, old_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; battery_level=100, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
                              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.2: value_type 1, value = 34
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, old_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; battery_level=100, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
                              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.199: value_type 38, value = 3160
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, new_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, old_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=3160; battery_level=100, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
                              INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                              INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                              ^CINFO:homeassistant.core:Stopping
                              INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                              INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                              INFO:mysensors.mysensors:Stopping thread
                              INFO:homeassistant.components.recorder:Closing database
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                       - Getting help:
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=notify, service=telegram>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=, port=/dev/ttyUSB0, node_id=1>
                              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, port=/dev/ttyUSB0, node_id=1>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; child_id=1, unit_of_measurement=°C, battery_level=100, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; child_id=2, unit_of_measurement=%, battery_level=100, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
                              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=; child_id=199, unit_of_measurement=V, battery_level=0, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                              You can see that I get a warning about bad byte, after first start. I solve this by restarting hass.
                              Your home assistant config for mysensors should now be structured like this:
                              mysensors:
                                port:
                                  - '/dev/ttyUSB0'
                                #  - '/dev/ttyACM0'
                                debug: true
                                persistence: true
                                persistence_file:
                                  - '/home/martin/.homeassistant/mysensors.json'
                                #  - '/home/martin/.homeassistant/mysensors2.json'
                                version: '1.5'
                              sensor:
                                platform: mysensors
                              switch:
                                platform: mysensors
                              • D drock1985
                                Hi @martinhjelmare
                                #define SV "1.0"
                                #define CHILD_ID0 3
                                #define CHILD_ID1 5
                                          //0: All Dimmers
                                          //1: LED 1
                                          //2: LED 2
                                H
                                H
                                humblehacker
                                @drock1985
                                It looks like we're trying to do similar things with HA and MYS... I've been working on a rotary encoder switch for colored lights (eg Limitlessled/HUE etc...) and had been trying to program it through MQTT. However, I just now noticed the LEDDIMMERwithROTARYENCODER sketch in the MySensors examples so I thought I might try using MYS instead of MQTT. Of course that leads right back to the lack of support for MYS Switches in HASS... Perhaps there's a solution for both of our problems if we use an MQTT Gateway instead? I've worked with MQTT and NodeRED before and it was pretty straight forward, but then again I've been having a much harder time understanding the way its implemented in HASS... So I might need to work with it some more before I can be of any help testing the MQTT MYS Gateway with HA...
                                • H humblehacker
                                  @drock1985
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @humblehacker
                                  Hi!
                                  I also want to try the MQTT gateway together with HA. MQTT support is well supported in HA, and looking at the MQTT protocol in mysensors dev branch it looks promising. I have just got some ethernet modules and more nanos, so as soon as I find some time, I'll get started. We can post our progress somewhere here whoever gets it going first.
                                  • D
                                    drock1985
                                    wrote on last edited by drock1985
                                    #36
                                    @humblehacker @martinhjelmare
                                    Sounds like an interesting idea to me. I have never used a MQTT gateway before, so i'm going in a little blind. I think I have the server so far (mosquitto) running on the same RPI as my HA install; so now looking into the next step.
                                    One thing though, would this replace my current serial gateway, or be an addition to it?
                                    My Projects
                                    2 Door Chime Sensor
                                    • D
                                      drock1985
                                      I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
                                      #MySensors MQTT Test
                                      mqtt 1:
                                        broker: 192.168.86.198
                                        port: 1883
                                      #  client_id: home-assistant-1
                                        keepalive: 60
                                      #  username: USERNAME
                                      #  password: PASSWORD
                                      The Serial output from Arduino shows that I connected successfully
                                      0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
                                      0;0;3;0;9;Radio init successful.
                                      IP: 192.168.86.112
                                      0;0;3;0;9;MQTT connected
                                      0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                                      But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
                                      15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
                                      15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
                                      Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
                                      My Projects
                                      2 Door Chime Sensor
                                        Sorry, havent tried HomeAssistant myself.
                                        • D
                                          drock1985
                                          Thanks @hek , had to ask :)
                                          Would it be possible to get a Home-Assistant dedicated sub-forum please?
                                          My Projects
                                          2 Door Chime Sensor
