  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 54.8k Views 3 Watching
  • H humblehacker
    Sure enough-
    WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
    @martinhjelmare- How do I create a new gateway instance? Simply restart?
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @humblehacker
    If using home assistant, it's enough to restart home assistant, to get a new gateway instance and reconnect.
    • H
      H
      humblehacker
      :smiley:
      Other than the fact that my log seems to think its yesterday... I just need to find out why I can't use MySensors with Any ATMega32u4 devices... Attiny85/Trinket support would be nice too but I dont need to push my luck...
      • H humblehacker
        :smiley:
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @humblehacker
        :thumbsup:
        • K
          K
          kielnino
          I'm still stuck with the import of sensors to home-assitant. Can someone please post his configuration.yaml? I Wonder if I made a stupid configuration error there.
          Do I need the "inclusion mode" of the Gateway or does home-assistant handle the detection of new sensors? In the serial monitor all the communication between the nodes and the Gateway is looking good, but in home-assistant they won't show up.
          • K kielnino
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @kielnino
            Home assistant adds the new device after the sensor has presented itself to the gateway and sent at least one value. So proper presentation messages has to be sent by the node and received by the gateway. These include node id, sensor child id, sketch name and presentation "S_VALUE". Then one value should be sent using the correct "V_VALUE".
            See the mysensor API documentation for the S_VALUES and V_VALUES.
            See below for the sensors excerpt from my config. If you have multiple sensor platforms you need to increment the sensor name with a number: sensor, sensor 2, sensor 3, etc. All sensor platforms should be one continuing block in the config. Note that this is not my config for my github fork of home assistant. For that one, you need to add a separate domain in the config for mysensors.
            # SENSORS
            # Mysensors
            sensor:
              platform: mysensors
              port: "/dev/ttyUSB0"
            #  debug:
            # forecast.io
            sensor 2:
              platform: forecast
              api_key: ***censored***
              monitored_conditions:
                - summary
                - precip_type
                - precip_intensity
                - temperature
                - dew_point
                - wind_speed
                - wind_bearing
                - cloud_cover
                - humidity
                - pressure
                - visibility
                - ozone
            # time_date
            sensor 3:
              platform: time_date
              display_options:
                - 'time'
                - 'date'
                - 'date_time'
                - 'time_date'
                - 'time_utc'
                - 'beat'
            • D
              drock1985
              Hi @martinhjelmare
              Just wanted to first say thank you for the port of MySensors to Home-Assistant. I'm currently in the process of switching from Domoticz to Home-Assistant, and have a quick question about getting my node recognized.
              I have a Doorbell/Chome monitor, and it gets the ID from the gateway no problem. It shows up in HA after pressing the doorbell button (as a motion sensor, since that is the trigger) but I can't control the chime itself (aka, whether the bell rings if the door is pressed or not) which is set as a light switch.
              I know from reading this thread that in order for a device to first appear in HA, it must send a command to the gateway. Is there any way for me through HA to force a command to the childid light switch, so that it will show up on its own?
              My Projects
              2 Door Chime Sensor
              Washing Machine Monitor
              • D drock1985
                Hi @martinhjelmare
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                #29
                @drock1985
                Hi!
                First I'd just want to make clear that I'm not the original author or maintainer of pymysensors, which is the mysensors API that home assistant uses. I have just made some pull requests to pymysensors and I'd like to improve the functionality, if possible.
                To answer your question, mysensors switches are not yet supported in home assistant. That's what one of my pull requests want to solve, but it has yet to be merged. There is currently no way of forcing a node to resend it's presentation, if that info is lacking on the gateway side. This could be solved after version 1.6 of mysensors gets released but it will take more development, both on pymysensors and home assistant sides.
                If you want to make sure that the doorbell shows up in the GUI, before the first press of the button, just send the sensor value to the gateway, in the end of the setup function in your node sketch.
                For example, if you have defined a msgMotion for the doorbell:
                gw.send(msgMotion.set("0"));
                • D
                  drock1985
                  Hi @martinhjelmare
                  I decided to try this on a simplier sketch that I have, but still no luck. I added this line gw.send(lightMsgW.set("1")); to the end of void setup(). The sensor shows up at the top of the States screen in HA, but doesn't let me actually control it, and it doesn't show up in Switches or Lights.
                  Here is the sketch that I am using.
