  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • martinhjelmareM
    martinhjelmareM
    martinhjelmare
    Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
    Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
    :anguished:
      mirko314
      Alright then, I started to feel a bit dumb :D
      If you need any help let me know!
      Thank you for looking into the issue :+1:
      • M mirko314
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @mirko314
        Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
        I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          Update: Bugfix release 0.11.1 is now out.
            mirko314
            Nice!
            Thank you, I installed it, works like a charm!
            Going to try a HA switch tomorrow!
            Are 1-Wire Components like AM2301 Temp-Sensor already supported?
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              #21
              I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
              But I found this post, where the adafruit library is used together with mysensors:
              http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
              As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                mirko314
                wrote on last edited by mirko314
                #22
                Well I will look into, thank you!
                I do not know if this is the right place for further problems, if not tell me.
                I tried to remote control a relay today
                I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                Log of the Sensor-Arduino Running RelayActuator.ino:
                send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                repeater started, id=1, parent=0, distance=1
                send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                Log of HA:
                INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                INFO:homeassistant.components.sensor:Updating sensor entities
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                INFO:homeassistant.components.mysensors:update sensor_update: node 1
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                  mirko314
                  #23
                  Sorry, I forgot to ask, is it implemented yet? :D
                  I just scrambled through the code at HA
                  https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                  and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                  • M mirko314
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @mirko314
                    You should send a value from the node child to set initial state also. I think that's what's missing.
                    Read my post here:
                    http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                      mirko314
                      #25
                      @martinhjelmare
                      Would you mind to elaborate a bit more?
                      I am not sure how to alter the script.
                      • M mirko314
                        @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #26
                        @mirko314
                        For example:
                        MyMessage msgArray[NUMBER_OF_RELAYS];
                        for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                            msgArray[sensor-1] = msg(sensor, V_STATUS);
                            gw.begin();
                                gw.present(sensor, S_BINARY);
                                gw.send(msgArray[sensor-1].set(0));
                        If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                        You need to send at least one value per child to populate all data structures in home assistant.
                        Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                        • D
                          drock1985
                          Hi @martinhjelmare
                          I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                          My Projects
                          2 Door Chime Sensor
                          Washing Machine Monitor
                          • D drock1985
                            Hi @martinhjelmare
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @drock1985
                            Please show me the home assistant log. I can't really say anything useful without it.
                            • D
                              drock1985
                              Hi @martinhjelmare
                              here is the output from /home/pi/.homeassistant/home-assistant.log:
                              6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                              This is my configuration.yaml
                              homeassistant:
                                # Name of the location where Home Assistant is running
                                # Location required to calculate the time the sun rises and sets
                                latitude:
                                longitude:
                                # C for Celcius, F for Fahrenheit
                                temperature_unit: C
                                # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                time_zone: America/Halifax
                              # Enables the frontend
                              frontend:
                              # Checks for available updates
                              updater:
                              # View all events in a logbook
                              logbook:
                              # Track the sun
                              sun:
                              # Enables support for tracking state changes over time.
                              history:
                              # Show links to resources in log and frontend
                              #introduction:
                              # Allows you to issue voice commands from the frontend
                              conversation:
                              # Discover some devices automatically
                              discovery:
                              # Webcams
                              camera 1:
                                platform: mjpeg
                                mjpeg_url: http://192.168.86.117:10012/videofeed
                                username: root
                                password: groot
                              # Squeezebox Server
                              media_player 1:
                                platform: squeezebox
                                host: 192.168.86.113
                                port: 9090
                              # MySensors Serial Gateway
                              mysensors:
                                gateways:
                                  - port: '/dev/ttyUSB0'
                                    persistence_file: '/home/pi/.homeassistant/mysensors.json'
                              #  debug: true
                                persistence: true
                                version: '1.5'
                              Would it be because my nodes are set for manual ID and not auto?
                              My Projects
                              2 Door Chime Sensor
                              • D drock1985
                                Hi @martinhjelmare
                                homeassistant:
                                  latitude:
                                  longitude:
                                  temperature_unit: C
                                frontend:
                                updater:
                                logbook:
                                # Track the sun
                                sun:
                                history:
                                #introduction:
                                conversation:
                                discovery:
                                # Webcams
                                camera 1:
                                  platform: mjpeg
                                  username: root
                                  password: groot
                                # Squeezebox Server
                                media_player 1:
                                  port: 9090
                                mysensors:
                                  gateways:
                                #  debug: true
                                  persistence: true
                                  version: '1.5'
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @drock1985
                                The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                                You should shut down home assistant first if you have it running as a service.
                                Activate debug first for mysensors though.
