  3. Sensebender Micro + button
sensebendersensebender micbutton
27 Posts 5 Posters 11.1k Views 8 Watching
  • Pierre PP Offline
    Pierre PP Offline
    Pierre P
    Hello all !
    I like the way that this sketch: https://www.mysensors.org/hardware/micro work with Jeedom.
    And I need a bell button that doesn't need a batterie per month.
    So i've tried to mix with this sketch: https://www.mysensors.org/build/binary
    But it's a fail. It only show the data once.
    The button is in D3. I may use D4 latter (as a secret button maybe). By using D3, we can use the ftdi port to power the circuit, and to cable the button. But then, i want to see how many time a button-cell can be used.
    so:
    0_1453483204520_IMG_20160122_162415-2.jpg 0_1453483211180_IMG_20160122_163324-2.jpg
    How to use the interrupt fonction to wake up when pressing the button, and have a 10 minutes wake-up if no press ?
    (And yeah, i could take off all the serial part)
    Thanks for helping !
    ps: can't we write down the code ? It may be a bug from the forum but i can't go down...
     * Version 1.0 - Henrik Ekblad
    #include <SI7021.h>
    #include "utility/SPIFlash.h"
    #include <EEPROM.h>
    #include <sha204_lib_return_codes.h>
    #include <sha204_library.h>
    #include <RunningAverage.h>
    #include <avr/power.h>
    // Define a static node address, remove if you want auto address assignment
    //#define NODE_ADDRESS   3
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    //#define BATT_SENSOR    199
    #define RELEASE "1.2"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    #define MEASURE_INTERVAL 600000
    #define FORCE_TRANSMIT_INTERVAL 30
    #define HUMI_TRANSMIT_THRESHOLD 1
    #define TEMP_TRANSMIT_THRESHOLD 1
    // Pin definitions
    #define TEST_PIN       A0
    #define LED_PIN        A2
    #define ATSHA204_PIN   17 // A3
    #define CHILD_ID_BP 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    //#define CHILD_ID 4
    //#define BUTTON_PIN  4  // Arduino Digital I/O pin for button/reed switch
    const int sha204Pin = ATSHA204_PIN;
    SI7021 humiditySensor;
    SPIFlash flash(8, 0x1F65);
    // Sensor messages
    MyMessage msgBP(CHILD_ID_BP,V_TRIPPED);
    Bounce debouncer = Bounce();
    int oldValue=-1;
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    float lastTemperature = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      Serial.print(RELEASE);
      Serial.flush();
      // First check if we should boot into test mode
      pinMode(TEST_PIN,INPUT);
      digitalWrite(TEST_PIN, HIGH); // Enable pullup
      if (!digitalRead(TEST_PIN)) testMode();
      // Make sure that ATSHA204 is not floating
      pinMode(ATSHA204_PIN, INPUT);
      digitalWrite(ATSHA204_PIN, HIGH);
      digitalWrite(TEST_PIN,LOW);
      digitalWrite(LED_PIN, HIGH);
    #ifdef NODE_ADDRESS
      gw.begin(NULL, NODE_ADDRESS, false);
      gw.begin(NULL,AUTO,false);
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      humiditySensor.begin();
      Serial.flush();
      gw.sendSketchInfo("Sensebender Micro", RELEASE);
      gw.present(CHILD_ID_TEMP,S_TEMP);
      gw.present(CHILD_ID_HUM,S_HUM);
      gw.present(CHILD_ID_BP, S_DOOR);
    #ifdef BATT_SENSOR
      gw.present(BATT_SENSOR, S_POWER);
      isMetric = gw.getConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
     *  Main loop function
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
        highfreq = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
      if (sendBattery > 60)
         sendBattLevel(forceTransmit); // Not needed to send battery info that often
         sendBattery = 0;
    // début du rajout
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msgBP.set(value==HIGH ? 1 : 0));
         oldValue = value;
    // fin du rajout
      gw.sleep(MEASURE_INTERVAL);
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      float oldAvgHum = raHum.getAverage();
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100);
      float diffHum = abs(oldAvgHum - raHum.getAverage());
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        gw.send(msgTemp.set(temperature,1));
        gw.send(msgHum.set(humidity));
        lastHumidity = humidity;
     * Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        gw.send(msgBatt.set(vcc));
        // Calculate percentage
        long percent = vcc / 14.0;
        gw.sendBatteryLevel(percent);
    long readVcc() {
     * Verify all peripherals, and signal via the LED if any problems.
    void testMode()
      uint8_t ret_code;
      byte tests = 0;
      digitalWrite(LED_PIN, HIGH); // Turn on LED.
