  3. MyController.org
  4. MyController+Domoticz at same time?
Scheduled Pinned Locked Moved MyController.org
33 Posts 9 Posters 18.2k Views 12 Watching
  • mfalkviddM
    @fets you're welcome. It is a bit hidden :)
    I have also found out that cloudmqtt offers a free personal mqtt broker. That might be useful.
    I have installed node-red-node-serialport:
    npm install -g --unsafe-perm node-red-node-serialport
    ln -s /usr/local/lib/node_modules/node-red-node-serialport /usr/lib/node_modules/node-red/node_modules
    (exactly what I did with node-red-contrib-mysensors) and restarted nodered and restarted my browser, but there's still no Serial port building block.
    • fetsF
      fetsF
      fets
      Did you check logs at node-red startup for errors, or try to run with -v flag
      • mfalkviddM
        I thought I did :blush: but now I'm getting something suspicious:
        Welcome to Node-RED
        5 Jan 21:38:44 - [info] Node-RED version: v0.10.6
        5 Jan 21:38:44 - [info] Node.js  version: v0.12.1
        5 Jan 21:38:44 - [info] Loading palette nodes
        5 Jan 21:38:51 - [warn] ------------------------------------------
        5 Jan 21:38:51 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
        5 Jan 21:38:51 - [warn] [serial] Error: Cannot find module '/usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v14-linux-arm/serialport.node'
        5 Jan 21:38:51 - [warn] [redisout] Error: Cannot find module 'redis'
        5 Jan 21:38:51 - [warn] [mongodb] Error: Cannot find module 'mongodb'
        5 Jan 21:38:51 - [warn] [serialport] serial in already registered
        5 Jan 21:38:51 - [info] User Directory : /home/pi/.node-red
        5 Jan 21:38:51 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
        5 Jan 21:38:51 - [info] Server now running at http://127.0.0.1:1880/
        5 Jan 21:38:51 - [info] Starting flows
        5 Jan 21:38:52 - [info] Started flows
        5 Jan 21:38:52 - [mqtt] [e7f85c03.1807a] connected to broker tcp://localhost:1883
        pi@raspberrypi ~ $ ls -laR /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/
        /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/:
        total 12
        drwxr-xr-x 3 root root 4096 Jun 13  2015 .
        drwxr-xr-x 3 root root 4096 Jun 13  2015 ..
        drwxr-xr-x 2 root root 4096 Jun 13  2015 node-v11-linux-arm
        /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v11-linux-arm:
        total 52
        drwxr-xr-x 2 root root  4096 Jun 13  2015 .
        -rwxr-xr-x 1 root root 44841 Jun 13  2015 serialport.node
        • fetsF
          fetsF
          fets
          I think your issue comes from your nodejs version.
          I'm now running v4.2.4.
          Check node-red-serial , Install section.
          Maybe this will solve your issue
          • mfalkviddM
            I'll try that. My gcc version is <4.8 so I need to use the alternative version.
            Do I need to remove the other packages? I seem unable to do that:
            pi@raspberrypi ~ $ gcc -v
            Using built-in specs.
            COLLECT_GCC=gcc
            COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.7/lto-wrapper
            Target: arm-linux-gnueabihf
            Configured with: ../src/configure -v --with-pkgversion='Debian 4.7.2-5+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
            Thread model: posix
            gcc version 4.7.2 (Debian 4.7.2-5+rpi1)
            pi@raspberrypi ~ $ sudo npm uninstall --unsafe-perm node-red-node-serialport
            - ansi-regex@2.0.0 node_modules/ansi-regex
            - ansi-styles@2.1.0 node_modules/ansi-styles
            - asn1@0.2.3 node_modules/asn1
            - assert-plus@0.1.5 node_modules/assert-plus
            - async@0.9.0 node_modules/async
            - aws-sign2@0.6.0 node_modules/aws-sign2
            - bindings@1.2.1 node_modules/bindings
            - bl@1.0.0 node_modules/bl
            - boom@2.10.1 node_modules/boom
            - caseless@0.11.0 node_modules/caseless
            - chalk@1.1.1 node_modules/chalk
            - combined-stream@1.0.5 node_modules/combined-stream
            - commander@2.9.0 node_modules/commander
            - core-util-is@1.0.2 node_modules/core-util-is
            - cryptiles@2.0.5 node_modules/cryptiles
            - dashdash@1.11.0 node_modules/dashdash
            - debug@2.2.0 node_modules/debug
            - delayed-stream@1.0.0 node_modules/delayed-stream
            - ecc-jsbn@0.1.1 node_modules/ecc-jsbn
            - escape-string-regexp@1.0.4 node_modules/escape-string-regexp
            - extend@3.0.0 node_modules/extend
            - extsprintf@1.0.2 node_modules/extsprintf
            - forever-agent@0.6.1 node_modules/forever-agent
            - form-data@1.0.0-rc3 node_modules/form-data
            - async@1.5.1 node_modules/form-data/node_modules/async
            - generate-function@2.0.0 node_modules/generate-function
            - generate-object-property@1.2.0 node_modules/generate-object-property
            - github@0.2.4 node_modules/github
            - graceful-readlink@1.0.1 node_modules/graceful-readlink
            - har-validator@2.0.3 node_modules/har-validator
            - has-ansi@2.0.0 node_modules/has-ansi
            - hawk@3.1.2 node_modules/hawk
            - hoek@2.16.3 node_modules/hoek
