  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
    mirko314
    I installed Home-assistant and Setup a MySensor SerialGateWay + MySensor Switch.
    Yet when I start HA It shows this Error:
    16-01-18 17:27:38 homeassistant.components.mysensors: Missing required configuration items in mysensors: gateways
    16-01-18 17:27:38 homeassistant.bootstrap: component mysensors failed to initialize```
    Config:
    mysensors 1:
      gateways:
        - port: '/dev/ttyUSB0'
          persistence_file: 'hass_log/mysensors.json'
      debug: true
      persistence: true
      version: '1.5'
    • M mirko314
      Config:
      mysensors 1:
        gateways:
        debug: true
        persistence: true
        version: '1.5'
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @mirko314
      Hi!
      You should only have one mysensors domain, so remove the "1" after "mysensors" in your config:
      mysensors:
        gateways:
        debug: true
        persistence: true
        version: '1.5'
        mirko314
        @martinhjelmare
        Thank you!
        Seems to Load now :)
        I disabled persistence because I did not seem to need it right now.
        I am getting the following log when I Push the Wireless Button, it seems to work.
        But I dont see any now nodes / Sensor on the Dashboard. Did I forget something?
        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
        INFO:homeassistant.components.mysensors:update sensor_update: node 1
        INFO:homeassistant.components.mysensors:No sketch_name: node 1
        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
        • M mirko314
          @martinhjelmare
          Thank you!
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @mirko314
          This indicates that the gateway hasn't received all presentation messages from node 1. It's missing sketch name for this node.
          If you disable persistence you have to restart your nodes each time you restart home assistant, to resend the presentation messages.
            mirko314
            @martinhjelmare
            Got that worked out, changed the Name in the Persistence File that HA created! :+1:
            But it still does not show up.
            HA Log:
            Persistence File:
            {"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}}
            martinhjelmareM 2 Replies Last reply
            • M mirko314
              @martinhjelmare
              HA Log:
              Persistence File:
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @mirko314
              I can't see anything obviously wrong with the persistence file, except for sketch version being null, although that is not used by HA. Try changing that to "1.0" and restart.
              • M mirko314
                @martinhjelmare
                HA Log:
                Persistence File:
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @mirko314
                Btw, your values are setup for a door sensor and not a switch. Maybe that was your intention?
                  mirko314
                  @martinhjelmare
                  I Changed the Version, yet there is nothing added to the dashboard.
                  I used the sample BinarySwitch example sketch of MYS. The Sensor Arduino has a button connected to Pin 3.
                  I'm relativly new here so maybe I missed something. And I don't know what Values you mean.
                  • M mirko314
                    @martinhjelmare
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @mirko314
                    Can you post your sketch and the complete log of HA after start? You can censor any sensitive info.
                    • martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @mirko314
                      A clarification: In home assistant a switch is something you can turn on/off from home assistant, an actuator. The BinarySwitch example in mysensors examples is something you turn on/off by the node, a sensor.
                      It should work anyhow, but I was a bit confused at first. :smiley:
                        mirko314
                        The Whole log is:
                        screenlog.txt
                        The Sketch is:
                        BinarySwitchSensor.ino
                        The Sketch was not modified and should be the same as the one of the MYS download Page.
                        Do I maybe have to add anything to my config.yaml besides the plattform thing?
                        • martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
                          Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
                          :anguished:
                            mirko314
                            Alright then, I started to feel a bit dumb :D
                            If you need any help let me know!
                            Thank you for looking into the issue :+1:
                            • M mirko314
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @mirko314
                              Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
                              I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
                              • martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                Update: Bugfix release 0.11.1 is now out.
                                  mirko314
                                  Nice!
                                  Thank you, I installed it, works like a charm!
                                  Going to try a HA switch tomorrow!
                                  Are 1-Wire Components like AM2301 Temp-Sensor already supported?
                                  • martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    #21
                                    I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
                                    But I found this post, where the adafruit library is used together with mysensors:
                                    http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
                                    As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                                      mirko314
                                      wrote on last edited by mirko314
                                      #22
                                      Well I will look into, thank you!
                                      I do not know if this is the right place for further problems, if not tell me.
                                      I tried to remote control a relay today
                                      I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                                      Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                                      Log of the Sensor-Arduino Running RelayActuator.ino:
                                      send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                                      send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                      read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      repeater started, id=1, parent=0, distance=1
                                      send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                                      send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                      Log of HA:
                                      INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                      INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                      INFO:homeassistant.components.sensor:Updating sensor entities
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                      INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                                      INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                                      INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                                      INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                                        mirko314
                                        #23
                                        Sorry, I forgot to ask, is it implemented yet? :D
                                        I just scrambled through the code at HA
                                        https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                                        and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                                        • M mirko314
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @mirko314
                                          You should send a value from the node child to set initial state also. I think that's what's missing.
                                          Read my post here:
                                          http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                                          12.5k
