  3. Soft WDT reset on ESP8266
soft wdt resetesp-078266 gatewaywatchdog timeou
19 Posts 5 Posters 35.1k Views 4 Watching
    1.5 or dev branch?
    Tried adding a capacitor VCC/GND?
    R 1 Reply Last reply
    • YveauxY
      @robertober said:
      NRF24L01
      The + version I hope....
      Which ESP8266 Arduino core?
      • F
        F
        flopp
        how do you power the ESP8266?
        It is not enough to power it from Arduino or FTDI, you need something else. Try using something like AMS1177.
          1.5 or dev branch?
          R
          R
          robertober
          @hek 100 microfareds already there.
          !.5 or dev branch -- please explain.
          I think the answer is 1.5.
          F 1 Reply Last reply
          • R robertober
            F
            F
            flopp
            wrote on last edited by flopp
            i think @hek means version o library
            • YveauxY Yveaux
              @robertober said:
              NRF24L01
              R
              R
              robertober
              @Yveaux Yes, radio is the + model.
              I bought the model listed in the mySensor store, which is a ESP8266 Remote Serial Port WIFI Transceiver Wireless Module Esp-07 AP+STA WC
              • YveauxY
                ESP8266 is very sensitive to power. How are you powering it?
                • F flopp
                  R
                  R
                  robertober
                  @flopp My power supply is providing 35mA at 3.25 volts to the controller.
                  • R robertober
                    F
                    F
                    flopp
                    35mA!!!
                    ESP8266 need at least 300mA
                    What do you mean that it is powering the controller, do you mean ESP8266 or e.g. Domoticz?
                    • R robertober
                      I've built my own WiFi Gateway using an ESP-07. The sketch loaded without error, but the program won't run. I put in my network and port data. all else is on default settings. All my sensors are currently reporting(successfully) to a SerialGateway. Both controllers are set up to report through an interface to my XTension HA program. The Serial Gateway works fine, the 8266 gateway connects to XTension, but then reboots, disconnects and reconnects about every 7 seconds or so. Can anyone point me towards probable corrections?
                      I get the following output to the serial monitor:
                      ESP8266 MySensors Gateway
                      Connecting to Oberhaus
                      ..........Connected!
                      IP: 10.0.1.149
                      Soft WDT reset
                      ctx: cont
                      sp: 3ffefe10 end: 3fff0030 offset: 01b0
                      stack>>>
                      3ffeffc0: 00000000 00000001 3ffeee00 402034fc
                      3ffeffd0: 00000000 402020cc 00000001 40205308
                      3ffeffe0: 9501000a 00ffffff 0101000a 3ffef004
                      3ffefff0: 3ffe84a9 3ffeeef4 3fff0080 4020251b
                      3fff0000: 3ffe8860 9501000a 00000000 00000000
                      3fff0010: 3fffdc20 00000000 3ffeeffc 402052d2
                      3fff0020: 00000000 00000000 3ffef010 40100114
                      <<<stack<<<
                      ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                      tail 0
                      chksum 0x42
                      csum 0x42
                      ~ld
                      Following is my pinouts and connections to the 8266.
                      ESP8266 Module Esp-07 AP+STA WC
                      NRF24L01
                      Rest 10K to VCC/Switch to Ground
                      ADC
                      CH_PD 10K to VCC
                      GPIO16
                      GPIO14 SCK
                      GPIO12 MISO
                      GPIO13 MOSI
                      VCC 3.3V
                      TX
                      RX
                      GPIO5
                      GPIO4 CE
                      GPIO0 10K to VCC/Switch to Ground
                      GPIO2 10K to VCC
                      GPIO15 CSN
                      Ground Ground
                      R
                      R
                      robertober
                      @robertober I think that my issue is one of two things, one of the pins not properly connected, or a problem in the software. I started out using the sketch that is in the mySensor library, but found that the file ESP8266wifi.h was missing. I downloaded a file named https://github.com/ekstrand/ESP8266wifi/archive/master.zip and installed it into my library. I also noticed that the instructions built into the ESP8244Gateway Skecth gives two different connections for GPIO15. Is the pulldown resistor needed to run or only for uploading?
