  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • M mirko314
    @martinhjelmare
    Got that worked out, changed the Name in the Persistence File that HA created! :+1:
    But it still does not show up.
    HA Log:
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
    INFO:homeassistant.components.mysensors:update sensor_update: node 1
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
    Persistence File:
    {"1": {"sketch_version": null, "children": {"3": {"type": 0, "values": {"16": "0"}, "id": 3}}, "sketch_name": "testgateway", "battery_level": 0, "sensor_id": 1, "type": 17}}
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @mirko314
    Btw, your values are setup for a door sensor and not a switch. Maybe that was your intention?
      mirko314
      @martinhjelmare
      I Changed the Version, yet there is nothing added to the dashboard.
      I used the sample BinarySwitch example sketch of MYS. The Sensor Arduino has a button connected to Pin 3.
      I'm relativly new here so maybe I missed something. And I don't know what Values you mean.
      • M mirko314
        @martinhjelmare
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @mirko314
        Can you post your sketch and the complete log of HA after start? You can censor any sensitive info.
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @mirko314
          A clarification: In home assistant a switch is something you can turn on/off from home assistant, an actuator. The BinarySwitch example in mysensors examples is something you turn on/off by the node, a sensor.
          It should work anyhow, but I was a bit confused at first. :smiley:
            mirko314
            The Whole log is:
            screenlog.txt
            The Sketch is:
            BinarySwitchSensor.ino
            The Sketch was not modified and should be the same as the one of the MYS download Page.
            Do I maybe have to add anything to my config.yaml besides the plattform thing?
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
              Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
              :anguished:
                mirko314
                Alright then, I started to feel a bit dumb :D
                If you need any help let me know!
                Thank you for looking into the issue :+1:
                • M mirko314
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @mirko314
                  Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
                  I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Update: Bugfix release 0.11.1 is now out.
                      mirko314
                      Nice!
                      Thank you, I installed it, works like a charm!
                      Going to try a HA switch tomorrow!
                      Are 1-Wire Components like AM2301 Temp-Sensor already supported?
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #21
                        I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
                        But I found this post, where the adafruit library is used together with mysensors:
                        http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
                        As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                          mirko314
                          wrote on last edited by mirko314
                          #22
                          Well I will look into, thank you!
                          I do not know if this is the right place for further problems, if not tell me.
                          I tried to remote control a relay today
                          I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                          Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                          Log of the Sensor-Arduino Running RelayActuator.ino:
                          send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                          send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                          read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          repeater started, id=1, parent=0, distance=1
                          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                          send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                          Log of HA:
                          INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                          INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                          INFO:homeassistant.components.sensor:Updating sensor entities
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                          INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                          INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                          INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                          INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                            mirko314
                            #23
                            Sorry, I forgot to ask, is it implemented yet? :D
                            I just scrambled through the code at HA
                            https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                            and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                            • M mirko314
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @mirko314
                              You should send a value from the node child to set initial state also. I think that's what's missing.
                              Read my post here:
                              http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                                mirko314
                                #25
                                @martinhjelmare
                                Would you mind to elaborate a bit more?
                                I am not sure how to alter the script.
                                • M mirko314
                                  @martinhjelmare
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  #26
                                  @mirko314
                                  For example:
                                  MyMessage msgArray[NUMBER_OF_RELAYS];
                                  for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                                      msgArray[sensor-1] = msg(sensor, V_STATUS);
                                      gw.begin();
                                          gw.present(sensor, S_BINARY);
                                          gw.send(msgArray[sensor-1].set(0));
                                  If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                                  You need to send at least one value per child to populate all data structures in home assistant.
                                  Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                                  • D
                                    drock1985
                                    Hi @martinhjelmare
                                    I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                                    My Projects
                                    2 Door Chime Sensor
                                    Washing Machine Monitor
                                    • D drock1985
                                      Hi @martinhjelmare
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      Please show me the home assistant log. I can't really say anything useful without it.
                                      • D
                                        drock1985
                                        Hi @martinhjelmare
                                        here is the output from /home/pi/.homeassistant/home-assistant.log:
                                        6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                                        This is my configuration.yaml
                                        homeassistant:
                                          # Name of the location where Home Assistant is running
                                          # Location required to calculate the time the sun rises and sets
                                          latitude:
                                          longitude:
                                          # C for Celcius, F for Fahrenheit
                                          temperature_unit: C
                                          # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                          time_zone: America/Halifax
                                        # Enables the frontend
                                        frontend:
                                        # Checks for available updates
                                        updater:
                                        # View all events in a logbook
                                        logbook:
                                        # Track the sun
                                        sun:
                                        # Enables support for tracking state changes over time.
                                        history:
                                        # Show links to resources in log and frontend
                                        #introduction:
                                        # Allows you to issue voice commands from the frontend
                                        conversation:
                                        # Discover some devices automatically
                                        discovery:
                                        # Webcams
                                        camera 1:
                                          platform: mjpeg
                                          mjpeg_url: http://192.168.86.117:10012/videofeed
                                          username: root
                                          password: groot
                                        # Squeezebox Server
                                        media_player 1:
                                          platform: squeezebox
                                          host: 192.168.86.113
                                          port: 9090
                                        # MySensors Serial Gateway
                                        mysensors:
                                          gateways:
                                            - port: '/dev/ttyUSB0'
                                              persistence_file: '/home/pi/.homeassistant/mysensors.json'
                                        #  debug: true
                                          persistence: true
                                          version: '1.5'
                                        Would it be because my nodes are set for manual ID and not auto?
                                        My Projects
                                        2 Door Chime Sensor
                                        • D drock1985
                                          Hi @martinhjelmare
                                          homeassistant:
                                            latitude:
                                            longitude:
                                            temperature_unit: C
                                          frontend:
                                          updater:
                                          logbook:
                                          # Track the sun
                                          sun:
                                          history:
                                          #introduction:
                                          conversation:
                                          discovery:
                                          # Webcams
                                          camera 1:
                                            platform: mjpeg
                                            username: root
                                            password: groot
                                          # Squeezebox Server
                                          media_player 1:
                                            port: 9090
                                          mysensors:
                                            gateways:
                                          #  debug: true
                                            persistence: true
                                            version: '1.5'
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @drock1985
                                          The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                                          You should shut down home assistant first if you have it running as a service.
                                          Activate debug first for mysensors though.
                                          12.5k
