Home Assistant v 0.11.1 with switch support
Hi!
Version 0.11 of home assisstant is now released with included mysensors switch support for serial gateway. Right now switches will change state optimistically, without waiting for reply from actuator. I'll add support for feedback state soon. Let me know of any problems.
I've also refactored the component so it will be easy to add new platforms, light, binary sensor, lock etc. I'm hoping to have time to do so soon. Another new feature is multiple serial gateways connected at the same time.
Edit:
You have to update your config if already using mysensors in home assistant. It should now look like this, for two gateways:
mysensors: gateways: - port: '/dev/ttyUSB0' persistence_file: 'path/mysensors.json' - port: '/dev/ttyACM1' persistence_file: 'path/mysensors2.json' debug: true persistence: true version: '1.5'You can see that it's not a sensor platform config anymore. The available platforms will be setup automatically from the component.
Update: Bugfix release 0.11.1 is now released. Version 0.11 was missing the binary sensors. That has now been fixed in 0.11.1.
Thank you! Please let me know if this new release is development or not, because I am looking every day on HA site for update (mostly for solving the delay for group switches) and there are no news about 0.11.
I don't think they've had the time to do a blog post yet. But it will probably happen very soon. The release is available both on pypi and github though. You should be able to do:
pip3 install --upgrade homeassistantThen restart homeassistant.
I installed Home-assistant and Setup a MySensor SerialGateWay + MySensor Switch.
Yet when I start HA It shows this Error:16-01-18 17:27:38 homeassistant.components.mysensors: Missing required configuration items in mysensors: gateways 16-01-18 17:27:38 homeassistant.bootstrap: component mysensors failed to initialize```Config:
mysensors 1: gateways: - port: '/dev/ttyUSB0' persistence_file: 'hass_log/mysensors.json' debug: true persistence: true version: '1.5' -
mysensors 1: gateways: - port: '/dev/ttyUSB0' persistence_file: 'hass_log/mysensors.json' debug: true persistence: true version: '1.5'Hi!
You should only have one mysensors domain, so remove the "1" after "mysensors" in your config:
mysensors: gateways: - port: '/dev/ttyUSB0' persistence_file: 'hass_log/mysensors.json' debug: true persistence: true version: '1.5' -
@martinhjelmare
Thank you!
Seems to Load now :)
I disabled persistence because I did not seem to need it right now.
I am getting the following log when I Push the Wireless Button, it seems to work.
But I dont see any now nodes / Sensor on the Dashboard. Did I forget something?INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 -
@martinhjelmare
Thank you!
But I dont see any now nodes / Sensor on the Dashboard. Did I forget something?INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1 INFO:homeassistant.components.mysensors:No sketch_name: node 1INFO:homeassistant.components.mysensors:No sketch_name: node 1This indicates that the gateway hasn't received all presentation messages from node 1. It's missing sketch name for this node.
If you disable persistence you have to restart your nodes each time you restart home assistant, to resend the presentation messages.
@martinhjelmare
Got that worked out, changed the Name in the Persistence File that HA created! :+1:
But it still does not show up.
HA Log:INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1 INFO:homeassistant.components.mysensors:update sensor_update: node 1 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0 INFO:homeassistant.components.mysensors:update sensor_update: node 1Persistence File:
{"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}} -
@martinhjelmare
{"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}}I can't see anything obviously wrong with the persistence file, except for sketch version being null, although that is not used by HA. Try changing that to "1.0" and restart.
@martinhjelmare
{"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}}Btw, your values are setup for a door sensor and not a switch. Maybe that was your intention?
@martinhjelmare
I Changed the Version, yet there is nothing added to the dashboard.
I used the sample BinarySwitch example sketch of MYS. The Sensor Arduino has a button connected to Pin 3.
I'm relativly new here so maybe I missed something. And I don't know what Values you mean. -
@martinhjelmare
I'm relativly new here so maybe I missed something. And I don't know what Values you mean.Can you post your sketch and the complete log of HA after start? You can censor any sensitive info.
A clarification: In home assistant a switch is something you can turn on/off from home assistant, an actuator. The BinarySwitch example in mysensors examples is something you turn on/off by the node, a sensor.
It should work anyhow, but I was a bit confused at first. :smiley:
The Whole log is:
screenlog.txt
The Sketch is:
BinarySwitchSensor.ino
The Sketch was not modified and should be the same as the one of the MYS download Page.Do I maybe have to add anything to my config.yaml besides the plattform thing?
Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
:anguished: -
Alright then, I started to feel a bit dumb :D
If you need any help let me know!
Thank you for looking into the issue :+1:Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
Update: Bugfix release 0.11.1 is now out.
