  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
    mirko314
    @martinhjelmare
    Got that worked out, changed the Name in the Persistence File that HA created! :+1:
    But it still does not show up.
    HA Log:
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
    INFO:homeassistant.components.mysensors:update sensor_update: node 1
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
    Persistence File:
    {"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}}
    martinhjelmareM 2 Replies Last reply
    • M mirko314
      @martinhjelmare
      HA Log:
      Persistence File:
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @mirko314
      I can't see anything obviously wrong with the persistence file, except for sketch version being null, although that is not used by HA. Try changing that to "1.0" and restart.
      • M mirko314
        @martinhjelmare
        HA Log:
        Persistence File:
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @mirko314
        Btw, your values are setup for a door sensor and not a switch. Maybe that was your intention?
          mirko314
          @martinhjelmare
          I Changed the Version, yet there is nothing added to the dashboard.
          I used the sample BinarySwitch example sketch of MYS. The Sensor Arduino has a button connected to Pin 3.
          I'm relativly new here so maybe I missed something. And I don't know what Values you mean.
          • M mirko314
            @martinhjelmare
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @mirko314
            Can you post your sketch and the complete log of HA after start? You can censor any sensitive info.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @mirko314
              A clarification: In home assistant a switch is something you can turn on/off from home assistant, an actuator. The BinarySwitch example in mysensors examples is something you turn on/off by the node, a sensor.
              It should work anyhow, but I was a bit confused at first. :smiley:
                mirko314
                The Whole log is:
                screenlog.txt
                The Sketch is:
                BinarySwitchSensor.ino
                The Sketch was not modified and should be the same as the one of the MYS download Page.
                Do I maybe have to add anything to my config.yaml besides the plattform thing?
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
                  Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
                  :anguished:
                    mirko314
                    Alright then, I started to feel a bit dumb :D
                    If you need any help let me know!
                    Thank you for looking into the issue :+1:
                    • M mirko314
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @mirko314
                      Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
                      I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        Update: Bugfix release 0.11.1 is now out.
                          mirko314
                          Nice!
                          Thank you, I installed it, works like a charm!
                          Going to try a HA switch tomorrow!
                          Are 1-Wire Components like AM2301 Temp-Sensor already supported?
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            #21
                            I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
                            But I found this post, where the adafruit library is used together with mysensors:
                            http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
                            As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                              mirko314
                              wrote on last edited by mirko314
                              #22
                              Well I will look into, thank you!
                              I do not know if this is the right place for further problems, if not tell me.
                              I tried to remote control a relay today
                              I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                              Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                              Log of the Sensor-Arduino Running RelayActuator.ino:
                              send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                              send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                              read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                              repeater started, id=1, parent=0, distance=1
                              send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                              send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                              Log of HA:
                              INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                              INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                              INFO:homeassistant.components.sensor:Updating sensor entities
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                              INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                              INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                              INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                              INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                              INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                                mirko314
                                #23
                                Sorry, I forgot to ask, is it implemented yet? :D
                                I just scrambled through the code at HA
                                https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                                and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                                • M mirko314
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @mirko314
                                  You should send a value from the node child to set initial state also. I think that's what's missing.
                                  Read my post here:
                                  http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                                    mirko314
                                    #25
                                    @martinhjelmare
                                    Would you mind to elaborate a bit more?
                                    I am not sure how to alter the script.
                                    • M mirko314
                                      @martinhjelmare
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      #26
                                      @mirko314
                                      For example:
                                      MyMessage msgArray[NUMBER_OF_RELAYS];
                                      for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                                          msgArray[sensor-1] = msg(sensor, V_STATUS);
                                          gw.begin();
                                              gw.present(sensor, S_BINARY);
                                              gw.send(msgArray[sensor-1].set(0));
                                      If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                                      You need to send at least one value per child to populate all data structures in home assistant.
                                      Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                                      • D
                                        drock1985
                                        Hi @martinhjelmare
                                        I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                                        My Projects
                                        2 Door Chime Sensor
                                        Washing Machine Monitor
                                        • D drock1985
                                          Hi @martinhjelmare
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @drock1985
                                          Please show me the home assistant log. I can't really say anything useful without it.
                                          12.5k
