  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.5k Views 4 Watching
    @Anticimex
    Yes, I'll have to update the codebender library manually.
    korttomaK
    korttomaK
    korttoma
    @hek said:
    @Anticimex
    I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
    • Tomas
    • korttomaK korttoma
      Is there "SOMETHING" missing like this??
      MySensor gw(transport, SOMETHING);
      candidate constructor not viable: requires 2 arguments, but 1 was provided
      How do I define "MyHwDriver"??
      Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
      korttomaK 1 Reply Last reply
      • AnticimexA
        AnticimexA
        Anticimex
        And you have selected a atmega328-based target when you build?
          korttomaK
          korttomaK
          korttoma
          I take it you have managed to reproduce the situation or do you need some more information from me?
          Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
          • Tomas
            No, I'm currently @work.
              @korttoma
              Updated codebender lib to 1.5.3 and it fails with the same error you got.
              Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
              https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
              I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
              • ferpandoF
                ferpandoF
                ferpando
                I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                I'm using IDE 1.6.6
                It was working before with MySensors 1.5
                • AnticimexA
                  AnticimexA
                  Anticimex
                  Those warnings are no reason for concern. Everything works like before.
                  ferpandoF 1 Reply Last reply
                  • AnticimexA Anticimex
                    ferpandoF
                    ferpandoF
                    ferpando
                    @Anticimex
                    Ok, but is there a way to remove them?
                    I can confirm it compiles and uploads correctly.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                        @korttoma
                        1.5.3 in codebender compiles now.
                        They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                        Patched the codebender library (manually defining this) as a workaround until they update their things.
                        • korttomaK
                          korttomaK
                          korttoma
                          @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                          • Tomas