      Serial.println(F(" - TestMode"));
      Serial.println(F("Testing peripherals!"));
      Serial.flush();
      Serial.print(F("-> SI7021 : "));
      Serial.flush();
      if (humiditySensor.begin())
        Serial.println(F("ok!"));
        tests ++;
        Serial.println(F("failed!"));
      Serial.flush();
      Serial.print(F("-> Flash : "));
      Serial.flush();
      if (flash.initialize())
        tests ++;
      Serial.flush();
      Serial.print(F("-> SHA204 : "));
      Serial.flush();
      if (ret_code != SHA204_SUCCESS)
        Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
      Serial.flush();
      if (ret_code == SHA204_SUCCESS)
        ret_code = sha204.getSerialNumber(rx_buffer);
          Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
          Serial.print(F("Ok (serial : "));
          for (int i=0; i<9; i++)
            if (rx_buffer[i] < 0x10)
            Serial.print(rx_buffer[i], HEX);
          Serial.println(")");
          tests ++;
      Serial.flush();
      Serial.println(F("Test finished"));
      if (tests == 3)
        Serial.println(F("Selftest ok!"));
        while (1) // Blink OK pattern!
          delay(200);
          delay(200);
        Serial.println(F("----> Selftest failed!"));
        while (1) // Blink FAILED pattern! Rappidly blinking..
    No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
    • martinhjelmareM Offline
      martinhjelmare
      Hi!
      Regarding the scrolling not working while in edit, yeah, I experiencing that also. I'm on Chrome 47, Ubuntu. I always have to edit in full screen.
      This is my sketch for a sensebender connected to my door bell:
      2016-02-29: Updated sketch to fix bug in siVolt calculation and set max vcc to 3.2 V.
       * Version 1.0 - Thomas Bowman Mørch
       * Version 1.3 - Thomas Bowman Mørch
       * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
       * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
       * MODIFIED by Martin Hjelmare
       * Sensebender Micro default sketch with addition of binary switch and interrupt,
       * taken from Patrick 'Anticimex' Fallberg's sketch BinarySwitchSleepSensor.
       * Also fixed the bug with the diff calculation for the temperature, and changed
       * vcc 100% rating to 3V, instead of 3.3V.
      #include <SI7021.h>
      #include <EEPROM.h>
      //#include <avr/power.h>
      #define NODE_ADDRESS   1
      #define RELEASE "1.3"
      #define AVERAGES 2
      // How many milli seconds should we wait for OTA?
      #define OTA_WAIT_PERIOD 300
      #define TEMP_TRANSMIT_THRESHOLD 1.0
      // Pin definitions
      #define TEST_PIN       A0
      #define OTA_ENABLE     A1
      #define LED_PIN        A2
      // Sensor messages
      #ifdef BATT_SENSOR
      #define CHILD_ID_BUTTON 3
      #if (BUTTON_PIN < 2 || BUTTON_PIN > 3)
      #error BUTTON_PIN must be either 2 or 3 for interrupts to work
      MyMessage msg(CHILD_ID_BUTTON, V_TRIPPED);
      // Global settings
      boolean ota_enabled = false;
      boolean transmission_occured = false;
      int oldValue = -1;
       * Setup code
        Serial.flush();
        pinMode(TEST_PIN,INPUT_PULLUP);
        //digitalWrite(TEST_PIN, HIGH); // Enable pullup
        pinMode(OTA_ENABLE, INPUT);
        digitalWrite(OTA_ENABLE, HIGH);
        if (!digitalRead(OTA_ENABLE)) {
          ota_enabled = true;
        digitalWrite(OTA_ENABLE, LOW); // remove pullup, save some power.
