  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @mirko314
    A clarification: In home assistant a switch is something you can turn on/off from home assistant, an actuator. The BinarySwitch example in mysensors examples is something you turn on/off by the node, a sensor.
    It should work anyhow, but I was a bit confused at first. :smiley:
      mirko314
      The Whole log is:
      screenlog.txt
      The Sketch is:
      BinarySwitchSensor.ino
      The Sketch was not modified and should be the same as the one of the MYS download Page.
      Do I maybe have to add anything to my config.yaml besides the plattform thing?
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        Unfortunately, I've realized this is a bug caused by me. There will be a bugfix release soon, so I hope we can have a fix for this in there. Sorry for the inconvenience!
        Right now the binary sensors are missing in the sensor platform. I think it's due to me planning to do a binary sensor platform, but then changing my mind, and posponing that. Again sorry!
        :anguished:
          mirko314
          Alright then, I started to feel a bit dumb :D
          If you need any help let me know!
          Thank you for looking into the issue :+1:
          • M mirko314
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @mirko314
            Thanks for testing and reporting the problem. All feedback is very welcome and important, cause even though I try to test most scenarios, it's easy to miss something. In this case, though, I feel a bit embarrassed. :flushed:
            I've submitted a tested pull request which fixes this, and it has already been merged. Hopefully the bugfix release will be live very soon.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Update: Bugfix release 0.11.1 is now out.
                mirko314
                Nice!
                Thank you, I installed it, works like a charm!
                Going to try a HA switch tomorrow!
                Are 1-Wire Components like AM2301 Temp-Sensor already supported?
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  #21
                  I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
                  But I found this post, where the adafruit library is used together with mysensors:
                  http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
                  As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
                    mirko314
                    wrote on last edited by mirko314
                    #22
                    Well I will look into, thank you!
                    I do not know if this is the right place for further problems, if not tell me.
                    I tried to remote control a relay today
                    I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                    Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
                    Log of the Sensor-Arduino Running RelayActuator.ino:
                    send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    repeater started, id=1, parent=0, distance=1
                    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                    send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                    Log of HA:
                    INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                    INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                    INFO:homeassistant.components.sensor:Updating sensor entities
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                    INFO:homeassistant.components.mysensors:update sensor_update: node 1
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                    INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
                    INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
                    INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
                    INFO:homeassistant.components.mysensors:update sensor_update: node 1```
                      mirko314
                      #23
                      Sorry, I forgot to ask, is it implemented yet? :D
                      I just scrambled through the code at HA
                      https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
                      and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
                      • M mirko314
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @mirko314
                        You should send a value from the node child to set initial state also. I think that's what's missing.
                        Read my post here:
                        http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
                          mirko314
                          #25
                          @martinhjelmare
                          Would you mind to elaborate a bit more?
                          I am not sure how to alter the script.
                          • M mirko314
                            @martinhjelmare
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            #26
                            @mirko314
                            For example:
                            MyMessage msgArray[NUMBER_OF_RELAYS];
                            for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                                msgArray[sensor-1] = msg(sensor, V_STATUS);
                                gw.begin();
                                    gw.present(sensor, S_BINARY);
                                    gw.send(msgArray[sensor-1].set(0));
                            If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
                            You need to send at least one value per child to populate all data structures in home assistant.
                            Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
                            • D
                              drock1985
                              Hi @martinhjelmare
                              I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                              My Projects
                              2 Door Chime Sensor
                              Washing Machine Monitor
                              • D drock1985
                                Hi @martinhjelmare
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @drock1985
                                Please show me the home assistant log. I can't really say anything useful without it.
                                • D
                                  drock1985
                                  Hi @martinhjelmare
                                  here is the output from /home/pi/.homeassistant/home-assistant.log:
                                  6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                                  This is my configuration.yaml
                                  homeassistant:
                                    # Name of the location where Home Assistant is running
                                    # Location required to calculate the time the sun rises and sets
                                    latitude:
                                    longitude:
                                    # C for Celcius, F for Fahrenheit
                                    temperature_unit: C
                                    # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                    time_zone: America/Halifax
                                  # Enables the frontend
                                  frontend:
                                  # Checks for available updates
                                  updater:
                                  # View all events in a logbook
                                  logbook:
                                  # Track the sun
                                  sun:
                                  # Enables support for tracking state changes over time.
                                  history:
                                  # Show links to resources in log and frontend
                                  #introduction:
                                  # Allows you to issue voice commands from the frontend
                                  conversation:
                                  # Discover some devices automatically
                                  discovery:
                                  # Webcams
                                  camera 1:
                                    platform: mjpeg
                                    mjpeg_url: http://192.168.86.117:10012/videofeed
                                    username: root
                                    password: groot
                                  # Squeezebox Server
                                  media_player 1:
                                    platform: squeezebox
                                    host: 192.168.86.113
                                    port: 9090
                                  # MySensors Serial Gateway
                                  mysensors:
                                    gateways:
                                      - port: '/dev/ttyUSB0'
                                        persistence_file: '/home/pi/.homeassistant/mysensors.json'
                                  #  debug: true
                                    persistence: true
                                    version: '1.5'
                                  Would it be because my nodes are set for manual ID and not auto?
