  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
    mirko314
    The Whole log is:
    screenlog.txt
    The Sketch is:
    BinarySwitchSensor.ino
    The Sketch was not modified and should be the same as the one of the MYS download Page.
    Do I maybe have to add anything to my config.yaml besides the plattform thing?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
      Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
      :anguished:
        mirko314
        Alright then, I started to feel a bit dumb :D
        If you need any help let me know!
        Thank you for looking into the issue :+1:
        • M mirko314
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @mirko314
          Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
          I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            Update: Bugfix release 0.11.1 is now out.
              mirko314
              Nice!
              Thank you, I installed it, works like a charm!
              Going to try a HA switch tomorrow!
              Are 1-Wire Components like AM2301 Temp-Sensor already supported?
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                #21
                I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
                But I found this post, where the adafruit library is used together with mysensors:
                http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
                As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                  mirko314
                  wrote on last edited by mirko314
                  #22
                  Well I will look into, thank you!
                  I do not know if this is the right place for further problems, if not tell me.
                  I tried to remote control a relay today
                  I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                  Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                  Log of the Sensor-Arduino Running RelayActuator.ino:
                  send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                  send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                  read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  repeater started, id=1, parent=0, distance=1
                  send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                  send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                  Log of HA:
                  INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                  INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                  INFO:homeassistant.components.sensor:Updating sensor entities
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                  INFO:homeassistant.components.mysensors:update sensor_update: node 1
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                  INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                  INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                  INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                  INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                    mirko314
                    #23
                    Sorry, I forgot to ask, is it implemented yet? :D
                    I just scrambled through the code at HA
                    https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                    and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                    • M mirko314
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @mirko314
                      You should send a value from the node child to set initial state also. I think that's what's missing.
                      Read my post here:
                      http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                        mirko314
                        #25
                        @martinhjelmare
                        Would you mind to elaborate a bit more?
                        I am not sure how to alter the script.
                        • M mirko314
                          @martinhjelmare
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          #26
                          @mirko314
                          For example:
                          MyMessage msgArray[NUMBER_OF_RELAYS];
                          for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                              msgArray[sensor-1] = msg(sensor, V_STATUS);
                              gw.begin();
                                  gw.present(sensor, S_BINARY);
                                  gw.send(msgArray[sensor-1].set(0));
                          If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                          You need to send at least one value per child to populate all data structures in home assistant.
                          Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                          • D
                            drock1985
                            Hi @martinhjelmare
                            I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                            My Projects
                            2 Door Chime Sensor
                            Washing Machine Monitor
                            • D drock1985
                              Hi @martinhjelmare
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @drock1985
                              Please show me the home assistant log. I can't really say anything useful without it.
                              • D
                                drock1985
                                Hi @martinhjelmare
                                here is the output from /home/pi/.homeassistant/home-assistant.log:
                                6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                                This is my configuration.yaml
                                homeassistant:
                                  # Name of the location where Home Assistant is running
                                  # Location required to calculate the time the sun rises and sets
                                  latitude:
                                  longitude:
                                  # C for Celcius, F for Fahrenheit
                                  temperature_unit: C
                                  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                  time_zone: America/Halifax
                                # Enables the frontend
                                frontend:
                                # Checks for available updates
                                updater:
                                # View all events in a logbook
                                logbook:
                                # Track the sun
                                sun:
                                # Enables support for tracking state changes over time.
                                history:
                                # Show links to resources in log and frontend
                                #introduction:
                                # Allows you to issue voice commands from the frontend
                                conversation:
                                # Discover some devices automatically
                                discovery:
                                # Webcams
                                camera 1:
                                  platform: mjpeg
                                  mjpeg_url: http://192.168.86.117:10012/videofeed
                                  username: root
                                  password: groot
                                # Squeezebox Server
                                media_player 1:
                                  platform: squeezebox
                                  host: 192.168.86.113
                                  port: 9090
                                # MySensors Serial Gateway
                                mysensors:
                                  gateways:
                                    - port: '/dev/ttyUSB0'
                                      persistence_file: '/home/pi/.homeassistant/mysensors.json'
                                #  debug: true
                                  persistence: true
                                  version: '1.5'
                                Would it be because my nodes are set for manual ID and not auto?
                                My Projects
                                2 Door Chime Sensor
                                • D drock1985
                                  Hi @martinhjelmare
                                  homeassistant:
                                    latitude:
                                    longitude:
                                    temperature_unit: C
                                  frontend:
                                  updater:
                                  logbook:
                                  # Track the sun
                                  sun:
                                  history:
                                  #introduction:
                                  conversation:
                                  discovery:
                                  # Webcams
                                  camera 1:
                                    platform: mjpeg
                                    username: root
                                    password: groot
                                  # Squeezebox Server
                                  media_player 1:
                                    port: 9090
                                  mysensors:
                                    gateways:
                                  #  debug: true
                                    persistence: true
                                    version: '1.5'
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @drock1985
                                  The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                                  You should shut down home assistant first if you have it running as a service.