            - http-signature@1.1.0 node_modules/http-signature
            - inherits@2.0.1 node_modules/inherits
            - is-my-json-valid@2.12.3 node_modules/is-my-json-valid
            - is-property@1.0.2 node_modules/is-property
            - is-typedarray@1.0.0 node_modules/is-typedarray
            - isarray@0.0.1 node_modules/isarray
            - isstream@0.1.2 node_modules/isstream
            - jodid25519@1.0.2 node_modules/jodid25519
            - jsbn@0.1.0 node_modules/jsbn
            - json-schema@0.2.2 node_modules/json-schema
            - json-stringify-safe@5.0.1 node_modules/json-stringify-safe
            - jsonpointer@2.0.0 node_modules/jsonpointer
            - jsprim@1.2.2 node_modules/jsprim
            - mime@1.3.4 node_modules/mime
            - mime-db@1.20.0 node_modules/mime-db
            - mime-types@2.1.8 node_modules/mime-types
            - minimist@0.0.10 node_modules/minimist
            - ms@0.7.1 node_modules/ms
            - nan@2.0.9 node_modules/nan
            - node-red-node-serialport@0.1.0 node_modules/node-red-node-serialport
            - node-uuid@1.4.7 node_modules/node-uuid
            - oauth-sign@0.8.0 node_modules/oauth-sign
            - optimist@0.6.1 node_modules/optimist
            - pinkie@2.0.1 node_modules/pinkie
            - pinkie-promise@2.0.0 node_modules/pinkie-promise
            - process-nextick-args@1.0.6 node_modules/process-nextick-args
            - qs@5.2.0 node_modules/qs
            - readable-stream@2.0.5 node_modules/readable-stream
            - request@2.67.0 node_modules/request
            - serialport@2.0.5 node_modules/serialport
            - node-pre-gyp@0.6.13 node_modules/serialport/node_modules/node-pre-gyp
            - node-pre-gyp-github@1.0.5 node_modules/serialport/node_modules/node-pre-gyp-github
            - mkdirp@0.5.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp
            - minimist@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist
            - nopt@3.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt
            - abbrev@1.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/node_modules/abbrev
            - npmlog@1.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog
            - ansi@0.3.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/ansi
            - are-we-there-yet@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet
            - delegates@0.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/delegates
            - readable-stream@1.1.13 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream
            - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/core-util-is
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/inherits
            - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/isarray
            - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/string_decoder
            - gauge@1.2.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge
            - has-unicode@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/has-unicode
            - lodash.pad@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad
            - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._basetostring
            - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding
            - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding/node_modules/lodash.repeat
            - lodash.padleft@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft
            - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._basetostring
            - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding
            - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding/node_modules/lodash.repeat
            - lodash.padright@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright
            - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._basetostring
            - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding
            - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding/node_modules/lodash.repeat
            - rc@1.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
            - deep-extend@0.2.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/deep-extend
            - ini@1.3.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/ini
            - minimist@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist
            - strip-json-comments@0.1.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/strip-json-comments
            - request@2.65.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
            - aws-sign2@0.6.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/aws-sign2
            - bl@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl
            - readable-stream@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream
            - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/core-util-is
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/inherits
            - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/isarray
            - process-nextick-args@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/process-nextick-args
            - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/string_decoder
            - util-deprecate@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/util-deprecate