                                  My Projects
                                  2 Door Chime Sensor
                                  • D drock1985
                                    Hi @martinhjelmare
                                    homeassistant:
                                      latitude:
                                      longitude:
                                      temperature_unit: C
                                    frontend:
                                    updater:
                                    logbook:
                                    # Track the sun
                                    sun:
                                    history:
                                    #introduction:
                                    conversation:
                                    discovery:
                                    # Webcams
                                    camera 1:
                                      platform: mjpeg
                                      username: root
                                      password: groot
                                    # Squeezebox Server
                                    media_player 1:
                                      port: 9090
                                    mysensors:
                                      gateways:
                                    #  debug: true
                                      persistence: true
                                      version: '1.5'
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @drock1985
                                    The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                                    You should shut down home assistant first if you have it running as a service.
                                    Activate debug first for mysensors though.
                                    • D
                                      drock1985
                                      @martinhjelmare
                                      Here is the .log file
                                      16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                                      And from the SSH console after running hass as instructed
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
                                      INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                                      INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                                      INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                                      INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                                      INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                                      INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                      INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                                      INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                                      INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                                      INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
                                      INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                                      INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                                      INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                                      INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                      INFO:homeassistant.components.media_player:Updating media_player entities
                                      INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                                      INFO:homeassistant.components.light:Updating light entities
                                      INFO:homeassistant.components.camera:Updating camera entities
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                      INFO:homeassistant.components.mysensors:update sensor_update: node 3
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                                      INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                                      My Projects
                                      2 Door Chime Sensor
                                      • D drock1985
                                        @martinhjelmare
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @drock1985
                                        Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
                                        Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
                                        • D
                                          drock1985
                                          Hi @martinhjelmare
                                          the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                                          Is that what you are looking for at the top?
                                          INFO:homeassistant.components.recorder:Closing database
                                          pi@home-assistant:~/.homeassistant $ clear
                                          pi@home-assistant:~/.homeassistant $ hass
                                          Config directory: /home/pi/.homeassistant
                                          WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                          INFO:homeassistant.bootstrap:Home Assistant core initialized
                                          INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                          INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                                          INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                          INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                          INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                          INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                          INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                          INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                          INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                          INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                          INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                          INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                          INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                          INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                          INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                          INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                          INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                          INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                          INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                          /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                            warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                          INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                                          INFO:homeassistant.core:Starting Home Assistant (17 threads)
                                          INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                          INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                          INFO:homeassistant.core:Timer:starting
                                          INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                          INFO:homeassistant.components.mysensors:update persistence: node 2
                                          INFO:homeassistant.components.mysensors:No sketch_name: node 2
                                          INFO:homeassistant.components.mysensors:update persistence: node 3
                                          INFO:netdisco.service:Scanning
                                          WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                                          INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                                          INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                                          INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                                          INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                                          INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                                          INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                                          INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                                          INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                          INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                                          ERROR:homeassistant.components.switch:Error while setting up platform wemo
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                              self.hass, platform_config, self.add_entities, discovery_info)
                                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                              import pywemo.discovery as discovery
                                          AttributeError: 'module' object has no attribute 'discovery'
                                          INFO:pychromecast:Querying device status
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                                          INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                          INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                                          INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                                          INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                                          INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                                          INFO:phue:Attempting to connect to the bridge...
                                          INFO:phue:Using ip: 192.168.86.199
                                          INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                                          Exception in thread Thread-25:
                                            File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                              self.run()
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                                              handler(self.zc)
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                                              state_change=state_change,
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                                              h(**kwargs)
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                                              listener.add_service(*args)
                                            File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                                              service = zconf.get_service_info(typ, name)
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                                              if info.request(self, timeout):
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                                              zc.send(out)
                                            File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                                              bytes_sent = s.sendto(packet, 0, (addr, port))
                                          OSError: [Errno 9] Bad file descriptor
                                          INFO:plexapi:GET http://192.168.86.4:32400/
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                                          INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                                          INFO:plexapi:GET http://192.168.86.4:32400/clients
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                                          INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                                          INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                                          INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                                          INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                                          INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                                          INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                                          INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                                          INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                                          INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                                          INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                                          INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                                          INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                                          INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                                          ^CINFO:homeassistant.core:Stopping
                                          INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                          INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                                          INFO:mysensors.mysensors:Stopping thread
                                          My Projects
                                          2 Door Chime Sensor
                                          12.5k
