  3. My Relay Module
My Relay Module
21 Posts 8 Posters 27.2k Views 6 Watching
    You seem to have downloaded the development branch of the MySensors library. The code you're trying to run is 1.5.
    • Michel - ItM
      Michel - ItM
      Michel - It
      wrote on last edited by Michel - It
      I downloaded this , https://github.com/mysensors/Arduino . I Submitted libraries entirely within the zip file in my briefcase Arduino library.
      however it from the library is the 1.5 readme. Where am I wrong ?
      il codice è il seguente
      #define RELAY_PIN 4 // Arduino Digital I/O pin number for relay
      #define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
      #define CHILD_ID 1 // Id of the sensor child
      #define RELAY_ON 1
      #define RELAY_OFF 0
      Bounce debouncer = Bounce();
      int oldValue=0;
      bool state;
      gw.sendSketchInfo("Relay & Button", "1.0");
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
      * Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
      gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
      // Change relay state
      state = message.getBool();
      // Store state in eeprom
      gw.saveState(CHILD_ID, state);
        mysensors.org/download/
        • Michel - ItM
          Michel - ItM
          Michel - It
          thank you! I apologize for my level , I hope to fix with your help.
          • Michel - ItM
            Michel - ItM
            Michel - It
            Here is the improved code that I used on my Arduino Mega to create a home automation controller
            New optimized code to arduino mega
            https://codebender.cc/sketch:206446
            • Michel - ItM
              Michel - ItM
              Michel - It
              Update: Forget it, the code works with Arduino Mini and 2 relay. I tried one after the code of Arduino Mega and not working. Something wrong but I do not know what I require help
              I found mistakes on Arduino Mega solvable at the following link
              http://forum.mysensors.org/topic/2161/the-mysensor-1-5-code-is-not-compiling-for-my-arduino-mega-2560-board/1
              but I do not have this kind of problem you can get support? I connected NRF24L01 to Arduino Mega, as if it were an Arduino Nano, right?
                The SPI pins has different pin numbers on the Mega.
                Here is an example that runs the the Mega:
                http://www.mysensors.org/build/scene_controller
                • Michel - ItM
                  Michel - ItM
                  Michel - It
                  I connected the radio module as follows
                  AtMega 2650 Arduino Step Down Module/Radio
                  GND > GND
                  5V > Step Down module VCC
                  14 > SCK
                  15 > MOSI
                  16 > MISO
                  17 > CE
                  18 > CSN
                  I tried but it did not work I tried to connect also IrQ
                  2 > IRQ
                  it did not work. I tried to connect to 3v3 with the capacitor. it did not work. I tried adding the line in the code
                  #include <MyTransportNRF24.h>
                  #include <MyHwATMega328.h>
                  but to no avail. I am groping in the dark
                    You haven't said what problem you experience. Logs or anything else...
                    • Michel - ItM
                      Michel - ItM
                      Michel - It
                      I have "check wires" error on the serial arduino....
                      where do I fit in debug mode there is a guide?
                      I saw a video that uses MQTT program on mac.
                      I have downloaded windows MYSController I can be of help? How do I connect my PC? It is all new and are a little confused. :dizzy_face: :u7a7a:
                      I "atmega adk" is a problem?
                      https://www.arduino.cc/en/uploads/Main/ArduinoADK_R3_Front_450px.jpg
                      • P
                        P
                        pjr
                        Have you defined using softspi since using those pins?
                        I'm using different pins with mega and everything started to work after adding capacitor to radio:
                        GND > GND
                        3.3 > VCC
                        52 > SCK
                        51 > MOSI
                        50 > MISO
                        9 > CE
                        10 > CSN
                        2 > IRQ
                        • Michel - ItM
                          Michel - ItM
                          Michel - It
                          #21
                          soon as I finish the project it will create a new post in the category myproject
                          @pjr unfortunately I read your seat now but I confirm that pins are those that use exact thank - @salvato that helped me as an angel.
                          the irq pin does not need to be connected
