  3. Wireless nRF24L01+ sniffer for MySensors
omgsnifferwiresharknrf24l01+
108 Posts 19 Posters 98.8k Views 18 Watching
  • YveauxY Yveaux
    @marceltrapman said:
    1. Once Wireshark was started like described I noticed that the Nrf24Sniff console window displayed a *'Wait for sniffer to restart' *message. The author mentions that this will only take a few seconds but in my case I actually needed to reset the Arduino for it to go away. No exception.
    I changed the nrf24snif.exe to explicitly reset the Arduino (works for Uno) by lowering DTR/RTS lines. Should work for (most?) other Arduino's too, but I don't have any other to test one.
    For me it seems to work now. Could you test if this works stable for you too?
    Oh yeah, I added support for some status leds to the Sniffer, connected to A0..A4 and via resistors to GND:
    • A0 sniffer monitoring (LED turns off during reset)
    • A1 sniffer receiving a packet
    • A2 sniffer transmitting (serially) a packet
    • A3 new configuration received
    • A4 buffer overflow
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    wrote on last edited by marceltrapman
    #42
    @Yveaux
    Maybe I should create a (little) shield for this that holds the radio as well.
    Or just use a prototype board...
    Fulltime Servoy Developer
      @Yveaux
      @marceltrapman Maybe all of the LEDs are a bit overkill, but the RX LED and maybe the buffer-full LED can seriously be handy.
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        I only checked the UNO with the new sketch (no LEDs) and the new iteration of nrf24snif.exe and both work as expected...
        @Yveaux Well done again!
          Everything works now.
          Did not see any packets coming in though but I remember having an issue with a couple of Uno's and I am not sure if this was one of them.
          Anyway, I will do some more testing tomorrow.
          Very exited :)
          #45
          @marceltrapman And? How did the testing go?
          I fixed the Nrf24sniff.exe to use static linking so the msvcr110.dll should no longer be required.
          Also fixed executable so it runs on WinXP now (untested...).
          marceltrapmanM 2 Replies Last reply
          • YveauxY Yveaux
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @Yveaux To be honest, I have played with it a little but I have not come much further.
            Spent my time this weekend on other things :)
            Will let you know soon!
            • R
              R
              Rasmus Eneman
              Could the line quality information be queried directly by the gateway so that it can be known without additional hardware?
              • R Rasmus Eneman
                @Rasmus-Eneman no, the nrf24 does not expose it. You can query the amount of retries it took before a message got an acknowledgement, which could be used as quality indication.
                • R
                  R
                  Rasmus Eneman
                  @Yveaux Okej, Thank You!
                  • YveauxY Yveaux
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    #50
                    So, testing went well :)
                    I found a couple of malformed packets coming in so I will have to investigate that.
                    Yesterday evening I created my first shield, first double sided board and in fact the first true 'home brew' pcb in my entire life...
                    This is what it looks like (it is a bit of a mess because I messed up my via's the first time...
                      #51
                      @marceltrapman Wooow! First 'official' sniffer PCB! :+1: (did you give it an oldskool look? looks 50 years+ old :-)
                      Great it worked out that well!
                      In my experience there are always some malformed packets, nothing to worry about.
                      • YveauxY Yveaux
                        Ok, brace yourself! :zap:
                        I finally had the time to write on my blog about the wireless network sniffer I've been working on lately.
                        For the impatient see:
                        • http://yveaux.blogspot.nl/2014/07/nrf24l01-sniffer-part-1.html
                        • http://yveaux.blogspot.nl/2014/07/nrf24l01-sniffer-part-2.html
                        • http://yveaux.blogspot.nl/2014/07/nrf24l01-sniffer-part-3.html
                        This wireless sniffer allows you to capture traffic on air between multiple nodes of your MySensors network and is able to even capture packets with invalid CRC Values. The amount of CRC errors gives a fair indication of link quality, which is not provided by the nRF24.
                        The sniffer in action:
                        http://www.youtube.com/embed/wxjxm0LnkAk
                        Actual capturing is performed by an nRF24L01+ module connected to an Arduino (we all known how to do that ;-) ). No other hardware is required.
                        A small piece of software (currently only for Windows, sorry @hek) reads the packet data from the sniffer and forwards it to Wireshark, a network protocol analyzer.