            - caseless@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/caseless
            - combined-stream@1.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream
            - delayed-stream@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
            - extend@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/extend
            - forever-agent@0.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/forever-agent
            - form-data@1.0.0-rc3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data
            - async@1.4.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/node_modules/async
            - har-validator@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator
            - chalk@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk
            - ansi-styles@2.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
            - escape-string-regexp@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
            - has-ansi@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
            - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
            - strip-ansi@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
            - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
            - supports-color@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
            - commander@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander
            - graceful-readlink@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
            - is-my-json-valid@2.12.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
            - generate-function@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
            - generate-object-property@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
            - is-property@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
            - jsonpointer@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
            - xtend@4.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/xtend
            - pinkie-promise@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
            - pinkie@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
            - hawk@3.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk
            - boom@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/boom
            - cryptiles@2.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/cryptiles
            - hoek@2.16.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/hoek
            - sntp@1.0.9 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/sntp
            - http-signature@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
            - asn1@0.1.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/asn1
            - assert-plus@0.1.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/assert-plus
            - ctype@0.5.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/ctype
            - isstream@0.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/isstream
            - json-stringify-safe@5.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringify-safe
            - mime-types@2.1.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types
            - mime-db@1.19.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types/node_modules/mime-db
            - node-uuid@1.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/node-uuid
            - oauth-sign@0.8.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/oauth-sign
            - qs@5.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs
            - stringstream@0.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/stringstream
            - tough-cookie@2.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie
            - tunnel-agent@0.4.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tunnel-agent
            - rimraf@2.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf
            - glob@5.0.15 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob
            - inflight@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight
            - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight/node_modules/wrappy
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inherits
            - minimatch@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch
            - brace-expansion@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion
            - balanced-match@0.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/balanced-match
            - concat-map@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/concat-map
            - once@1.3.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once
            - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once/node_modules/wrappy
            - path-is-absolute@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/path-is-absolute
            - semver@5.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/semver
            - tar@2.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar
            - tar-pack@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
            - debug@0.7.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug
            - fstream@0.1.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream
            - fstream-ignore@0.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/inherits
