  3. Sensebender Micro + button
sensebendersensebender micbutton
27 Posts 5 Posters 13.6k Views 8 Watching
  • Pierre PP
    Pierre PP
    Pierre P
    Thanks a lot !
    There is many improvements between the very first sketch !
    And with OTA... Thanks !
    No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
      Hi!
      Regarding the scrolling not working while in edit, yeah, I experiencing that also. I'm on Chrome 47, Ubuntu. I always have to edit in full screen.
      This is my sketch for a sensebender connected to my door bell:
      2016-02-29: Updated sketch to fix bug in siVolt calculation and set max vcc to 3.2 V.
       * Version 1.0 - Thomas Bowman Mørch
       * Version 1.3 - Thomas Bowman Mørch
       * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
       * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
       * MODIFIED by Martin Hjelmare
       * Sensebender Micro default sketch with addition of binary switch and interrupt,
       * taken from Patrick 'Anticimex' Fallberg's sketch BinarySwitchSleepSensor.
       * Also fixed the bug with the diff calculation for the temperature, and changed
       * vcc 100% rating to 3V, instead of 3.3V.
      #include <SI7021.h>
      #include "utility/SPIFlash.h"
      #include <EEPROM.h>
      #include <sha204_lib_return_codes.h>
      #include <sha204_library.h>
      #include <RunningAverage.h>
      //#include <avr/power.h>
      // Define a static node address, remove if you want auto address assignment
      #define NODE_ADDRESS   1
      // Uncomment the line below, to transmit battery voltage as a normal sensor value
      #define BATT_SENSOR    199
      #define RELEASE "1.3"
      #define AVERAGES 2
      // Child sensor ID's
      #define CHILD_ID_TEMP  1
      #define CHILD_ID_HUM   2
      // How many milli seconds should we wait for OTA?
      #define OTA_WAIT_PERIOD 300
      #define FORCE_TRANSMIT_INTERVAL 30
      #define TEMP_TRANSMIT_THRESHOLD 1.0
      // Pin definitions
      #define TEST_PIN       A0
      #define OTA_ENABLE     A1
      #define LED_PIN        A2
      #define ATSHA204_PIN   17 // A3
      const int sha204Pin = ATSHA204_PIN;
      SI7021 humiditySensor;
      SPIFlash flash(8, 0x1F65);
      // Sensor messages
      #ifdef BATT_SENSOR
      MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
      #define CHILD_ID_BUTTON 3
      #define BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
      #if (BUTTON_PIN < 2 || BUTTON_PIN > 3)
      #error BUTTON_PIN must be either 2 or 3 for interrupts to work
      MyMessage msg(CHILD_ID_BUTTON, V_TRIPPED);
      // Global settings
      int measureCount = 0;
      int sendBattery = 0;
      boolean isMetric = true;
      boolean highfreq = true;
      boolean ota_enabled = false;
      boolean transmission_occured = false;
      float lastTemperature = -100;
      int lastHumidity = -100;
      long lastBattery = -100;
      int oldValue = -1;
       * Setup code
        pinMode(LED_PIN, OUTPUT);
        digitalWrite(LED_PIN, LOW);
        Serial.print(RELEASE);
        Serial.flush();
        // First check if we should boot into test mode
        pinMode(TEST_PIN,INPUT_PULLUP);
        //digitalWrite(TEST_PIN, HIGH); // Enable pullup
        if (!digitalRead(TEST_PIN)) testMode();
        pinMode(OTA_ENABLE, INPUT);
        digitalWrite(OTA_ENABLE, HIGH);
        if (!digitalRead(OTA_ENABLE)) {
          ota_enabled = true;
        // Make sure that ATSHA204 is not floating
        pinMode(ATSHA204_PIN, INPUT);
        digitalWrite(ATSHA204_PIN, HIGH);
        digitalWrite(TEST_PIN,LOW);
        digitalWrite(OTA_ENABLE, LOW); // remove pullup, save some power.
