  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.5k Views 4 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Sorry, I am not very familiar with codebender. It looks to me that the library you try to build with is very out if date if it lacks those hw definitions. I don't know how the library ends up at codebender. Perhaps @hek has some communication with them to support it.
    • carlierdC
      carlierdC
      carlierd
      I tried to compile with 1.5.2 and got these errors:
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
       #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
        if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
       #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
            SET_SIGN(msg.sender);
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
       #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
            CLEAR_SIGN(msg.sender);
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
            if (signer.requestSignatures() && DO_SIGN(msg.sender))
      Erreur lors de la compilation.
      No compilation issue with 1.5. And everything is working perfectly.
      David.
      AnticimexA 1 Reply Last reply
        @Anticimex
        Yes, I'll have to update the codebender library manually.
        korttomaK 1 Reply Last reply
        • carlierdC carlierd
          David.
          AnticimexA
          AnticimexA
          Anticimex
          @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
          carlierdC 1 Reply Last reply
          • AnticimexA Anticimex
            carlierdC
            carlierdC
            carlierd
            @Anticimex No problem !! Thanks for the support :)
              @Anticimex
              korttomaK
              korttomaK
              korttoma
              @hek said:
              @Anticimex
              I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
              • Tomas
              • korttomaK korttoma
                Is there "SOMETHING" missing like this??
                MySensor gw(transport, SOMETHING);
                candidate constructor not viable: requires 2 arguments, but 1 was provided
                How do I define "MyHwDriver"??
                Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
                • AnticimexA
                  AnticimexA
                  Anticimex
                  And you have selected a atmega328-based target when you build?
                    korttomaK
                    korttomaK
                    korttoma
                    I take it you have managed to reproduce the situation or do you need some more information from me?
                    Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
                    • Tomas
                      No, I'm currently @work.
                        @korttoma
                        Updated codebender lib to 1.5.3 and it fails with the same error you got.
                        Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
                        I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
                        • ferpandoF
                          ferpandoF
                          ferpando
                          I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                          Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                          I'm using IDE 1.6.6
                          It was working before with MySensors 1.5
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            Those warnings are no reason for concern. Everything works like before.
                            ferpandoF 1 Reply Last reply
                              ferpandoF
                              ferpandoF
                              ferpando
                              @Anticimex
                              Ok, but is there a way to remove them?
                              I can confirm it compiles and uploads correctly.
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                                  @korttoma
                                  1.5.3 in codebender compiles now.
                                  They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                                  Patched the codebender library (manually defining this) as a workaround until they update their things.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                                    • Tomas