            - minimatch@0.2.14 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch
            - lru-cache@2.7.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/lru-cache
            - sigmund@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/sigmund
            - graceful-fs@3.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/graceful-fs
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/inherits
            - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/graceful-fs
            - once@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once
            - readable-stream@1.0.33 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream
            - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/core-util-is
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/inherits
            - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/isarray
            - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/string_decoder
            - rimraf@2.2.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/rimraf
            - tar@0.1.20 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar
            - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/block-stream
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/inherits
            - uid-number@0.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/uid-number
            - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/block-stream
            - fstream@1.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream
            - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/node_modules/graceful-fs
            - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/inherits
            - sf@0.1.7 node_modules/sf
            - sntp@1.0.9 node_modules/sntp
            - sshpk@1.7.1 node_modules/sshpk
            - assert-plus@0.2.0 node_modules/sshpk/node_modules/assert-plus
            - string_decoder@0.10.31 node_modules/string_decoder
            - stringstream@0.0.5 node_modules/stringstream
            - strip-ansi@3.0.0 node_modules/strip-ansi
            - supports-color@2.0.0 node_modules/supports-color
            - tough-cookie@2.2.1 node_modules/tough-cookie
            - tunnel-agent@0.4.2 node_modules/tunnel-agent
            - tweetnacl@0.13.2 node_modules/tweetnacl
            - util-deprecate@1.0.2 node_modules/util-deprecate
            - verror@1.3.6 node_modules/verror
            - wordwrap@0.0.3 node_modules/wordwrap
            - xtend@4.0.1 node_modules/xtend
            npm WARN enoent ENOENT, open '/home/pi/package.json'
            npm WARN pi No description
            npm WARN pi No repository field.
            npm WARN pi No README data
            npm WARN pi No license field.
            • mfalkviddM
              pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport
              (>32kB output)
              pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport@0.1.0; sudo npm uninstall --unsafe-perm node-red-node-serialport@0.1.0
              - node-pre-gyp node_modules/serialport/node_modules/node-pre-gyp
              - rc node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
              - request node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
              - tar-pack node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
              npm WARN enoent ENOENT, open '/home/pi/node_modules/serialport/package.json'
              pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm serialport@2.0.5; sudo npm uninstall --unsafe-perm serialport@2.0.5
              pi@raspberrypi ~ $ sudo npm -g list
              /usr/local/lib
              ├─┬ mdns@2.2.11
              │ ├── bindings@1.2.1
              │ └── nan@2.1.0
              ├── node-red-contrib-mysensors@0.7.5
              ├─┬  error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json
              │ └──  extraneous error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json
              ├─┬ npm@3.5.3
              │ ├── abbrev@1.0.7
              │ ├── ansi-regex@2.0.0
              │ ├── ansicolors@0.3.2
              │ ├── ansistyles@0.1.3
              │ ├── aproba@1.0.1
              │ ├── archy@1.0.0
              │ ├── async-some@1.0.2
              │ ├── chownr@1.0.1
              │ ├─┬ cmd-shim@2.0.1
              │ │ └── graceful-fs@3.0.8
              │ ├─┬ columnify@1.5.2
              │ │ └─┬ wcwidth@1.0.0
              │ │   └─┬ defaults@1.0.3
              │ │     └── clone@1.0.2
              │ ├─┬ config-chain@1.1.9
              │ │ └── proto-list@1.2.4
              │ ├── debuglog@1.0.1
              │ ├─┬ dezalgo@1.0.3
              │ │ └── asap@2.0.3
              │ ├── editor@1.0.0
              │ ├── fs-vacuum@1.2.7
              │ ├── fs-write-stream-atomic@1.0.5
              │ ├── fstream@1.0.8
              │ ├─┬ fstream-npm@1.0.7
              │ │ └─┬ fstream-ignore@1.0.3
              │ │   └─┬ minimatch@3.0.0
              │ │     └─┬ brace-expansion@1.1.1
              │ │       ├── balanced-match@0.2.1
              │ │       └── concat-map@0.0.1
              │ ├─┬ glob@5.0.15
              │ │ ├─┬ minimatch@3.0.0
              │ │ │ └─┬ brace-expansion@1.1.1
              │ │ │   ├── balanced-match@0.2.0
              │ │ │   └── concat-map@0.0.1