                   * Version 1.0 - 6-December-2015, Derrick Rockwell
                   *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
                   *can usually be found in most dollar stores/hardware stores and are
                   *battery powered. This sketch uses digital pins 3 and 4 to power two
                   *a string of lights each. Ex, one can control white lights the other
                   *could control multi-colour lights.
                  #define SN "HolidayLEDDeskLights"
                  #define SV "1.0"
                  #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
                  #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
                  #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                  #define CHILD_ID0 3
                  #define CHILD_ID1 5
                  static int currentLevelM = 0;  // Current dim level...
                  static int currentLevelW = 0;  // Current dim level...
                  MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
                  MyMessage lightMsgM(MLED_PIN, V_LIGHT);
                  MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
                  MyMessage lightMsgW(WLED_PIN, V_LIGHT);
                   * Dimmable LED initialization method
                    Serial.println( SN );
                    Serial.println( SV );
                    gw.begin( incomingMessage );
                    // Register the LED Dimmable Light with the gateway
                    gw.present( MLED_PIN, S_DIMMER );
                    gw.present( WLED_PIN, S_DIMMER );
                    gw.sendSketchInfo(SN, SV);
                    // Pull the gateway's current dim level - restore light level upon sendor node power-up
                    gw.request( MLED_PIN, V_DIMMER );
                    gw.request( WLED_PIN, V_DIMMER );
                   *  Dimmable LED main processing loop
                  //For Multi Coloured Lights
                  if (message.type == V_LIGHT || message.type == V_DIMMER) {
                        // if (message.sensor <= 2)
                            //0: All Dimmers
                            //1: LED 1
                            //2: LED 2
                            if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                              fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                              gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                              gw.send(dimmerMsgM.set(requestedLevel) );
                            if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                              fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                              gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                              gw.send(dimmerMsgW.set(requestedLevel) );
                   *  This method provides a graceful fade up/down effect
                   // For Multi Coloured Lights
                  void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
                    int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
                    while ( (*currentLevel) != toLevel ) {
                      (*currentLevel) += delta;
                      analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
                      delay( FADE_DELAY );
                  My Projects
                  2 Door Chime Sensor
                  martinhjelmareM H 2 Replies Last reply
                  • D drock1985
                    Hi @martinhjelmare
                    #define SV "1.0"
                    #define CHILD_ID0 3
                    #define CHILD_ID1 5
                              //0: All Dimmers
                              //1: LED 1
                              //2: LED 2
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @drock1985
                    As I wrote above, switches are not supported yet, in the default releases of home assistant. That support only exists in my personal branches at github.
                    • D
                      drock1985
                      @martinhjelmare
                      And how would I install your branch of home-assistant then so that I can use it?
                      My Projects
                      2 Door Chime Sensor
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #33
                        You can test it by cloning my fork of home-assistant (https://github.com/MartinHjelmare/home-assistant), then checkout my branch "mysensors-component-switch". Then install it with pip. See my console log below. BIG DISCLAIMER: This is work in progress and under development. You are cloning my branch, which is based off the home assistant dev branch, which is not a stable release.
                        martin@martin-htpc:~$ mkvirtualenv -p python3 testhomeass
                        Running virtualenv with interpreter /usr/bin/python3
                        Using base prefix '/usr'
                        New python executable in testhomeass/bin/python3
                        Also creating executable in testhomeass/bin/python
                        Installing setuptools, pip, wheel...done.
                        virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/predeactivate
                        virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postdeactivate
                        virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/preactivate
                        virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postactivate
                        virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/get_env_details
                        (testhomeass)martin@martin-htpc:~$ cd Dev/
                        (testhomeass)martin@martin-htpc:~/Dev$ mkdir testhomeass
                        (testhomeass)martin@martin-htpc:~/Dev$ cd testhomeass/
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ git clone git@github.com:MartinHjelmare/home-assistant.git
                        Klonar till "home-assistant"...
                        remote: Counting objects: 28876, done.
                        remote: Total 28876 (delta 0), reused 0 (delta 0), pack-reused 28876
                        Tar emot objekt: 100% (28876/28876), 25.45 MiB | 1.59 MiB/s, done.
                        Analyserar delta: 100% (19679/19679), done.
                        Kontrollerar anslutning... klart.
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ cd home-assistant/
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git status
                        På grenen dev
                        Din gren är à jour med "origin/dev".
