  3. Sensor NRF24L01+ sleep current
16 Posts 5 Posters 8.9k Views 3 Watching
  • F Offline
    F Offline
    flopp
    wrote on last edited by flopp
    Hi I just finished my first MySensor setup.
    Everything is working but the uA(micro) for the NRF24L01+ is confusing me.
    I am using a Arduino Nano ATmega328(clone), removed LED and power regulator.
    Maybe to much information: I wake Arduino after 60 seconds and send the data to my Serial gateway. For controller I am using Domoticz.
    I have a BMP180 sensor for pressure and temperature.
    When my arduino is going to sleep it consume ~75uA when I remove 3.3V for the NRF it goes down to ~15uA.
    1. Shouldn't the NRF draw ~0,900 uA when sleeping?
    2. Is there any way to change the sleep mode for NRF? How?
    Any comment is welcome, if you found other error in my code.
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #include <Adafruit_BMP085.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define BATT_CHILD 2
    const float ALTITUDE = 8; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    	STABLE = 0,			// "Stable Weather Pattern"
    	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
    	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
    	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
    	UNKNOWN = 5			// "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    int oldBatteryPcnt = 0;
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    	gw.begin();
    	gw.sendSketchInfo("Pressure Sensor", "1.1");
    	if (!bmp.begin())
    		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    		while (1) {}
    	// Register sensors to gw (they will be created as child devices)
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
      gw.present(BATT_CHILD, S_MULTIMETER);
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
    	float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    	float temperature = bmp.readTemperature();
    	if (!metric)
    		// Convert to fahrenheit
    		temperature = temperature * 9.0 / 5.0 + 32.0;
    	int forecast = sample(pressure);
    	Serial.print("Temperature = ");
    	Serial.print(temperature);
    	Serial.println(metric ? " *C" : " *F");
    	Serial.print("Pressure = ");
    	Serial.print(pressure);
    	Serial.println(" hPa");
    	Serial.print("Forecast = ");
    	if (temperature != lastTemp)
    		gw.send(tempMsg.set(temperature, 1));
    		lastTemp = temperature;
    	if (pressure != lastPressure)
    		gw.send(pressureMsg.set(pressure, 1));
    		lastPressure = pressure;
    	if (forecast != lastForecast)
    		gw.send(forecastMsg.set(weather[forecast]));
    		lastForecast = forecast;
      //if (oldBatteryPcnt != batteryPcnt) {
       // Power up radio after sleep
       //gw.sendBatteryLevel(batteryPcnt);
       gw.send(battMsg.set(batteryV, 3));
       oldBatteryPcnt = batteryPcnt;
    	gw.sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
    	float lastPressureSamplesAverage = 0;
    	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
    		lastPressureSamplesAverage += lastPressureSamples[i];
    	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
    	return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
    	// Calculate the average of the last n minutes.
    	int index = minuteCount % LAST_SAMPLES_COUNT;
    	lastPressureSamples[index] = pressure;
    	minuteCount++;
    	if (minuteCount > 185)
    		minuteCount = 6;
    	if (minuteCount == 5)
    		pressureAvg = getLastPressureSamplesAverage();
    	else if (minuteCount == 35)
    		float lastPressureAvg = getLastPressureSamplesAverage();
    		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
    			dP_dt = change * 2; // note this is for t = 0.5hour
    			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
    	else if (minuteCount == 65)
    			dP_dt = change; //note this is for t = 1 hour
    			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
    	else if (minuteCount == 95)
    			dP_dt = change / 1.5; // note this is for t = 1.5 hour
    			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
    	else if (minuteCount == 125)
    		pressureAvg2 = lastPressureAvg; // store for later use.
    			dP_dt = change / 2; // note this is for t = 2 hour
    			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
    	else if (minuteCount == 155)
    			dP_dt = change / 2.5; // note this is for t = 2.5 hour
    			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
    	else if (minuteCount == 185)
    			dP_dt = change / 3; // note this is for t = 3 hour
    			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
    		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    	int forecast = UNKNOWN;
    		forecast = UNKNOWN;
    	else if (dP_dt < (-0.25))
    		forecast = THUNDERSTORM;
    	else if (dP_dt > 0.25)
    		forecast = UNSTABLE;
    		forecast = CLOUDY;
    		forecast = SUNNY;
    	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
    		forecast = STABLE;
    		forecast = UNKNOWN;
    	// uncomment when debugging
    	//Serial.print(F("Forecast at minute "));
    	//Serial.print(minuteCount);
    	//Serial.print(F(" dP/dt = "));
    	//Serial.print(dP_dt);
    	//Serial.print(F("kPa/h --> "));
    	return forecast;
    • F flopp
      enum FORECAST
      float pressureAvg;
      float pressureAvg2;
      float dP_dt;
      boolean metric;
      	gw.begin();
      	if (!bmp.begin())
      		while (1) {}
         #ifdef DEBUG
         #ifdef DEBUG
      	if (!metric)
      	minuteCount++;
      		minuteCount = 6;
      		forecast = UNKNOWN;
      		forecast = CLOUDY;
      		forecast = SUNNY;
      		forecast = STABLE;
      		forecast = UNKNOWN;
      	return forecast;
      YveauxY Offline
      YveauxY Offline
      @flopp How do you measure the small sleep currents?
