  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • D
    drock1985
    Hi @martinhjelmare
    Just wanted to first say thank you for the port of MySensors to Home-Assistant. I'm currently in the process of switching from Domoticz to Home-Assistant, and have a quick question about getting my node recognized.
    I have a Doorbell/Chome monitor, and it gets the ID from the gateway no problem. It shows up in HA after pressing the doorbell button (as a motion sensor, since that is the trigger) but I can't control the chime itself (aka, whether the bell rings if the door is pressed or not) which is set as a light switch.
    I know from reading this thread that in order for a device to first appear in HA, it must send a command to the gateway. Is there any way for me through HA to force a command to the childid light switch, so that it will show up on its own?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      Hi @martinhjelmare
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      #29
      @drock1985
      Hi!
      First I'd just want to make clear that I'm not the original author or maintainer of pymysensors, which is the mysensors API that home assistant uses. I have just made some pull requests to pymysensors and I'd like to improve the functionality, if possible.
      To answer your question, mysensors switches are not yet supported in home assistant. That's what one of my pull requests want to solve, but it has yet to be merged. There is currently no way of forcing a node to resend it's presentation, if that info is lacking on the gateway side. This could be solved after version 1.6 of mysensors gets released but it will take more development, both on pymysensors and home assistant sides.
      If you want to make sure that the doorbell shows up in the GUI, before the first press of the button, just send the sensor value to the gateway, in the end of the setup function in your node sketch.
      For example, if you have defined a msgMotion for the doorbell:
      gw.send(msgMotion.set("0"));
      • D
        drock1985
        Hi @martinhjelmare
        I decided to try this on a simplier sketch that I have, but still no luck. I added this line gw.send(lightMsgW.set("1")); to the end of void setup(). The sensor shows up at the top of the States screen in HA, but doesn't let me actually control it, and it doesn't show up in Switches or Lights.
        Here is the sketch that I am using.
         * Version 1.0 - 6-December-2015, Derrick Rockwell
         *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
         *can usually be found in most dollar stores/hardware stores and are
         *battery powered. This sketch uses digital pins 3 and 4 to power two
         *a string of lights each. Ex, one can control white lights the other
         *could control multi-colour lights.
        #define SN "HolidayLEDDeskLights"
        #define SV "1.0"
        #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
        #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
        #define CHILD_ID0 3
        #define CHILD_ID1 5
        static int currentLevelM = 0;  // Current dim level...
        static int currentLevelW = 0;  // Current dim level...
        MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
        MyMessage lightMsgM(MLED_PIN, V_LIGHT);
        MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
        MyMessage lightMsgW(WLED_PIN, V_LIGHT);
         * Dimmable LED initialization method
          Serial.println( SN );
          Serial.println( SV );
          gw.begin( incomingMessage );
          // Register the LED Dimmable Light with the gateway
          gw.present( MLED_PIN, S_DIMMER );
          gw.present( WLED_PIN, S_DIMMER );
          gw.sendSketchInfo(SN, SV);
          // Pull the gateway's current dim level - restore light level upon sendor node power-up
          gw.request( MLED_PIN, V_DIMMER );
          gw.request( WLED_PIN, V_DIMMER );
         *  Dimmable LED main processing loop
        //For Multi Coloured Lights
        if (message.type == V_LIGHT || message.type == V_DIMMER) {
              // if (message.sensor <= 2)
                  //0: All Dimmers
                  //1: LED 1
                  //2: LED 2
                  if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                    fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                    gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                    gw.send(dimmerMsgM.set(requestedLevel) );
                  if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                    fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                    gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                    gw.send(dimmerMsgW.set(requestedLevel) );
         *  This method provides a graceful fade up/down effect
         // For Multi Coloured Lights
        void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
          int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
          while ( (*currentLevel) != toLevel ) {
            (*currentLevel) += delta;
            analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
            delay( FADE_DELAY );
        My Projects
        2 Door Chime Sensor
        martinhjelmareM H 2 Replies Last reply
        • D drock1985
          Hi @martinhjelmare
          #define SV "1.0"
          #define CHILD_ID0 3
          #define CHILD_ID1 5
                    //0: All Dimmers
                    //1: LED 1
                    //2: LED 2
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @drock1985
          As I wrote above, switches are not supported yet, in the default releases of home assistant. That support only exists in my personal branches at github.