                        inget att checka in, arbetskatalogen ren
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git checkout mysensors-component-switch
                        Grenen mysensors-component-switch ställdes in att spåra fjärrgrenen mysensors-component-switch från origin.
                        Växlade till en ny gren "mysensors-component-switch"
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ pip install .
                        Processing /home/martin/Dev/testhomeass/home-assistant
                        Collecting requests<3,>=2 (from homeassistant==0.9.0.dev0)
                          Using cached requests-2.8.1-py2.py3-none-any.whl
                        Collecting pyyaml<4,>=3.11 (from homeassistant==0.9.0.dev0)
                        Collecting pytz>=2015.4 (from homeassistant==0.9.0.dev0)
                          Using cached pytz-2015.7-py2.py3-none-any.whl
                        Requirement already satisfied (use --upgrade to upgrade): pip>=7.0.0 in /home/martin/.virtualenvs/testhomeass/lib/python3.4/site-packages (from homeassistant==0.9.0.dev0)
                        Collecting vincenty==0.1.3 (from homeassistant==0.9.0.dev0)
                        Building wheels for collected packages: homeassistant
                          Running setup.py bdist_wheel for homeassistant
                          Stored in directory: /home/martin/.cache/pip/wheels/0d/98/ff/ecb5c632258e50fbc91b535762865e4a132eb966f5c28f00d7
                        Successfully built homeassistant
                        Installing collected packages: requests, pyyaml, pytz, vincenty, homeassistant
                        Successfully installed homeassistant-0.9.0.dev0 pytz-2015.7 pyyaml-3.11 requests-2.8.1 vincenty-0.1.3
                        (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ hass
                        Config directory: /home/martin/.homeassistant
                        WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
                        INFO:homeassistant.bootstrap:Home Assistant core initialized
                        INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
                        INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                        INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                        INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                        INFO:homeassistant.loader:Loaded notify from homeassistant.components.notify
                        INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                        INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                        INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                        INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                        INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                        INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                        INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
                        INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                        INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
                        INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                        INFO:homeassistant.components.introduction:
                                Hello, and welcome to Home Assistant!
                                We'll hope that we can make all your dreams come true.
                                Here are some resources to get started:
                                 - Configuring Home Assistant:
                                   https://home-assistant.io/getting-started/configuration/
                                 - Available components:
                                   https://home-assistant.io/components/
                                 - Troubleshooting your configuration:
                                   https://home-assistant.io/getting-started/troubleshooting-configuration/
                                 - Getting help:
                                   https://home-assistant.io/help/
                                This message is generated by the introduction component. You can
                                disable it in configuration.yaml.
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                        INFO:homeassistant.loader:Loaded notify.telegram from homeassistant.components.notify.telegram
                        INFO:homeassistant.util.package:Attempting install of python-telegram-bot==2.8.7
                        INFO:homeassistant.components.notify.telegram:Telegram bot is '***censored***'.
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=telegram, domain=notify>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=notify>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                        INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                        INFO:homeassistant.util.package:Attempting install of https://github.com/MartinHjelmare/pymysensors/archive/fifo_queue.zip#pymysensors==0.3
                        INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                        INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group>
                        INFO:homeassistant.loader:Loaded automation.state from homeassistant.components.automation.state
                        INFO:homeassistant.components.automation:Initialized rule Rule 1 - Door bell pressed
                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=automation>
                        INFO:homeassistant.core:Starting Home Assistant (16 threads)
                        INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
                        INFO:homeassistant.components.mysensors:update persistence: node 1
                        INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=, update_type=persistence, node_id=1>
                        INFO:homeassistant.components.mysensors:adding new devices: [<Entity Sensebender Micro Bell 1.1: >, <Entity Sensebender Micro Bell 1.2: >, <Entity Sensebender Micro Bell 1.199: >]
                        INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                        INFO:homeassistant.core:Timer:starting
                        INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, update_type=persistence, node_id=1>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, new_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
                        INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.1: value_type 0, value = 21.0
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, new_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, old_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; battery_level=100, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
                        INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.2: value_type 1, value = 34
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, old_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; battery_level=100, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
                        INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.199: value_type 38, value = 3160
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, new_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, old_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=3160; battery_level=100, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
                        INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                        INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                        ^CINFO:homeassistant.core:Stopping
                        INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                        INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                        INFO:mysensors.mysensors:Stopping thread
                        INFO:homeassistant.components.recorder:Closing database
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                 - Getting help:
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=notify, service=telegram>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                        INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=, port=/dev/ttyUSB0, node_id=1>
                        INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, port=/dev/ttyUSB0, node_id=1>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; child_id=1, unit_of_measurement=°C, battery_level=100, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; child_id=2, unit_of_measurement=%, battery_level=100, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=; child_id=199, unit_of_measurement=V, battery_level=0, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                        You can see that I get a warning about bad byte, after first start. I solve this by restarting hass.