        // Setup the button
        pinMode(BUTTON_PIN, INPUT_PULLUP);
      #ifdef NODE_ADDRESS
        Serial.flush();
        gw.sendSketchInfo("Sensebender Micro Bell", RELEASE);
      #ifdef BATT_SENSOR
        gw.present(BATT_SENSOR, S_MULTIMETER);
        gw.present(CHILD_ID_BUTTON, S_DOOR);
        raHum.clear();
        if (ota_enabled) Serial.println("OTA FW update enabled");
        measureCount ++;
        sendBattery ++;
          if (!ota_enabled) clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
          highfreq = false;
          measureCount = 0;
           sendBattery = 0;
        if (ota_enabled & transmission_occured) {
            gw.wait(OTA_WAIT_PERIOD);
        gw.sleep(5);
        int buttonValue = digitalRead(BUTTON_PIN);
        if (buttonValue != oldValue) {
           // Send in the new buttonValue
           gw.send(msg.set(buttonValue==HIGH ? 0 : 1));
           oldValue = buttonValue;
        gw.sleep(BUTTON_PIN-2, CHANGE, MEASURE_INTERVAL);
       * Parameters
        bool tx = force;
        float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
        if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
        if (tx) {
          measureCount = 0;
          transmission_occured = true;
       * Parameters
          lastBattery = vcc;
        float siVolt = vcc / 1000.0;
      #ifdef BATT_SENSOR
          gw.send(msgBatt.set(siVolt, 2));
          vcc = min(vcc, 3200L); // vcc max is 3200
          long percent = vcc / 13.0;
      long readVcc() {
      void testMode()
        uint8_t ret_code;
        byte tests = 0;
        Serial.flush();
        Serial.flush();
          tests ++;
        Serial.flush();
        Serial.flush();
          tests ++;
        Serial.flush();
        Serial.flush();
        Serial.flush();
            tests ++;
        Serial.flush();
        if (tests == 3)
            delay(200);
            delay(200);
      Pierre PP 1 Reply Last reply
      • Pierre PP Offline
        Pierre PP Offline
        Pierre P
        Thanks a lot !
        There is many improvements between the very first sketch !
        And with OTA... Thanks !
          Hi!
          #include <SI7021.h>
          #include <EEPROM.h>
          #define AVERAGES 2
          // Pin definitions
          #define TEST_PIN       A0
          #define LED_PIN        A2
          // Sensor messages
          #ifdef BATT_SENSOR
          // Global settings
          int oldValue = -1;
           * Setup code
            Serial.flush();
              ota_enabled = true;
            // Setup the button
          #ifdef NODE_ADDRESS
            Serial.flush();
          #ifdef BATT_SENSOR
            raHum.clear();
            measureCount ++;
            sendBattery ++;
              highfreq = false;
              measureCount = 0;
               sendBattery = 0;
            gw.sleep(5);
           * Parameters
            bool tx = force;
            if (tx) {
              measureCount = 0;
           * Parameters
              lastBattery = vcc;
          #ifdef BATT_SENSOR
          long readVcc() {
          void testMode()
            uint8_t ret_code;
            byte tests = 0;
            Serial.flush();
            Serial.flush();
              tests ++;
            Serial.flush();
            Serial.flush();
              tests ++;
            Serial.flush();
            Serial.flush();
            Serial.flush();
                tests ++;
            Serial.flush();
            if (tests == 3)
                delay(200);
                delay(200);
          Pierre PP Offline
          Pierre PP Offline
          Pierre P
          @martinhjelmare there is a bug (for code bender and arduinoUI). It doesn't like siVolt. '"siVolt' was not declared in this scope"
          your code:
           * Parameters
              lastBattery = vcc;
            siVolt = vcc / 1000;
          #ifdef BATT_SENSOR
              gw.send(msgBatt.set(siVolt));
              vcc = min(vcc, 3000L); // vcc max is 3000
              long percent = vcc / 11.0;
          old code
           * Parameters
              lastBattery = vcc;
          #ifdef BATT_SENSOR
          How did you compil ?
          tbowmoT 1 Reply Last reply
          • Pierre PP Pierre P
            your code:
             * Parameters
                lastBattery = vcc;
            #ifdef BATT_SENSOR
            old code
             * Parameters
                lastBattery = vcc;
            #ifdef BATT_SENSOR
            tbowmoT Offline
            tbowmoT Offline
            tbowmo
            @Pierre-P
            You just need to declare siVolt as a float type
            float siVolt = vcc/100;
            #ifdef....
            • tbowmoT tbowmo
              @Pierre-P
              #ifdef....
              Pierre PP Offline
              Pierre PP Offline
              Pierre P
              @tbowmo "call of overloaded 'set(float&)' is ambiguous"
              I don't know what it mean.
              And i don't know why the very first sketch is working for you and not for me ! :sweat_smile:
               * Parameters
                  lastBattery = vcc;
                  float siVolt = vcc / 1000;
              #ifdef BATT_SENSOR
              /*******************************************f```
                 * Parameters
                    lastBattery = vcc;
                #ifdef BATT_SENSOR
                martinhjelmare
                @Pierre-P
                Sorry that was my addition and I haven't actually tested the siVolt thing yet. Everything else works though. But I don't see why it shouldn't work if you declare it properly first.