              │ │ └── path-is-absolute@1.0.0
              │ ├── graceful-fs@4.1.2
              │ ├── has-unicode@1.0.1
              │ ├── hosted-git-info@2.1.4
              │ ├── iferr@0.1.5
              │ ├── imurmurhash@0.1.4
              │ ├── inflight@1.0.4
              │ ├── inherits@2.0.1
              │ ├── ini@1.3.4
              │ ├─┬ init-package-json@1.9.1
              │ │ └── promzard@0.3.0
              │ ├── lockfile@1.0.1
              │ ├── lodash._baseindexof@3.1.0
              │ ├── lodash._baseuniq@3.0.3
              │ ├── lodash._bindcallback@3.0.1
              │ ├── lodash._cacheindexof@3.0.2
              │ ├── lodash._createcache@3.1.2
              │ ├── lodash._getnative@3.9.1
              │ ├─┬ lodash.clonedeep@3.0.2
              │ │ └─┬ lodash._baseclone@3.3.0
              │ │   ├── lodash._arraycopy@3.0.0
              │ │   ├── lodash._arrayeach@3.0.0
              │ │   ├─┬ lodash._baseassign@3.2.0
              │ │   │ └── lodash._basecopy@3.0.1
              │ │   └── lodash._basefor@3.0.2
              │ ├── lodash.isarguments@3.0.4
              │ ├── lodash.isarray@3.0.4
              │ ├── lodash.keys@3.1.2
              │ ├── lodash.restparam@3.6.1
              │ ├─┬ lodash.union@3.1.0
              │ │ └── lodash._baseflatten@3.1.4
              │ ├─┬ lodash.uniq@3.2.2
              │ │ ├─┬ lodash._basecallback@3.3.1
              │ │ │ ├─┬ lodash._baseisequal@3.0.7
              │ │ │ │ └── lodash.istypedarray@3.0.2
              │ │ │ └── lodash.pairs@3.0.1
              │ │ └── lodash._isiterateecall@3.0.9
              │ ├─┬ lodash.without@3.2.1
              │ │ └── lodash._basedifference@3.0.3
              │ ├─┬ mkdirp@0.5.1
              │ │ └── minimist@0.0.8
              │ ├─┬ node-gyp@3.2.1
              │ │ ├─┬ glob@4.5.3
              │ │ │ └─┬ minimatch@2.0.10
              │ │ │   └─┬ brace-expansion@1.1.2
              │ │ │     ├── balanced-match@0.3.0
              │ │ ├─┬ minimatch@1.0.0
              │ │ │ ├── lru-cache@2.7.3
              │ │ │ └── sigmund@1.0.1
              │ │ ├─┬ npmlog@1.2.1
              │ │ │ ├── ansi@0.3.0
              │ │ │ ├─┬ are-we-there-yet@1.0.4
              │ │ │ │ ├── delegates@0.1.0
              │ │ │ │ └─┬ readable-stream@1.1.13
              │ │ │ │   ├── core-util-is@1.0.2
              │ │ │ │   ├── isarray@0.0.1
              │ │ │ │   └── string_decoder@0.10.31
              │ │ │ └─┬ gauge@1.2.2
              │ │ │   ├─┬ lodash.pad@3.1.1
              │ │ │   │ ├── lodash._basetostring@3.0.1
              │ │ │   │ └─┬ lodash._createpadding@3.6.1
              │ │ │   │   └── lodash.repeat@3.0.1
              │ │ │   ├─┬ lodash.padleft@3.1.1
              │ │ │   └─┬ lodash.padright@3.1.1
              │ │ └─┬ path-array@1.0.0
              │ │   └─┬ array-index@0.1.1
              │ │     └─┬ debug@2.2.0
              │ │       └── ms@0.7.1
              │ ├── nopt@3.0.6
              │ ├── normalize-git-url@3.0.1
              │ ├─┬ normalize-package-data@2.3.5
              │ │ └─┬ is-builtin-module@1.0.0
              │ │   └── builtin-modules@1.1.0
              │ ├── npm-cache-filename@1.0.2
              │ ├─┬ npm-install-checks@2.0.1
              │ │ └─┬ npmlog@1.2.1
              │ │   ├── ansi@0.3.0
              │ │   │   ├── core-util-is@1.0.1
              │ │   └─┬ gauge@1.2.2
              │ ├── npm-package-arg@4.1.0
              │ ├─┬ npm-registry-client@7.0.9
              │ │ └─┬ concat-stream@1.5.1
              │ │   ├─┬ readable-stream@2.0.4
              │ │   │ ├── process-nextick-args@1.0.3
              │ │   │ ├── string_decoder@0.10.31
              │ │   │ └── util-deprecate@1.0.2
              │ │   └── typedarray@0.0.6
              │ ├── npm-user-validate@0.1.2
              │ ├─┬ npmlog@2.0.0
              │ │ ├── ansi@0.3.0
              │ │ └─┬ gauge@1.2.2
              │ ├── once@1.3.3
              │ ├── opener@1.4.1
              │ ├─┬ osenv@0.1.3
              │ │ ├── os-homedir@1.0.1
              │ │ └── os-tmpdir@1.0.1
              │ ├── path-is-inside@1.0.1
              │ ├─┬ read@1.0.7
              │ │ └── mute-stream@0.0.5
              │ ├── read-cmd-shim@1.0.1
              │ ├─┬ read-installed@4.0.3
              │ │ └── util-extend@1.0.1
              │ ├─┬ read-package-json@2.0.2
              │ │ └─┬ json-parse-helpfulerror@1.0.3
              │ │   └── jju@1.2.1
              │ ├── read-package-tree@5.1.2
              │ ├── readdir-scoped-modules@1.0.2
              │ ├── realize-package-specifier@3.0.1
              │ ├─┬ request@2.67.0
              │ │ ├── aws-sign2@0.6.0
              │ │ ├─┬ bl@1.0.0
              │ │ │ └─┬ readable-stream@2.0.4
              │ │ │   ├── process-nextick-args@1.0.6
              │ │ ├── caseless@0.11.0
              │ │ ├─┬ combined-stream@1.0.5
              │ │ │ └── delayed-stream@1.0.0
              │ │ ├── extend@3.0.0
              │ │ ├── forever-agent@0.6.1
              │ │ ├─┬ form-data@1.0.0-rc3
              │ │ │ └── async@1.5.0
              │ │ ├─┬ har-validator@2.0.3
              │ │ │ ├─┬ chalk@1.1.1
              │ │ │ │ ├── ansi-styles@2.1.0
              │ │ │ │ ├── escape-string-regexp@1.0.3
              │ │ │ │ ├── has-ansi@2.0.0
              │ │ │ │ └── supports-color@2.0.0
              │ │ │ ├─┬ commander@2.9.0
