  3. My Relay Module
My Relay Module
21 Posts 8 Posters 27.1k Views 6 Watching
  • N NotYetRated
    Very nice write up! Next add some current sensing ability to see what your load is pulling. :) Although if used for lighting, mostly negligible I suppose haha.
    gigiG
    gigiG
    gigi
    A non invasive sensor would be ideal. I alredy use energimonitor for solar panels!!!!!
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    • N
      N
      Nicola Reina
      Bello GiGi! Nice GiGi.
      If you want pm me as I understand we are from the same country.
      May be we can exchange some experience in italian ;-)
      Will copy your design
      gigiG 1 Reply Last reply
      • N Nicola Reina
        gigiG
        gigiG
        gigi
        @Nicola-Reina Ok
        • J
          J
          jemish
          if we put this box in wall then power supply will safe or not?
          5v power supply adapter's temperature will afact or not?
          • D
            dayve218
            any one care to confirm whats happening with the AC wires in this? i cant quite make it out from the photos
            • Michel - ItM
              Michel - ItM
              Michel - It
              Hello everyone , I have a problem . maybe it's stupid , I have a server with raspberry domoticz , I downloaded code, but by the following errorCattura.PNG
                You seem to have downloaded the development branch of the MySensors library. The code you're trying to run is 1.5.
                • Michel - ItM
                  Michel - ItM
                  Michel - It
                  wrote on last edited by Michel - It
                  I downloaded this , https://github.com/mysensors/Arduino . I Submitted libraries entirely within the zip file in my briefcase Arduino library.
                  however it from the library is the 1.5 readme. Where am I wrong ?
                  il codice è il seguente
                  #define RELAY_PIN 4 // Arduino Digital I/O pin number for relay
                  #define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
                  #define CHILD_ID 1 // Id of the sensor child
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  Bounce debouncer = Bounce();
                  int oldValue=0;
                  bool state;
                  gw.sendSketchInfo("Relay & Button", "1.0");
                  // Setup the button
                  pinMode(BUTTON_PIN,INPUT);
                  // Activate internal pull-up
                  debouncer.attach(BUTTON_PIN);
                  debouncer.interval(5);
                  gw.present(CHILD_ID, S_LIGHT);
                  pinMode(RELAY_PIN, OUTPUT);
                  state = gw.loadState(CHILD_ID);
                  * Example on how to asynchronously check for new messages from gw
                  debouncer.update();
                  // Get the update value
                  int value = debouncer.read();
                  if (value != oldValue && value==0) {
                  gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                  oldValue = value;
                  if (message.isAck()) {
                  // Change relay state
                  state = message.getBool();
                  // Store state in eeprom
                  gw.saveState(CHILD_ID, state);
                    mysensors.org/download/
                    • Michel - ItM
                      Michel - ItM
                      Michel - It
                      thank you! I apologize for my level , I hope to fix with your help.
                      • Michel - ItM
                        Michel - ItM
                        Michel - It
                        Here is the improved code that I used on my Arduino Mega to create a home automation controller
                        New optimized code to arduino mega
                        https://codebender.cc/sketch:206446
                        • Michel - ItM
                          Michel - ItM
                          Michel - It
                          Update: Forget it, the code works with Arduino Mini and 2 relay. I tried one after the code of Arduino Mega and not working. Something wrong but I do not know what I require help
                          I found mistakes on Arduino Mega solvable at the following link
                          http://forum.mysensors.org/topic/2161/the-mysensor-1-5-code-is-not-compiling-for-my-arduino-mega-2560-board/1
                          but I do not have this kind of problem you can get support? I connected NRF24L01 to Arduino Mega, as if it were an Arduino Nano, right?
                            The SPI pins has different pin numbers on the Mega.
                            Here is an example that runs the the Mega:
                            http://www.mysensors.org/build/scene_controller
                            • Michel - ItM
                              Michel - ItM
                              Michel - It
                              I connected the radio module as follows
                              AtMega 2650 Arduino Step Down Module/Radio
                              GND > GND
                              5V > Step Down module VCC
                              14 > SCK
                              15 > MOSI
                              16 > MISO
                              17 > CE
                              18 > CSN
                              I tried but it did not work I tried to connect also IrQ
                              2 > IRQ
                              it did not work. I tried to connect to 3v3 with the capacitor. it did not work. I tried adding the line in the code
                              #include <MyTransportNRF24.h>
                              #include <MyHwATMega328.h>
                              but to no avail. I am groping in the dark
                                You haven't said what problem you experience. Logs or anything else...
                                • Michel - ItM
                                  Michel - ItM
                                  Michel - It
                                  I have "check wires" error on the serial arduino....
                                  where do I fit in debug mode there is a guide?
                                  I saw a video that uses MQTT program on mac.
                                  I have downloaded windows MYSController I can be of help? How do I connect my PC? It is all new and are a little confused. :dizzy_face: :u7a7a:
                                  I "atmega adk" is a problem?
                                  https://www.arduino.cc/en/uploads/Main/ArduinoADK_R3_Front_450px.jpg
                                  • P
                                    P
                                    pjr
                                    Have you defined using softspi since using those pins?
                                    I'm using different pins with mega and everything started to work after adding capacitor to radio:
                                    GND > GND
                                    3.3 > VCC
                                    52 > SCK
                                    51 > MOSI
                                    50 > MISO
                                    9 > CE
                                    10 > CSN
                                    2 > IRQ
                                    • Michel - ItM
                                      Michel - ItM
                                      Michel - It
                                      #21
                                      soon as I finish the project it will create a new post in the category myproject
                                      @pjr unfortunately I read your seat now but I confirm that pins are those that use exact thank - @salvato that helped me as an angel.
                                      the irq pin does not need to be connected