                • Pierre PP Offline
                  Pierre PP Offline
                  Pierre P
                  wrote on last edited by Pierre P
                  BATT_SENSOR si declared.
                  ... I think msgBatt is not.
                  Does it should be here ?
                  // Sensor messages
                  Wait not it's just under:
                  #ifdef BATT_SENSOR
                    // Sensor messages
                    #ifdef BATT_SENSOR
                    martinhjelmare
                    @Pierre-P
                    It's declared three lines below, inside the ifdefine.
                    Try declaring siVolt outside the if block in the battery function.
                    Edit: Scrap the last suggestion.
                    • Pierre PP Offline
                      Pierre PP Offline
                      Pierre P
                      If I undefine: //#define BATT_SENSOR 199
                      it's working.
                      But your code still not 100% so we have to find why.
                      But... but, i think i'm making a mistake: yes i plan to use 3volts power. But, i don't want it as a sensor ! I wan't it as a battery level like the very first SensebenderMicro sketch. So... I have to undefine BATT_SENSOR ? And i will not have it set to 3Vcc=100% ?
                      martinhjelmareM iotcrazyI 2 Replies Last reply
                        it's working.
                        martinhjelmare
                        @Pierre-P
                        Might you need to specify decimals if sending float as message. If you want to try, add a second argument with an integer number for decimals.
                        https://github.com/mysensors/Arduino/blob/1.5.3/libraries/MySensors/MyMessage.cpp#L212
                        • Pierre PP Offline
                          Pierre PP Offline
                          Pierre P
                          Sorry i'm lost. I'm not as good for now.
                          (you may already see that)
                            martinhjelmare
                            @Pierre-P
                                lastBattery = vcc;
                            #ifdef BATT_SENSOR
                            • Pierre PP Offline
                              Pierre PP Offline
                              Pierre P
                              oh...:no_mouth:
                              Just need to say use "2" decimals in the message and it's ok...
                              The compilation work !
                              I'll try this afternoon the difference between #define BATT_SENSOR 199 and //#define BATT_SENSOR 199
                              Thanks for your help !
                              • Pierre PP Offline
                                Pierre PP Offline
                                Pierre P
                                Voltage is not good (it's a new 3Vcc button cell) and batterie pourcentage is at 76%
                                The battery voltage is not just minus 0.3V...
                                • tbowmoT Offline
                                  tbowmoT Offline
                                  tbowmo
                                  @Pierre-P
                                  The measurement method is not accurate at all. It relies on an internal reference that can vary in value between boards (I can't remember the accuracy of it at the moment)
                                  If you don't want the battery voltage, then uncomment the #define for BATT_SENSOR in the top of the sketch, and move the float siVolt = vcc/1000; to be within the #ifdef BATT_SENSOR like:
                                  #ifdef BATT_SENSOR
                                  Now it should compile, and send battery percentage as the standard sensebender sketch.
                                  • Pierre PP Offline
                                    Pierre PP Offline
                                    Pierre P
                                    I personaly think that it's quite good. When powered by FTDI, it found 3.00V.
                                    And I have only add the "//" to BATT_SENSOR and it work good.
                                    (you inverted the thing in the message just above).
                                    Thanks again for you help.
                                    Now i work very good and very fast. I just have to check for adding an antenna to the controller.
                                    • tbowmoT Offline
                                      tbowmoT Offline
                                      tbowmo
                                      @Pierre-P
                                      The FTDI probably supplies the board with 3.3V and not 3V..
                                      • alexsh1A Offline
                                        alexsh1A Offline
                                        alexsh1
                                        @Pierre-P How do you find the battery life please? I am planning to fit Sensebender with nrf24l01+ SMD and CR2032, but I wonder how long the battery is going to survive? Appreciate if depends on your sketch, but given one is conservative (i.e. no need to send temp/hum every 30-60 sec, but probably every 5-10mins or so), what's your estimate please?
                                        • Pierre PP Offline
                                          Pierre PP Offline
                                          Pierre P
                                          I can't tell you for the moment, I haven't check the real voltage of the CR2032 at the beginning. I'll try to make two mesure between 30 days.
                                          But my sketch is 1800000ms or 30min sleeping (if no-one press the button). Because it's a redundant information, my Jeedom controler have a meteo plugin who's working good. (i'll use it for the mini-night-temperature to have a message if there is glass on my car's windows).
                                          11.8k
                                          113.2k