              │ │ │ │ └── graceful-readlink@1.0.1
              │ │ │ ├─┬ is-my-json-valid@2.12.3
              │ │ │ │ ├── generate-function@2.0.0
              │ │ │ │ ├─┬ generate-object-property@1.2.0
              │ │ │ │ │ └── is-property@1.0.2
              │ │ │ │ ├── jsonpointer@2.0.0
              │ │ │ │ └── xtend@4.0.1
              │ │ │ └─┬ pinkie-promise@2.0.0
              │ │ │   └── pinkie@2.0.1
              │ │ ├─┬ hawk@3.1.2
              │ │ │ ├── boom@2.10.1
              │ │ │ ├── cryptiles@2.0.5
              │ │ │ ├── hoek@2.16.3
              │ │ │ └── sntp@1.0.9
              │ │ ├─┬ http-signature@1.1.0
              │ │ │ ├── assert-plus@0.1.5
              │ │ │ ├─┬ jsprim@1.2.2
              │ │ │ │ ├── extsprintf@1.0.2
              │ │ │ │ ├── json-schema@0.2.2
              │ │ │ │ └── verror@1.3.6
              │ │ │ └─┬ sshpk@1.7.1
              │ │ │   ├── asn1@0.2.3
              │ │ │   ├── assert-plus@0.2.0
              │ │ │   ├─┬ dashdash@1.10.1
              │ │ │   │ └── assert-plus@0.1.5
              │ │ │   ├── ecc-jsbn@0.1.1
              │ │ │   ├── jodid25519@1.0.2
              │ │ │   ├── jsbn@0.1.0
              │ │ │   └── tweetnacl@0.13.2
              │ │ ├── is-typedarray@1.0.0
              │ │ ├── isstream@0.1.2
              │ │ ├── json-stringify-safe@5.0.1
              │ │ ├─┬ mime-types@2.1.8
              │ │ │ └── mime-db@1.20.0
              │ │ ├── node-uuid@1.4.7
              │ │ ├── oauth-sign@0.8.0
              │ │ ├── qs@5.2.0
              │ │ ├── stringstream@0.0.5
              │ │ ├── tough-cookie@2.2.1
              │ │ └── tunnel-agent@0.4.2
              │ ├── retry@0.8.0
              │ ├── rimraf@2.4.4
              │ ├── semver@5.1.0
              │ ├─┬ sha@2.0.1
              │ │ └─┬ readable-stream@2.0.2
              │ ├── slide@1.1.6
              │ ├── sorted-object@1.0.0
              │ ├── strip-ansi@3.0.0
              │ ├─┬ tar@2.2.1
              │ │ └── block-stream@0.0.8
              │ ├── text-table@0.2.0
              │ ├── uid-number@0.0.6
              │ ├── umask@1.1.0
              │ ├─┬ unique-filename@1.1.0
              │ │ └── unique-slug@2.0.0
              │ ├── unpipe@1.0.0
              │ ├─┬ validate-npm-package-license@3.0.1
              │ │ ├─┬ spdx-correct@1.0.1
              │ │ │ └── spdx-license-ids@1.0.2
              │ │ └─┬ spdx-expression-parse@1.0.0
              │ │   └── spdx-exceptions@1.0.3
              │ ├─┬ validate-npm-package-name@2.2.2
              │ │ └── builtins@0.0.7
              │ ├─┬ which@1.2.0
              │ │ └─┬ is-absolute@0.1.7
              │ │   └── is-relative@0.1.3
              │ ├── wrappy@1.0.1
              │ └── write-file-atomic@1.1.4
              └─┬ serialport@2.0.5
                ├── async@0.9.0
                ├── bindings@1.2.1
                ├─┬ debug@2.2.0
                │ └── ms@0.7.1
                ├── nan@2.0.9
                ├─┬ node-pre-gyp@0.6.18
                │ ├─┬ mkdirp@0.5.1
                │ ├─┬ nopt@3.0.6
                │ │ └── abbrev@1.0.7
                │ ├─┬ npmlog@2.0.0
                │ │ ├── ansi@0.3.0
                │ │ ├─┬ are-we-there-yet@1.0.5
                │ │ │ └─┬ readable-stream@2.0.5
                │ │ │   ├── inherits@2.0.1
                │ │ └─┬ gauge@1.2.2
                │ │   ├── has-unicode@1.0.1
                │ ├─┬ rc@1.1.5
                │ │ ├── deep-extend@0.4.0
                │ │ ├── ini@1.3.4
                │ │ ├── minimist@1.2.0
                │ │ └── strip-json-comments@1.0.4
                │ │ ├─┬ bl@1.0.0
                │ │ │ │ ├─┬ has-ansi@2.0.0
                │ │ │ │ │ └── ansi-regex@2.0.0
                │ │ │ │ ├─┬ strip-ansi@3.0.0
                │ │ ├─┬ hawk@3.1.2
                │ │ ├── qs@5.2.0
                │ ├─┬ rimraf@2.4.4
                │ │ └─┬ glob@5.0.15
                │ │   ├─┬ inflight@1.0.4
                │ │   │ └── wrappy@1.0.1
                │ │   ├─┬ once@1.3.3
                │ ├── semver@5.1.0
                │ ├─┬ tar@2.2.1
                │ │ ├── block-stream@0.0.8
                │ │ ├─┬ fstream@1.0.8
                │ │ │ └── graceful-fs@4.1.2
                │ │ └── inherits@2.0.1
                │ └─┬ tar-pack@3.1.2
                │   ├── debug@0.7.4
                │   ├─┬ fstream@1.0.8
                │   │ ├── graceful-fs@4.1.2
                │   ├─┬ fstream-ignore@1.0.3
                │   ├── once@1.1.1
                │   ├─┬ readable-stream@2.0.5
                │   └── uid-number@0.0.3
                ├─┬ node-pre-gyp-github@1.0.4 invalid (git://github.com/jacobrosenthal/node-pre-gyp-github.git#8f8b71c6111230d6535ccd21ffbb725aaa068cf0)
                │ ├── github@0.2.4
                │ ├── mime@1.3.4
                │ └─┬ request@2.65.0
                │   ├─┬ bl@1.0.0
                │   │ └─┬ readable-stream@2.0.3
                │   ├── extend@3.0.0
                │   │ └── async@1.5.0
                │   ├─┬ har-validator@2.0.2
                │   │ ├─┬ chalk@1.1.1
                │   │ ├─┬ is-my-json-valid@2.12.2
                │   │ │ └── xtend@4.0.0
                │   │ └─┬ pinkie-promise@1.0.0
                │   │   └── pinkie@1.0.0
                │   ├─┬ hawk@3.1.0
                │   │ ├── boom@2.10.0
                │   │ ├── hoek@2.16.3
                │   │ └── sntp@1.0.9