                        Your home assistant config for mysensors should now be structured like this:
                        mysensors:
                          port:
                            - '/dev/ttyUSB0'
                          #  - '/dev/ttyACM0'
                          debug: true
                          persistence: true
                          persistence_file:
                            - '/home/martin/.homeassistant/mysensors.json'
                          #  - '/home/martin/.homeassistant/mysensors2.json'
                          version: '1.5'
                        sensor:
                          platform: mysensors
                        switch:
                          platform: mysensors
                        • D drock1985
                          Hi @martinhjelmare
                          #define SV "1.0"
                          #define CHILD_ID0 3
                          #define CHILD_ID1 5
                                    //0: All Dimmers
                                    //1: LED 1
                                    //2: LED 2
                          H
                          H
                          humblehacker
                          @drock1985
                          It looks like we're trying to do similar things with HA and MYS... I've been working on a rotary encoder switch for colored lights (eg Limitlessled/HUE etc...) and had been trying to program it through MQTT. However, I just now noticed the LEDDIMMERwithROTARYENCODER sketch in the MySensors examples so I thought I might try using MYS instead of MQTT. Of course that leads right back to the lack of support for MYS Switches in HASS... Perhaps there's a solution for both of our problems if we use an MQTT Gateway instead? I've worked with MQTT and NodeRED before and it was pretty straight forward, but then again I've been having a much harder time understanding the way its implemented in HASS... So I might need to work with it some more before I can be of any help testing the MQTT MYS Gateway with HA...
                          • H humblehacker
                            @drock1985
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @humblehacker
                            Hi!
                            I also want to try the MQTT gateway together with HA. MQTT support is well supported in HA, and looking at the MQTT protocol in mysensors dev branch it looks promising. I have just got some ethernet modules and more nanos, so as soon as I find some time, I'll get started. We can post our progress somewhere here whoever gets it going first.
                            • D
                              drock1985
                              wrote on last edited by drock1985
                              #36
                              @humblehacker @martinhjelmare
                              Sounds like an interesting idea to me. I have never used a MQTT gateway before, so i'm going in a little blind. I think I have the server so far (mosquitto) running on the same RPI as my HA install; so now looking into the next step.
                              One thing though, would this replace my current serial gateway, or be an addition to it?
                              My Projects
                              2 Door Chime Sensor
                              • D
                                drock1985
                                I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
                                #MySensors MQTT Test
                                mqtt 1:
                                  broker: 192.168.86.198
                                  port: 1883
                                #  client_id: home-assistant-1
                                  keepalive: 60
                                #  username: USERNAME
                                #  password: PASSWORD
                                The Serial output from Arduino shows that I connected successfully
                                0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
                                0;0;3;0;9;Radio init successful.
                                IP: 192.168.86.112
                                0;0;3;0;9;MQTT connected
                                0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                                But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
                                15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
                                15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
                                Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
                                My Projects
                                2 Door Chime Sensor
                                  Sorry, havent tried HomeAssistant myself.
                                  • D
                                    drock1985
                                    Thanks @hek , had to ask :)
                                    Would it be possible to get a Home-Assistant dedicated sub-forum please?
                                    My Projects
                                    2 Door Chime Sensor
                                    • D drock1985
                                      mqtt 1:
                                        port: 1883
                                        keepalive: 60
                                      IP: 192.168.86.112
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
                                        You got it.
                                        http://forum.mysensors.org/category/28/home-assistant
                                        • D
                                          drock1985
                                          #42
                                          Thanks @hek very appreciated.
                                          EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
                                          Going to try the ESP8266MQTTGateway: I'm got a hunch.
                                          My Projects
                                          2 Door Chime Sensor