                                • D
                                  drock1985
                                  @martinhjelmare
                                  Here is the .log file
                                  16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                  And from the SSH console after running hass as instructed
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
                                  INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                                  INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                                  INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                  INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                                  INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                                  INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                  INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                                  INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                                  INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                                  INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
                                  INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                  INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                                  INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                                  INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                  INFO:homeassistant.components.media_player:Updating media_player entities
                                  INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                                  INFO:homeassistant.components.light:Updating light entities
                                  INFO:homeassistant.components.camera:Updating camera entities
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                  INFO:homeassistant.components.mysensors:update sensor_update: node 3
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                                  INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                  My Projects
                                  2 Door Chime Sensor
                                  • D drock1985
                                    @martinhjelmare
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @drock1985
                                    Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
                                    Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
                                    • D
                                      drock1985
                                      Hi @martinhjelmare
                                      the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                                      Is that what you are looking for at the top?
                                      INFO:homeassistant.components.recorder:Closing database
                                      pi@home-assistant:~/.homeassistant $ clear
                                      pi@home-assistant:~/.homeassistant $ hass
                                      Config directory: /home/pi/.homeassistant
                                      WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                      INFO:homeassistant.bootstrap:Home Assistant core initialized
                                      INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                      INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                                      INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                      INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                      INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                      INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                      INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                      INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                      INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                      INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                      INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                      INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                      INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                      INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                      INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                      INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                      INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                      INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                      INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                      /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                        warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                      INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                                      INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                      INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                      INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                      INFO:homeassistant.core:Timer:starting
                                      INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                      INFO:homeassistant.components.mysensors:update persistence: node 2
                                      INFO:homeassistant.components.mysensors:No sketch_name: node 2
                                      INFO:homeassistant.components.mysensors:update persistence: node 3
                                      INFO:netdisco.service:Scanning
                                      WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                      INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                                      INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                                      INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                                      INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                                      INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                                      INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                                      INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                                      INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                      INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                                      ERROR:homeassistant.components.switch:Error while setting up platform wemo
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                          self.hass, platform_config, self.add_entities, discovery_info)
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                          import pywemo.discovery as discovery
                                      AttributeError: 'module' object has no attribute 'discovery'
                                      INFO:pychromecast:Querying device status
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                                      INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                      INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                                      INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                                      INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                                      INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                                      INFO:phue:Attempting to connect to the bridge...
                                      INFO:phue:Using ip: 192.168.86.199
                                      INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                                      Exception in thread Thread-25:
                                        File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                          self.run()
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                                          handler(self.zc)
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                                          state_change=state_change,
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                                          h(**kwargs)
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                                          listener.add_service(*args)
                                        File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                                          service = zconf.get_service_info(typ, name)
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                                          if info.request(self, timeout):
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                                          zc.send(out)
                                        File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                                          bytes_sent = s.sendto(packet, 0, (addr, port))
                                      OSError: [Errno 9] Bad file descriptor
                                      INFO:plexapi:GET http://192.168.86.4:32400/
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                                      INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                                      INFO:plexapi:GET http://192.168.86.4:32400/clients
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                      INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                                      INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                                      INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                                      INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                                      INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                                      INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                                      INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                                      INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                                      ^CINFO:homeassistant.core:Stopping
                                      INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                      INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                                      INFO:mysensors.mysensors:Stopping thread
                                      My Projects
                                      2 Door Chime Sensor
                                      • D
                                        drock1985
                                        I'm still trying to get this to work, with mixed results. Noticed on startup sometimes that HA was starting before my Serial port was initialized. Added a .timer file to delay the start of HA until the Pi is fully booted. Still having problems, but now i'm getting this in the HA logs:
                                        16-01-24 18:37:40 homeassistant.core: BusHandler:Exception doing job
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 829, in job_handler
                                            func(arg)
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 302, in onetime_listener
                                            listener(event)
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 104, in gw_start
                                            gateway.event_callback('persistence', node_id)
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                                            callback(self, node_id)
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                                            add_devices(devices[node_id])
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                                            entity.update_ha_state()
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                                            self.unit_of_measurement is not None:
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                                            self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                                          File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                                            raise AttributeError(name) from None
                                        AttributeError: V_PERCENTAGE
                                        16-01-24 18:37:43 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                        My Projects
                                        2 Door Chime Sensor
                                        • D drock1985
                                              func(arg)
                                              listener(event)
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @drock1985
                                          I think you need to delete the persistence file and start over and present your sensors. You should do this while looking at the output from hass so you get feedback if it's working or not.
                                          From the top of your log output there was a warning about bad byte from the gateway. The gateway started confirmation was never logged. You should see this before you start your sensors. If you don't get the gateway confirmation, try restarting home assistant.
                                          Also in the log, the persistence file loaded sensor 2 and 3, but some data was missing, probably. There was a note about missing sketch name for one of the sensors.
                                          You need to present the sensors properly, including sketch name and then send one value per sensor before they show up in the gui.
                                          12.5k