                │   ├─┬ http-signature@0.11.0
                │   │ ├── asn1@0.1.11
                │   │ └── ctype@0.5.3
                │   ├─┬ mime-types@2.1.7
                │   │ └── mime-db@1.19.0
                │   ├── node-uuid@1.4.3
                │   ├── qs@5.2.0
                │   ├── tough-cookie@2.2.0
                │   └── tunnel-agent@0.4.1
                ├─┬ optimist@0.6.1
                │ ├── minimist@0.0.10
                │ └── wordwrap@0.0.3
                └── sf@0.1.7
              npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json'
              npm ERR! extraneous: serialport /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
              npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json'
              npm ERR! invalid: node-pre-gyp-github@1.0.4 /usr/local/lib/node_modules/serialport/node_modules/node-pre-gyp-github
              • mfalkviddM
                pi@raspberrypi ~ $ sudo npm -g install node-red-node-serialport@0.0.5
                npm WARN lifecycle serialport@1.7.4~install: cannot run in wd %s %s (wd=%s) serialport@1.7.4 node-pre-gyp install --fallback-to-build /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
                /usr/local/lib
                └─┬ node-red-node-serialport@0.0.5
                  └─┬ serialport@1.7.4
                    ├── async@0.9.0
                    ├── bindings@1.2.1
                    ├─┬ debug@2.2.0
                    │ └── ms@0.7.1
                    ├── nan@1.8.4
                    ├─┬ node-pre-gyp@0.6.7
                    │ ├─┬ mkdirp@0.5.0
                    │ ├─┬ nopt@3.0.1
                    │ │ └── abbrev@1.0.5
                    │ ├─┬ npmlog@1.2.0
                    │ │ ├── ansi@0.3.0
                    │ │ └─┬ gauge@1.2.0
                    │ │   ├── has-unicode@1.0.0
                    │ │   ├─┬ lodash.pad@3.1.0
                    │ │   │ ├── lodash._basetostring@3.0.0
                    │ │   │ └─┬ lodash._createpadding@3.6.0
                    │ │   │   └── lodash.repeat@3.0.0
                    │ ├─┬ rc@1.0.1
                    │ │ ├── deep-extend@0.2.11
                    │ │ ├── ini@1.3.3
                    │ │ ├── minimist@0.0.10
                    │ │ └── strip-json-comments@0.1.3
                    │ ├─┬ request@2.55.0
                    │ │ ├── aws-sign2@0.5.0
                    │ │ ├─┬ bl@0.9.4
                    │ │ │ └─┬ readable-stream@1.0.33
                    │ │ ├── caseless@0.9.0
                    │ │ ├─┬ combined-stream@0.0.7
                    │ │ │ └── delayed-stream@0.0.5
                    │ │ ├─┬ form-data@0.2.0
                    │ │ │ └── async@0.9.0
                    │ │ ├─┬ har-validator@1.7.0
                    │ │ │ ├── bluebird@2.9.25
                    │ │ │ ├─┬ chalk@1.0.0
                    │ │ │ │ ├── ansi-styles@2.0.1
                    │ │ │ │ ├─┬ has-ansi@1.0.3
                    │ │ │ │ │ ├── ansi-regex@1.1.1
                    │ │ │ │ │ └── get-stdin@4.0.1
                    │ │ │ │ ├─┬ strip-ansi@2.0.1
                    │ │ │ │ │ └── ansi-regex@1.1.1
                    │ │ │ │ └── supports-color@1.3.1
                    │ │ │ ├─┬ commander@2.8.1
                    │ │ │ └─┬ is-my-json-valid@2.10.1
                    │ │ │   ├─┬ generate-object-property@1.1.1
                    │ │ │   ├── jsonpointer@1.1.0
                    │ │ ├─┬ hawk@2.3.1
                    │ │ │ ├── boom@2.7.1
                    │ │ │ ├── cryptiles@2.0.4
                    │ │ │ ├── hoek@2.13.0
                    │ │ ├─┬ http-signature@0.10.1
                    │ │ │ ├── asn1@0.1.11
                    │ │ │ └── ctype@0.5.3
                    │ │ ├── json-stringify-safe@5.0.0
                    │ │ ├─┬ mime-types@2.0.10
                    │ │ │ └── mime-db@1.8.0
                    │ │ ├── node-uuid@1.4.3
                    │ │ ├── oauth-sign@0.6.0
                    │ │ ├── qs@2.4.1
                    │ │ ├── stringstream@0.0.4
                    │ │ ├── tough-cookie@1.1.0
                    │ │ └── tunnel-agent@0.4.0
                    │ ├─┬ rimraf@2.3.3
                    │ │ └─┬ glob@4.5.3
                    │ │   ├─┬ minimatch@2.0.7
                    │ │   │ └─┬ brace-expansion@1.1.0
                    │ │   └─┬ once@1.3.1
                    │ ├── semver@4.3.3
                    │ ├─┬ tar@2.1.0
                    │ │ ├── block-stream@0.0.7
                    │ │ ├─┬ fstream@1.0.4
                    │ │ │ └── graceful-fs@3.0.6
                    │ └─┬ tar-pack@2.0.0
                    │   ├── debug@0.7.4
                    │   ├─┬ fstream@0.1.31
                    │   │ ├── graceful-fs@3.0.6
                    │   ├─┬ fstream-ignore@0.0.7
                    │   │ └─┬ minimatch@0.2.14
                    │   │   ├── lru-cache@2.6.2
                    │   │   └── sigmund@1.0.0
                    │   ├── graceful-fs@1.2.3
                    │   ├── once@1.1.1
                    │   ├─┬ readable-stream@1.0.33
                    │   ├── rimraf@2.2.8
                    │   ├─┬ tar@0.1.20
                    ├─┬ optimist@0.6.1
                    └── sf@0.1.7
                • fetsF
                  fetsF
                  fets
                  Sorry, I don't understand why it doen'twork. This is beyond my capabilities.
