  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.0k Views 4 Watching
  • carlierdC
    carlierdC
    carlierd
    I tried to compile with 1.5.2 and got these errors:
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
     #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
      if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
     #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
          SET_SIGN(msg.sender);
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
     #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
          CLEAR_SIGN(msg.sender);
    /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
          if (signer.requestSignatures() && DO_SIGN(msg.sender))
    Erreur lors de la compilation.
    No compilation issue with 1.5. And everything is working perfectly.
    David.
    AnticimexA 1 Reply Last reply
      @Anticimex
      Yes, I'll have to update the codebender library manually.
      korttomaK 1 Reply Last reply
      • carlierdC carlierd
        David.
        AnticimexA
        AnticimexA
        Anticimex
        @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
        carlierdC 1 Reply Last reply
        • AnticimexA Anticimex
          carlierdC
          carlierdC
          carlierd
          @Anticimex No problem !! Thanks for the support :)
            @Anticimex
            korttomaK
            korttomaK
            korttoma
            @hek said:
            @Anticimex
            I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
            • Tomas
            • korttomaK korttoma
              Is there "SOMETHING" missing like this??
              MySensor gw(transport, SOMETHING);
              candidate constructor not viable: requires 2 arguments, but 1 was provided
              How do I define "MyHwDriver"??
              Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
              • AnticimexA
                AnticimexA
                Anticimex
                And you have selected a atmega328-based target when you build?
                  korttomaK
                  korttomaK
                  korttoma
                  I take it you have managed to reproduce the situation or do you need some more information from me?
                  Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
                  • Tomas
                    No, I'm currently @work.
                      @korttoma
                      Updated codebender lib to 1.5.3 and it fails with the same error you got.
                      Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
                      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
                      I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
                      • ferpandoF
                        ferpandoF
                        ferpando
                        I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                        Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                        I'm using IDE 1.6.6
                        It was working before with MySensors 1.5
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          Those warnings are no reason for concern. Everything works like before.
                          ferpandoF 1 Reply Last reply
                            ferpandoF
                            ferpandoF
                            ferpando
                            @Anticimex
                            Ok, but is there a way to remove them?
                            I can confirm it compiles and uploads correctly.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                                @korttoma
                                1.5.3 in codebender compiles now.
                                They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                                Patched the codebender library (manually defining this) as a workaround until they update their things.
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                                  • Tomas