                                  Activate debug first for mysensors though.
                                  • D
                                    drock1985
                                    @martinhjelmare
                                    Here is the .log file
                                    16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                    And from the SSH console after running hass as instructed
                                    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                                    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
                                    INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                                    INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                                    INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                    INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                                    INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                                    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                    INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                                    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                                    INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                                    INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
                                    INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                                    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                                    INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                                    INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                                    INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                                    INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                                    INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                                    INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                    INFO:homeassistant.components.media_player:Updating media_player entities
                                    INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                                    INFO:homeassistant.components.light:Updating light entities
                                    INFO:homeassistant.components.camera:Updating camera entities
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                    INFO:homeassistant.components.mysensors:update sensor_update: node 3
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                                    INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                    My Projects
                                    2 Door Chime Sensor
                                    • D drock1985
                                      @martinhjelmare
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
                                      Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
                                      • D
                                        drock1985
                                        Hi @martinhjelmare
                                        the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                                        Is that what you are looking for at the top?
                                        INFO:homeassistant.components.recorder:Closing database
                                        pi@home-assistant:~/.homeassistant $ clear
                                        pi@home-assistant:~/.homeassistant $ hass
                                        Config directory: /home/pi/.homeassistant
                                        WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                        INFO:homeassistant.bootstrap:Home Assistant core initialized
                                        INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                        INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                                        INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                        INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                        INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                        INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                        INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                        INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                        INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                        INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                        INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                        INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                        INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                        INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                        INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                        INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                        INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                        INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                        INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                        /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                          warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                        INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                                        INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                        INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                        INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                        INFO:homeassistant.core:Timer:starting
                                        INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                        INFO:homeassistant.components.mysensors:update persistence: node 2
                                        INFO:homeassistant.components.mysensors:No sketch_name: node 2
                                        INFO:homeassistant.components.mysensors:update persistence: node 3
                                        INFO:netdisco.service:Scanning
                                        WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                        INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                                        INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                                        INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                                        INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                                        INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                                        INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                                        INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                                        INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                        INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                                        ERROR:homeassistant.components.switch:Error while setting up platform wemo
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                            self.hass, platform_config, self.add_entities, discovery_info)
                                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                            import pywemo.discovery as discovery
                                        AttributeError: 'module' object has no attribute 'discovery'
                                        INFO:pychromecast:Querying device status
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                                        INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                        INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                                        INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                                        INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                                        INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                                        INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                                        INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                                        INFO:phue:Attempting to connect to the bridge...
                                        INFO:phue:Using ip: 192.168.86.199
                                        INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                                        Exception in thread Thread-25:
                                          File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                            self.run()
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                                            handler(self.zc)
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                                            state_change=state_change,
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                                            h(**kwargs)
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                                            listener.add_service(*args)
                                          File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                                            service = zconf.get_service_info(typ, name)
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                                            if info.request(self, timeout):
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                                            zc.send(out)
                                          File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                                            bytes_sent = s.sendto(packet, 0, (addr, port))
                                        OSError: [Errno 9] Bad file descriptor
                                        INFO:plexapi:GET http://192.168.86.4:32400/
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                                        INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                                        INFO:plexapi:GET http://192.168.86.4:32400/clients
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                        INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                                        INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                                        INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                                        INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                                        INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                                        INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                                        INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                                        INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                                        INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                                        INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                                        INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                                        INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                                        INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                                        ^CINFO:homeassistant.core:Stopping
                                        INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                        INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                                        INFO:mysensors.mysensors:Stopping thread
                                        My Projects
                                        2 Door Chime Sensor
                                        • D
                                          drock1985
                                          I'm still trying to get this to work, with mixed results. Noticed on startup sometimes that HA was starting before my Serial port was initialized. Added a .timer file to delay the start of HA until the Pi is fully booted. Still having problems, but now i'm getting this in the HA logs:
                                          16-01-24 18:37:40 homeassistant.core: BusHandler:Exception doing job
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 829, in job_handler
                                              func(arg)
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 302, in onetime_listener
                                              listener(event)
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 104, in gw_start
                                              gateway.event_callback('persistence', node_id)
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                                              callback(self, node_id)
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                                              add_devices(devices[node_id])
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                                              entity.update_ha_state()
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                                              self.unit_of_measurement is not None:
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                                              self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                                            File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                                              raise AttributeError(name) from None
                                          AttributeError: V_PERCENTAGE
                                          16-01-24 18:37:43 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                          My Projects
                                          2 Door Chime Sensor
                                          12.5k