          • D
            drock1985
            @martinhjelmare
            And how would I install your branch of home-assistant then so that I can use it?
            My Projects
            2 Door Chime Sensor
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              #33
              You can test it by cloning my fork of home-assistant (https://github.com/MartinHjelmare/home-assistant), then checkout my branch "mysensors-component-switch". Then install it with pip. See my console log below. BIG DISCLAIMER: This is work in progress and under development. You are cloning my branch, which is based off the home assistant dev branch, which is not a stable release.
              martin@martin-htpc:~$ mkvirtualenv -p python3 testhomeass
              Running virtualenv with interpreter /usr/bin/python3
              Using base prefix '/usr'
              New python executable in testhomeass/bin/python3
              Also creating executable in testhomeass/bin/python
              Installing setuptools, pip, wheel...done.
              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/predeactivate
              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postdeactivate
              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/preactivate
              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postactivate
              virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/get_env_details
              (testhomeass)martin@martin-htpc:~$ cd Dev/
              (testhomeass)martin@martin-htpc:~/Dev$ mkdir testhomeass
              (testhomeass)martin@martin-htpc:~/Dev$ cd testhomeass/
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ git clone git@github.com:MartinHjelmare/home-assistant.git
              Klonar till "home-assistant"...
              remote: Counting objects: 28876, done.
              remote: Total 28876 (delta 0), reused 0 (delta 0), pack-reused 28876
              Tar emot objekt: 100% (28876/28876), 25.45 MiB | 1.59 MiB/s, done.
              Analyserar delta: 100% (19679/19679), done.
              Kontrollerar anslutning... klart.
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ cd home-assistant/
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git status
              På grenen dev
              Din gren är à jour med "origin/dev".
              inget att checka in, arbetskatalogen ren
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git checkout mysensors-component-switch
              Grenen mysensors-component-switch ställdes in att spåra fjärrgrenen mysensors-component-switch från origin.
              Växlade till en ny gren "mysensors-component-switch"
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ pip install .
              Processing /home/martin/Dev/testhomeass/home-assistant
              Collecting requests<3,>=2 (from homeassistant==0.9.0.dev0)
                Using cached requests-2.8.1-py2.py3-none-any.whl
              Collecting pyyaml<4,>=3.11 (from homeassistant==0.9.0.dev0)
              Collecting pytz>=2015.4 (from homeassistant==0.9.0.dev0)
                Using cached pytz-2015.7-py2.py3-none-any.whl
              Requirement already satisfied (use --upgrade to upgrade): pip>=7.0.0 in /home/martin/.virtualenvs/testhomeass/lib/python3.4/site-packages (from homeassistant==0.9.0.dev0)
              Collecting vincenty==0.1.3 (from homeassistant==0.9.0.dev0)
              Building wheels for collected packages: homeassistant
                Running setup.py bdist_wheel for homeassistant
                Stored in directory: /home/martin/.cache/pip/wheels/0d/98/ff/ecb5c632258e50fbc91b535762865e4a132eb966f5c28f00d7
              Successfully built homeassistant
              Installing collected packages: requests, pyyaml, pytz, vincenty, homeassistant
              Successfully installed homeassistant-0.9.0.dev0 pytz-2015.7 pyyaml-3.11 requests-2.8.1 vincenty-0.1.3
              (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ hass
              Config directory: /home/martin/.homeassistant
              WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
              INFO:homeassistant.bootstrap:Home Assistant core initialized
              INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
              INFO:homeassistant.loader:Loaded history from homeassistant.components.history
              INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
              INFO:homeassistant.loader:Loaded http from homeassistant.components.http
              INFO:homeassistant.loader:Loaded notify from homeassistant.components.notify
              INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
              INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
              INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
              INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
              INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
              INFO:homeassistant.loader:Loaded api from homeassistant.components.api
              INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
              INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
              INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
              INFO:homeassistant.loader:Loaded group from homeassistant.components.group
              INFO:homeassistant.components.introduction:
                      Hello, and welcome to Home Assistant!
