  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
    How did thinks go @Lars65 ?
    I thought a bit more about this problem and I think I have come up with a pretty neat solution:
    Throw away the chip on the moisture sensor and connect the "pitchfork" directly to the Arduino. Connect one prong to GND and one prong to an analog pin. No power pins are required.
    https://codebender.cc/sketch:177182
    The chip on the moisture sensor is basically a voltage divider. We get the same thing if we use the internal pull-up resistor on the Atmega processor.
    EDIT: This means you can buy just the "pitchforks" really cheap: http://www.aliexpress.com/item/10pcs-Soil-Hygrometer-Detection-Module-Soil-Moisture-Sensor-Probes/2051713873.html
    damien
    Hi @mfalkvidd and thank you very very much for your new version of the skecth for moisture sensors, its very clever ! i will test it as soon as possible
    • mfalkviddM
      @Nicklas-Starkel last weekend one of my sensors broke. Both pins were completely corroded and broke just where I connect the dupont wires. I think I will use hot glue to protect the connectors, but I have also added alternating power to my single-sensor sketch. I have this sketch running on three sensors now.
      https://codebender.cc/sketch:158460
      R Pierre PP 2 Replies Last reply
        memheli
        Newbie to controllers. I'd been looking at PanStamp for this project, and came across your post from Google. This would be my first project w/ micro controllers. How is this tied to the internet for reporting?
        • mfalkviddM
          In MySensors lingo, the Arduino is called a sensor. The part that MySensors calls a controller runs on a "real" computer, and gets information from the sensors. The controller usually handles reporting. The documentation at http://www.mysensors.org/about/network can probably give you a good overview.
          • m26872M
            m26872M
            m26872
            Just some ideas to the corrosion issue (any photos?). If both pins were corroded, it may not be sufficient with polarity switching. Perhaps a simple active cathodic protection system could help. E.g. a +wire limited to a few uA and wrapped with some aluminium foil in the soil near the sensor?
            I haven't yet got to it, but the plant monitoring is on pretty high on my list.
            • m26872M m26872
              @m26872 said:
              (any photos?)
              m26872M 1 Reply Last reply
                R
                R
                rajbadri
                @mfalkvidd
                i am using your sketch for indoor plant monitoring but have modified the sleep time to one hour . the problem i am facing is that every alternate humidity reading i get is a 0
                like
                first reading ------ 67%
                second reading ----- 0%
                third reading ------65%
                fourth reading ------- 0%
                and likewise
                Please Guide
                • R rajbadri
                  @mfalkvidd
                  like
                  and likewise
                  Please Guide
                  @rajbadri which pins are your sensor connected to?
                  R 3 Replies Last reply
                  • D
                    doblanch
                    I'm on the same project personally...I using 2 battery... this part should work between 3.3 V and 5V...
                    finally with 2XAA we only have 3V, and the max value for me is 750 not 1023... did you get 1023 when into the water?
                    I use a gold plated sensor, and the plug will be into a seal to avoid corrosion and water to go in.
                    I use a sensbender where I connected on A3 the pin use for the soil moisture sensor.
                    Could you confirm that change the polarity help to avoid corrosion ???
                    thanks
                    mfalkviddM F 3 Replies Last reply
                    • D doblanch
                      thanks
                      thanks
                      No I can not. All my sensors change the polarity, so I can't tell if there is a difference. You'll have to experiment.
                      D 2 Replies Last reply
                      • D doblanch
                        thanks
                        #34
                        I haven't tried in water. I don't care about the absolute value, I just note the reading when the plant needs watering and set a notification for that level. One of my plants needs water at about 70%, another at about 5%. It will vary wildly between different plant types, climate and soil composition.
                        The value for water will probably vary as well, depending on the water. Distilled water, rain water, tap water, salt water will all have different resistance.
                        And the value will vary depending on temperature and different Arduinos since the pull-up resistor is inexact.
                          thanks
                          doblanch
                          @mfalkvidd ok ; thanks I willl try :-)
                            thanks
                            doblanch
                            @mfalkvidd not false :-) I have to make some tries also. I bought a gold platined sensor, I hope that corrosion will be less...
                              @m26872 said:
                              (any photos?)
                              m26872M
                              m26872M
                              m26872
                              @mfalkvidd Thanks for sharing! By looking at your corrosion photos I'd guess galvanic corrosion of pin header.
                              I think I'll solder my wires instead and put some sealing paint and/or hot glue over it. Polarity switch won't harm, but I'll wait with the cathodic protection for now.
                                R
                                R
                                rajbadri
                                @mfalkvidd
                                its on analog pin A0
                                  R
                                  R
                                  rajbadri
                                  @mfalkvidd
                                  i have now connected two analog pins A0 and A1 of Pro Mini to the A0 pin of the soil sensor and now i am getting a constant reading of 98% humidity (in water or outside dry).
                                  please guide
                                    R
                                    R
                                    rajbadri
                                    @mfalkvidd
                                    this is how i have connected
                                    • mfalkviddM
                                      #41
                                      To use the sketch with reverse polarity you need to connect + and - on the prong to A0 and A1 on the Arduino. The chip in the middle is not used.
                                      R 1 Reply Last reply
                                        R
                                        R
                                        rajbadri
                                        @mfalkvidd
                                        ok will try
                                          Pierre PP
                                          Pierre PP
                                          Pierre P
                                          wrote on last edited by Pierre P
                                          #43
                                          Did you try to just paint the sensors ?
                                          I've seen that here: https://www.tindie.com/products/miceuz/i2c-soil-moisture-sensor/
                                          It doesn't work for me. I go double check the wiring. EDIT: not it's okay now. Great !
                                          But is it possible to use A0-A1, A2-A3, A4-A5 on a atmega328P or there is the same pullup problem ?
                                          No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
                                          S 1 Reply Last reply