                      My controller (XTension running on a Mac Mini) seems to be receiving a different port request each time the 8266 resets. Anyone know why?
                      The log in Tension shows the following:
                      1/5/16 1:57:39 PM mySensor WiFi: IP Open to 10.0.1.149:63444 failed.
                      1/5/16 1:57:41 PM Interface mySensor WiFi has been unexpectedly disconnected from XTension.
                      1/5/16 1:57:41 PM Interface "mySensor WiFi" has quit: (with no message) code: 0
                      1/5/16 1:57:46 PM Retry connection to interface "mySensor WiFi". Tries left: 9
                      1/5/16 1:57:46 PM Helper Command: (/XTension/XTension.app/Contents/Pitchers/mysensors.isf/mysensors.isf IP 127.0.0.1 52301 340 10.0.1.149 57580)
                      1/5/16 1:57:46 PM Starting Interface "mySensor WiFi"
                      1/5/16 1:57:56 PM mySensor WiFi: IP Open to 10.0.1.149:63449 failed.
                      1/5/16 1:57:58 PM Received Temperature for TEMPERATURE ATTIC of 38.7F (RFX)
                      1/5/16 1:57:59 PM Interface mySensor WiFi has been unexpectedly disconnected from XTension.
                      1/5/16 1:57:59 PM Interface "mySensor WiFi" has quit: (with no message) code: 0
                      1/5/16 1:58:04 PM Retry connection to interface "mySensor WiFi". Tries left: 9
                      1/5/16 1:58:04 PM Helper Command: (/XTension/XTension.app/Contents/Pitchers/mysensors.isf/mysensors.isf IP 127.0.0.1 52301 341 10.0.1.149 57580)
                      1/5/16 1:58:04 PM Starting Interface "mySensor WiFi"
                      YveauxY 2 Replies Last reply
                      • R robertober
                        Ok, 3rd time I'm asking... This is the last time ;-)
                        Follow the installation instructions to the letter, or know what you're doing.
                        If the instructions are incorrect, search the forum.
                        If nothing found, describe your exact situation in a forum post so we can help you and improve the instructions for everyone.
                        Don't download random files and expect things to work correctly.
                        Beef up the power supply (500mA minimum!), then try with different nRF24L01+ modules.
                        • YveauxY Yveaux
                          R
                          R
                          robertober
                          @Yveaux How does one determine the Arduino core?
                          • R robertober
                            In the Arduino IDE, go to the boards manager (Tools -> Board -> Board manager) and note the ESP8266 version:
                            • YveauxY Yveaux
                              R
                              R
                              robertober
                              @Yveaux Ahh, I have version 2.0.0 installed.
                              • F flopp
                                35mA!!!
                                R
                                R
                                robertober
                                @flopp The power is to the Gateway, not controller.
                                • YveauxY
                                  Ok, I took some time to update my ESP setup, as all you guys keep reporting issues over and over again.
                                  • Software: MySensors 1.5.1, Arduino 1.6.7 IDE and ESP8266 Arduino Core 2.0.0. Standard ESP8266 Gateway sketch.
                                  • Hardware: NodeMCU with ESP12e, nRF24L01+ connected using 20cm dupont wires, using the connection from the build instructions. No additional caps mounted. Powered from PC USB port.
                                  • Controller: MYSController 0.1.2.282
                                  • Tested with 1 slave sending a message every second
                                  Compiles like a charm.
                                  Runs rock-solid. No (WDT) reboots whatsoever.
                                  Sending messages from controller to sensor also works.
                                  • R robertober
                                    I get that error message when I select the wrong target board. E.g. when selected Arduino UNO as target board, and compiling ESP8266 gateway sketch:
                                    ...\Esp8266Gateway.ino:77:25: fatal error: ESP8266WiFi.h: No such file or directory
                                     #include <ESP8266WiFi.h>
                                    compilation terminated.
                                    • electronicsguyE
                                      electronicsguyE
                                      electronicsguy
                                      @robertober This is probably due to a long time (> 1s) spent in setup() due to which the watchdog timer is resetting the chip. Check this page for more info:
                                      github-issue-WDT