                      We'll hope that we can make all your dreams come true.
                      Here are some resources to get started:
                       - Configuring Home Assistant:
                         https://home-assistant.io/getting-started/configuration/
                       - Available components:
                         https://home-assistant.io/components/
                       - Troubleshooting your configuration:
                         https://home-assistant.io/getting-started/troubleshooting-configuration/
                       - Getting help:
                         https://home-assistant.io/help/
                      This message is generated by the introduction component. You can
                      disable it in configuration.yaml.
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
              INFO:homeassistant.loader:Loaded notify.telegram from homeassistant.components.notify.telegram
              INFO:homeassistant.util.package:Attempting install of python-telegram-bot==2.8.7
              INFO:homeassistant.components.notify.telegram:Telegram bot is '***censored***'.
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=telegram, domain=notify>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=notify>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
              INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
              INFO:homeassistant.util.package:Attempting install of https://github.com/MartinHjelmare/pymysensors/archive/fifo_queue.zip#pymysensors==0.3
              INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
              INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group>
              INFO:homeassistant.loader:Loaded automation.state from homeassistant.components.automation.state
              INFO:homeassistant.components.automation:Initialized rule Rule 1 - Door bell pressed
              INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=automation>
              INFO:homeassistant.core:Starting Home Assistant (16 threads)
              INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
              INFO:homeassistant.components.mysensors:update persistence: node 1
              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=, update_type=persistence, node_id=1>
              INFO:homeassistant.components.mysensors:adding new devices: [<Entity Sensebender Micro Bell 1.1: >, <Entity Sensebender Micro Bell 1.2: >, <Entity Sensebender Micro Bell 1.199: >]
              INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
              INFO:homeassistant.core:Timer:starting
              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, update_type=persistence, node_id=1>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, new_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.1: value_type 0, value = 21.0
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, new_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, old_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; battery_level=100, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.2: value_type 1, value = 34
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, old_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; battery_level=100, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
              INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.199: value_type 38, value = 3160
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, new_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, old_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=3160; battery_level=100, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
              INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
              INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
              WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
              ^CINFO:homeassistant.core:Stopping
              INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
              INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
              INFO:mysensors.mysensors:Stopping thread
              INFO:homeassistant.components.recorder:Closing database
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                       - Getting help:
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=notify, service=telegram>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
              INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=, port=/dev/ttyUSB0, node_id=1>
              INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, port=/dev/ttyUSB0, node_id=1>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; child_id=1, unit_of_measurement=°C, battery_level=100, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; child_id=2, unit_of_measurement=%, battery_level=100, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
              INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=; child_id=199, unit_of_measurement=V, battery_level=0, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
              You can see that I get a warning about bad byte, after first start. I solve this by restarting hass.