                  May be you should erase all directories name serial and node-serial in /usr/lib/node_modules/node-red/node_modules and your local node_modules in case of conflits with previous attempts
                  • mfalkviddM
                    Thanks a lot for your help @fets
                    I got it working, finally! Not sure exactly what I did to get it working (I tried literally hundreds of things) but if someone has a similar problem, this might help:
                    • Don't ever use npm -g. It is discouraged by the npm people, it is really broken when run with sudo and it is probably not what you want anyway.
                    • For the node-red shipped with Domoticz's Raspberry pi image, run npm as the pi user when standing in the /usr/lib/node_modules/node-red folder
                    • npm rebuild seems to be useful
                    • npm ls is useful for troubleshooting. It shouldn't report any errors if everything is alright, but things seem to seldom be alright.
                    • Have a lot of patience, npm is seriously slow on a Raspberry Pi
                    Anyway, now I have Serial as input and output block in nodered. :sparkles:
                    fetsF 1 Reply Last reply
                    • crankyC
                      crankyC
                      cranky
                      wrote on last edited by cranky
                      #22
                      You'll also probably want node-red-contrib-mysensors and a few other modules on flows.nodered.org
                      I use TOR extensively for being able to nicely manage and manipulate data on my network securely. The trick is a few things:
                      TOR: Providing a Hidden Service to SSH and HTTPS
                      Node-Red: Self-signed certs, HTTPS, and user authentication turned on.
                      Mosquitto: Providing MQTTSSL. node-red-contrib-mqttssl provides support for that
                      But hek was gracious to make a "Controller>Node-Red" subforum, so come join me there!
                      Edit: also, because npm is sometimes really braindead sometimes, try using -debug with whatever you're doing. It will many a times make it work where without debut will just hang forever.
                        fetsF
                        fetsF
                        fets
                        wrote on last edited by fets
                        #23
                        @mfalkvidd congrats
                        @cranky thanks I noticed the new subforum and already follow it
                        • ErrKE
                          ErrKE
                          ErrK
                          wrote on last edited by ErrK
                          #24
                          @mfalkvidd do you have both MyController and Domoticz on the same Raspberry Pi?
                          I will start from the Domoticz Raspberry Pi image and then try to install MyController.
                          I use a ESP8266 gateway. Do you have any tips before i start?
                          • mfalkviddM
                            Yes I use the same raspberry pi for both controllers. You probably need the newer models with 1GB ram.
                            I'm not really using mycontroller yet, have not spent time working with it.
                            • sundberg84S
                              sundberg84S
                              I tried both on a ethernet gw, but both freeze after some minutes. This has worked before but when domoticz included the gateway ping it begun. Im.now using domoticz and ethenret and build a serial gw and run with mysc for ota updates.
                              petewillP 1 Reply Last reply
                              • ErrKE
                                ErrKE
                                ErrK
                                @mfalkvidd i have the new Raspberry pi 2.
                                The installation was simple.
                                But i now i only have my gateway in MyController. Using Domoticz for my z-wave.
                                @sundberg84 ok.
                                Are you using MYSbootloader or Dualoptiboot?
                                • sundberg84S
                                  sundberg84S
                                  #28
                                  @ErrK MYSBootloader, i showed Tekka this so he is aware of the problem.
                                  ErrKE 1 Reply Last reply
                                  • sundberg84S sundberg84
                                    ErrKE
                                    ErrKE
                                    ErrK
                                    @sundberg84 ok.
                                    I will try with MYSBootloader.
                                    Need to figure out how to do it on osx.
                                    Have only find the tutorial for windows yet.
                                    • J
                                      J
                                      jkandasa
                                      Currently we are working for MyController 0.0.3 version. almost done. we will release it soon. It has many changes in front end(Enterprise level) and back end.
                                      If you want to try, please compile yourself from development branch https://github.com/mycontroller-org/mycontroller or let me know I will post compiled image.
                                      It will be helpful for MyController if you report any issue on this 0.0.3 version, we can fix it before release
                                      beta testers required...
                                      If you want MyController in your language send request here https://www.transifex.com/mycontrollerorg/gui-angularjs/
                                        petewillP
                                        petewillP
                                        petewill
                                        Can you describe this a little more? I have been experimenting with Domoticz as a secondary controller (on a Raspberry Pi using Node-Red) but my Ethernet Gateway has been crashing fairly regularly (about once a every other day on average). I'm not totally sure where the problem is occurring but it seems to be related to my Pi setup. If I shut the Pi down the Ethernet Gateway seems to stay alive longer (I haven't had too much time to test this theory though because I'm testing a sensor with the Pi). I also recently updated to 1.5.1 so I'm not sure if that has anything to do with it. Previously I was on 1.4.1 and the gateway ran for months without any issues. Just thought I'd reach out to you since it seems you may have had a similar issue. Thanks!
                                        • sundberg84S
                                          sundberg84S
                                          @petewill My Domoticz crashed 30sec after i connect Myscontroller to same ethernet gateway. Also Myscontroller seems to crash and when i disconnect Myscontroller, Domoticz resets the connection and reconnects itself with a error in the log.