      F 1 Reply Last reply
      • YveauxY Yveaux
        F Offline
        F Offline
        flopp
        @Yveaux
        With a multimeter
        • bjacobseB Offline
          bjacobseB Offline
          bjacobse
          True the NRF24L01+ shall use 900nA (0,9uA) in power down mode according to the spec.
          What do you mean when stating "when I remove 3.3V for the NRF it goes down to ~15uA." - is the NRF still connected with data pins to the arduino? (I hope that NO arduino pins are providing HIGH output, while there is no power to the NRF, since this will kill the NRF24L01+
          I understand that you are using a "good Quality" multimeter? else you can't trust your measured values.
          and the gw.sleep(SLEEP_TIME) should sleep both Arduino + NRF24L01+
          • tbowmoT Offline
            tbowmoT Offline
            tbowmo
            @flopp
            It could also be fake NRF chips, it's seen before.
            Also see this thread http://forum.mysensors.org/topic/1815/low-power-how-much-current-solved
            And perhaps this http://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
            • bjacobseB bjacobse
              F Offline
              F Offline
              flopp
              While arduino and NRF is in sleep I was measuring ~75 uA I disconnected the positive power cable for NRF and uA droped down to 15uA, BMP180 and stepdown was still connected.
              I am using a Fluke 87V, not calibrated for a couple of years but I trust it within 5% that's ok for me at the moment
              OK, that's perfect, then I don't have to think about sleep modes
              • tbowmoT tbowmo
                @flopp
                F Offline
                F Offline
                flopp
                @tbowmo
                I have ordered 10 pcs NRF, lets see if they can go down lower then ~60uA when sleeping
                Today I only have 2 NRF :grin:
                bjacobseB 1 Reply Last reply
                • F flopp
                  @tbowmo
                  bjacobseB Offline
                  bjacobseB Offline
                  bjacobse
                  @flopp
                  Yes replace NRFL2401+ with another NRF24L01+ to see if this make the current draw smaller - I think you can trust your Fluke 87V :-)
                  • F Offline
                    F Offline
                    flopp
                    I change the NRF for sensor and now I measure 0,04mA(41,8uA) with all equipment connected
                    I am happy
                    • F Offline
                      F Offline
                      flopp
                      I tried, before I changed NRF, to have use a digital output to feed my NRF.
                      i put
                      digitalWrite(4,HIGH);
                      at first row in SETUP
                      I also put
                      digitalWrite(4,LOW);
                      just before it go to sleep
                      but I then got "radio init fail", is it even possible to to it this way or can I have this type of function anywhere else in the code/file,?
                      AWIA 1 Reply Last reply
                      • F flopp
                        i put
                        I also put
                        AWIA Offline
                        AWIA Offline
                        AWI
                        @flopp When you power down the nRF you need to reinitialize it. But I doubt if it is worth the trouble as the radio consumes only a fraction of the total while sleeping.
                        Try making a node which powers up on interrupt only. The total consumption will go down to a little more than 1uA.
                        • AWIA AWI
                          F Offline
                          F Offline
                          flopp
                          It is a sensor(node?) that measures temp and pressure. Is it possible to have interrupt?
                          today I use timer, 60 seconds.
                          I also use a clone NRF(maybe) because firt one i tried did use much more than 1uA, more something like 60uA
                          • bjacobseB Offline
                            bjacobseB Offline
                            bjacobse
                            The timer can be set as an interupt
                            But sleep as MUCH as you can, this preserves your battery. So why measure every minute? if you can wait to measure every 5 minute, do so and prolong your battery :-) I know this depends on what you need the measurements to control, but "if its only" because you want to look at measurements in a graph, sleep for 5 min
                            • F Offline
                              F Offline
                              flopp
                              At the moment I am measuring every minute to verify that it works correctly.
                              Later I will measure every 5-15 minutes.
                              gw.sleep(sleeptime);
                              is what I use, I have seen other have used Interrupt together with sleeptime, but it works fine for me, right now in sleep it is 40uA
                              Do I need to use interrupt for better power saving?
                              • F flopp
                                bjacobseB Offline
                                bjacobseB Offline
                                bjacobse
                                @flopp
                                This is the correct way, to sleep and use interrupt for this :-) so you are using interrupt
                                http://forum.mysensors.org/topic/417/gw-sleep-and-milis
                                  @flopp
                                  F Offline
                                  F Offline
                                  flopp
                                  @bjacobse said:
                                  @flopp
                                  11.9k
                                  113.3k
