  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.4k Views 4 Watching
  • korttomaK
    korttomaK
    korttoma
    Thanks for the example @Anticimex now I know how but it is stil not working when using codebender.
    (personal library file) MySensors/MySensor.h:158:70: error: unknown type name 'MyHwDriver'
    (sketch file) MultiTemp.ino:66:1: error: unknown type name 'MyHwATMega328'
    MyHwATMega328 hw; // Select AtMega328 hardware profile
    I tested now with Arduino IDE 1.6.5 and my sketch compiles just fine.
    • Tomas
    • AnticimexA
      AnticimexA
      Anticimex
      Sorry, I am not very familiar with codebender. It looks to me that the library you try to build with is very out if date if it lacks those hw definitions. I don't know how the library ends up at codebender. Perhaps @hek has some communication with them to support it.
      • carlierdC
        carlierdC
        carlierd
        I tried to compile with 1.5.2 and got these errors:
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
         #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
          if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
         #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
              SET_SIGN(msg.sender);
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
         #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
              CLEAR_SIGN(msg.sender);
        /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
              if (signer.requestSignatures() && DO_SIGN(msg.sender))
        Erreur lors de la compilation.
        No compilation issue with 1.5. And everything is working perfectly.
        David.
        AnticimexA 1 Reply Last reply
          @Anticimex
          Yes, I'll have to update the codebender library manually.
          korttomaK 1 Reply Last reply
          • carlierdC carlierd
            David.
            AnticimexA
            AnticimexA
            Anticimex
            @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
            carlierdC 1 Reply Last reply
            • AnticimexA Anticimex
              carlierdC
              carlierdC
              carlierd
              @Anticimex No problem !! Thanks for the support :)
                @Anticimex
                korttomaK
                korttomaK
                korttoma
                @hek said:
                @Anticimex
                I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
                • Tomas
                • korttomaK korttoma
                  Is there "SOMETHING" missing like this??
                  MySensor gw(transport, SOMETHING);
                  candidate constructor not viable: requires 2 arguments, but 1 was provided
                  How do I define "MyHwDriver"??
                  Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    And you have selected a atmega328-based target when you build?
                      korttomaK
                      korttomaK
                      korttoma
                      I take it you have managed to reproduce the situation or do you need some more information from me?
                      Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
                      • Tomas
                        No, I'm currently @work.
                          @korttoma
                          Updated codebender lib to 1.5.3 and it fails with the same error you got.
                          Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
                          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
                          I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
                          • ferpandoF
                            ferpandoF
                            ferpando
                            I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                            Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                            I'm using IDE 1.6.6
                            It was working before with MySensors 1.5
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              Those warnings are no reason for concern. Everything works like before.
                              ferpandoF 1 Reply Last reply
                                ferpandoF
                                ferpandoF
                                ferpando
                                @Anticimex
                                Ok, but is there a way to remove them?
                                I can confirm it compiles and uploads correctly.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                                    @korttoma
                                    1.5.3 in codebender compiles now.
                                    They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                                    Patched the codebender library (manually defining this) as a workaround until they update their things.
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                                      • Tomas