                        Wireshark then allows you to inspect the packages from high-level down to the individual bits, filter by content, and analyze statistics.
                        Details are all in the blog posts. Last post in this series, which is yet to be written, will dive into using Wireshark and getting useful information from it.
                        I didn't want to keep this tool to myself until finally finished and documented, so there can (will?) still be some bugs left...
                        Please discuss any issues/ideas/suggestions in here or in my blog.
                        Happy sniffin' to all of you!
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        • YveauxY Yveaux
                          marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          @Yveaux It is a combination of the board color (it really is a bit 'greenish') the green matte, daylight gone and the flash light :)
                          I am pretty content with it except that I need to think about those via's next time as well as using flux.
                          Any idea where those malformed packets come from?
                          YveauxY 2 Replies Last reply
                            @marceltrapman try to combine vias with through hole components. E.g a resistor write can bring you to the other side of the board.
                            Or just make the board single sided. Should be doable for such a board and it is also easier to construct.
                            I switched to smd primarily to prevent drilling and reduce board space...
                            Just a matter of taste/laziness :)
                              #55
                              I guess it's just inherent to wireless traffic. The same reason why a Wi-Fi connection gives different rates all of the time.
                              It's just a hunch, I didn't really dive into it.
                              Using the sniffer we could also get some real figures on e.g. the capacitor fix. It all can make a difference but as long as you cannot measure objectively it is all guessing...
                              • YveauxY Yveaux
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                I know and I did that with the LED's but with a header that is more difficult.
                                I am sure but I did not want to do that. This also was a learning project for me :)
                                I am going to do that as well but I wanted to do one step at a time...
                                Thanks for your advice, much appreciated!!!
                                  Hackaday! Congrats.
                                  http://hackaday.com/2014/08/05/sniffing-nrf24l01-traffic-with-wireshark/
                                    Hackaday! Congrats.
                                    #58
                                    @hek wow! Thanks for the tip!
                                    Hope this will also boost mysensors popularity!
                                    Over 1000 hits on my blog in half a day! Wow!
                                    • YveauxY
                                      Updated the sniffer's Wireshark dissectors to MySensors 1.4b protocol version of Aug 18, 2014.
                                      Please update the **mysensors2.dll **when you update to this 1.4b version.
                                      SparkmanS 1 Reply Last reply
                                      • YveauxY Yveaux
                                        SparkmanS
                                        SparkmanS
                                        Sparkman
                                        wrote on last edited by Sparkman
                                        #60
                                        @Yveaux Thanks for putting this together. I'm trying it out today and seem to have everything running properly and without errors, but it's not capturing any packets. Can I just run nrf24sniff with all default parameters (other than the com port) for the current 1.4 release, or do I need to change some of them? I haven't made any changes to the default mysensor settings such as channel and data rate. I'm running it on a Mega, but have tested the radio, etc. using the BinarySwitchSensor sketch and it's communicating properly to my gateway/controller.
                                        Al
                                        • SparkmanS Sparkman
                                          Al
                                          @Sparkman Even if the MySensors protocol changed w.r.t. the version supported by the sniffer you should still be able to capture raw nRF24 packets on air. Only the MySensors dissection could fail in this case.
                                          You should double check the values of DEFAULT_RF_CHANNEL, DEFAULT_RF_DATARATE and DEFAULT_RADIO_ID in NRF24_sniff.ino.
                                          They should match the MySensors configuration from MyConfig.h: RF24_CHANNEL, RF24_DATARATE and BASE_RADIO_ID.
                                          The MySensors default datarate has gone down from 1Mbps to 25Kbps, so I would expect the DEFAULT_RF_DATARATE in the sniffer causes the malfunction.
                                          The SPI/pin settings for the radio connection could also be different on your Mega. The sniffer only supports hardware SPI. Other pins are configured in the same NRF24_sniff.ino:
                                              #define RF_CE_PIN                      (9)
                                              #define RF_CS_PIN                      (10)
                                              #define RF_IRQ_PIN                     (2)
                                              #define RF_IRQ                         (RF_IRQ_PIN-2)
                                          Also, the sniffer uses interrupts for quick response to new messages, so make sure the IRQ pin is connected between the Mega and the nRF24 (MySensors doesn't use) !
                                          To rule out any issues caused by the Mega, could you test the sniffer using a regular Uno?
                                          Good luck!