              Your home assistant config for mysensors should now be structured like this:
              mysensors:
                port:
                  - '/dev/ttyUSB0'
                #  - '/dev/ttyACM0'
                debug: true
                persistence: true
                persistence_file:
                  - '/home/martin/.homeassistant/mysensors.json'
                #  - '/home/martin/.homeassistant/mysensors2.json'
                version: '1.5'
              sensor:
                platform: mysensors
              switch:
                platform: mysensors
              • D drock1985
                Hi @martinhjelmare
                #define SV "1.0"
                #define CHILD_ID0 3
                #define CHILD_ID1 5
                          //0: All Dimmers
                          //1: LED 1
                          //2: LED 2
                H
                H
                humblehacker
                @drock1985
                It looks like we're trying to do similar things with HA and MYS... I've been working on a rotary encoder switch for colored lights (eg Limitlessled/HUE etc...) and had been trying to program it through MQTT. However, I just now noticed the LEDDIMMERwithROTARYENCODER sketch in the MySensors examples so I thought I might try using MYS instead of MQTT. Of course that leads right back to the lack of support for MYS Switches in HASS... Perhaps there's a solution for both of our problems if we use an MQTT Gateway instead? I've worked with MQTT and NodeRED before and it was pretty straight forward, but then again I've been having a much harder time understanding the way its implemented in HASS... So I might need to work with it some more before I can be of any help testing the MQTT MYS Gateway with HA...
                • H humblehacker
                  @drock1985
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @humblehacker
                  Hi!
                  I also want to try the MQTT gateway together with HA. MQTT support is well supported in HA, and looking at the MQTT protocol in mysensors dev branch it looks promising. I have just got some ethernet modules and more nanos, so as soon as I find some time, I'll get started. We can post our progress somewhere here whoever gets it going first.
                  • D
                    drock1985
                    wrote on last edited by drock1985
                    #36
                    @humblehacker @martinhjelmare
                    Sounds like an interesting idea to me. I have never used a MQTT gateway before, so i'm going in a little blind. I think I have the server so far (mosquitto) running on the same RPI as my HA install; so now looking into the next step.
                    One thing though, would this replace my current serial gateway, or be an addition to it?
                    My Projects
                    2 Door Chime Sensor
                    • D
                      drock1985
                      I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
                      #MySensors MQTT Test
                      mqtt 1:
                        broker: 192.168.86.198
                        port: 1883
                      #  client_id: home-assistant-1
                        keepalive: 60
                      #  username: USERNAME
                      #  password: PASSWORD
                      The Serial output from Arduino shows that I connected successfully
                      0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
                      0;0;3;0;9;Radio init successful.
                      IP: 192.168.86.112
                      0;0;3;0;9;MQTT connected
                      0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                      But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
                      15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
                      15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
                      Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
                      My Projects
                      2 Door Chime Sensor
                        Sorry, havent tried HomeAssistant myself.
                        • D
                          drock1985
                          Thanks @hek , had to ask :)
                          Would it be possible to get a Home-Assistant dedicated sub-forum please?
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            mqtt 1:
                              port: 1883
                              keepalive: 60
                            IP: 192.168.86.112
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @drock1985
                            What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
                              You got it.
                              http://forum.mysensors.org/category/28/home-assistant
                              • D
                                drock1985
                                #42
                                Thanks @hek very appreciated.
                                EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
                                Going to try the ESP8266MQTTGateway: I'm got a hunch.
                                My Projects
                                2 Door Chime Sensor
                                • D drock1985
                                  mqtt 1:
                                    port: 1883
                                    keepalive: 60
                                  IP: 192.168.86.112
                                  H
                                  H
                                  humblehacker
                                  wrote on last edited by humblehacker
                                  #43
                                  mqtt 1:
                                    port: 1883
                                    keepalive: 60
                                  Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
                                  D 1 Reply Last reply
                                  • H
                                    H
                                    humblehacker
                                    For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
                                    • H humblehacker
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @humblehacker
                                      FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
                                      H 1 Reply Last reply
                                        @humblehacker
                                        H
                                        H
                                        humblehacker
                                        @martinhjelmare said:
                                        @humblehacker
                                        Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
                                        • H humblehacker
                                          mqtt 1:
                                            port: 1883
                                            keepalive: 60
                                          drock1985
                                          @humblehacker said:
                                          k
                                          mqtt 1:
                                            port: 1883
                                            keepalive: 60
                                          @humblehacker
                                          The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                                          So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                                          My Projects
                                          2 Door Chime Sensor
                                          12.5k