        // Setup the button
        pinMode(BUTTON_PIN, INPUT_PULLUP);
        digitalWrite(LED_PIN, HIGH);
      #ifdef NODE_ADDRESS
        gw.begin(NULL, NODE_ADDRESS, false);
        gw.begin(NULL,AUTO,false);
        humiditySensor.begin();
        Serial.flush();
        gw.sendSketchInfo("Sensebender Micro Bell", RELEASE);
        gw.present(CHILD_ID_TEMP,S_TEMP);
        gw.present(CHILD_ID_HUM,S_HUM);
      #ifdef BATT_SENSOR
        gw.present(BATT_SENSOR, S_MULTIMETER);
        gw.present(CHILD_ID_BUTTON, S_DOOR);
        isMetric = gw.getConfig().isMetric;
        Serial.print(F("isMetric: ")); Serial.println(isMetric);
        raHum.clear();
        sendTempHumidityMeasurements(false);
        sendBattLevel(false);
        if (ota_enabled) Serial.println("OTA FW update enabled");
       *  Main loop function
        measureCount ++;
        sendBattery ++;
        bool forceTransmit = false;
          if (!ota_enabled) clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
          highfreq = false;
        if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
          forceTransmit = true;
          measureCount = 0;
        if (sendBattery > 60)
           sendBattLevel(forceTransmit); // Not needed to send battery info that often
           sendBattery = 0;
        if (ota_enabled & transmission_occured) {
            gw.wait(OTA_WAIT_PERIOD);
        gw.sleep(5);
        int buttonValue = digitalRead(BUTTON_PIN);
        if (buttonValue != oldValue) {
           // Send in the new buttonValue
           gw.send(msg.set(buttonValue==HIGH ? 0 : 1));
           oldValue = buttonValue;
        gw.sleep(BUTTON_PIN-2, CHANGE, MEASURE_INTERVAL);
       * Sends temperature and humidity from Si7021 sensor
       * Parameters
      void sendTempHumidityMeasurements(bool force)
        bool tx = force;
        raHum.addValue(data.humidityPercent);
        float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
        Serial.print(F("TempDiff :"));Serial.println(diffTemp);
        Serial.print(F("HumDiff  :"));Serial.println(diffHum);
        if (isnan(diffHum)) tx = true;
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
        if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
        if (tx) {
          measureCount = 0;
          float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
          Serial.print("T: ");Serial.println(temperature);
          Serial.print("H: ");Serial.println(humidity);
          gw.send(msgTemp.set(temperature,1));
          gw.send(msgHum.set(humidity));
          lastHumidity = humidity;
          transmission_occured = true;
       * Parameters
        if (force) lastBattery = -1;
        long vcc = readVcc();
        if (vcc != lastBattery) {
          lastBattery = vcc;
        float siVolt = vcc / 1000.0;
      #ifdef BATT_SENSOR
          gw.send(msgBatt.set(siVolt, 2));
          // Calculate percentage
          vcc = min(vcc, 3200L); // vcc max is 3200
          vcc = vcc  - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
          long percent = vcc / 13.0;
          gw.sendBatteryLevel(percent);
      long readVcc() {
       * Verify all peripherals, and signal via the LED if any problems.
      void testMode()
        uint8_t ret_code;
        byte tests = 0;
        digitalWrite(LED_PIN, HIGH); // Turn on LED.
        Serial.println(F(" - TestMode"));
        Serial.println(F("Testing peripherals!"));
        Serial.flush();
        Serial.print(F("-> SI7021 : "));
        Serial.flush();
        if (humiditySensor.begin())
          Serial.println(F("ok!"));
          tests ++;
          Serial.println(F("failed!"));
        Serial.flush();
        Serial.print(F("-> Flash : "));
        Serial.flush();
        if (flash.initialize())
          tests ++;
        Serial.flush();
        Serial.print(F("-> SHA204 : "));
        Serial.flush();
        if (ret_code != SHA204_SUCCESS)
          Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
        Serial.flush();
        if (ret_code == SHA204_SUCCESS)
          ret_code = sha204.getSerialNumber(rx_buffer);
            Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
            Serial.print(F("Ok (serial : "));
            for (int i=0; i<9; i++)
              if (rx_buffer[i] < 0x10)
              Serial.print(rx_buffer[i], HEX);
            Serial.println(")");
            tests ++;
        Serial.flush();
        Serial.println(F("Test finished"));
        if (tests == 3)
          Serial.println(F("Selftest ok!"));
          while (1) // Blink OK pattern!
            delay(200);
            delay(200);
          Serial.println(F("----> Selftest failed!"));
          while (1) // Blink FAILED pattern! Rappidly blinking..
      Pierre PP
      Pierre PP
      Pierre P
      @martinhjelmare there is a bug (for code bender and arduinoUI). It doesn't like siVolt. '"siVolt' was not declared in this scope"
      your code:
       * Parameters
          lastBattery = vcc;
        siVolt = vcc / 1000;
      #ifdef BATT_SENSOR
          gw.send(msgBatt.set(siVolt));
          vcc = min(vcc, 3000L); // vcc max is 3000
          long percent = vcc / 11.0;
      old code
       * Parameters
          lastBattery = vcc;
      #ifdef BATT_SENSOR
          gw.send(msgBatt.set(vcc));
          long percent = vcc / 14.0;
      How did you compil ?
      tbowmoT 1 Reply Last reply
      • Pierre PP Pierre P
        your code:
         * Parameters
            lastBattery = vcc;
        #ifdef BATT_SENSOR
        old code
         * Parameters
            lastBattery = vcc;
        #ifdef BATT_SENSOR
        tbowmoT
        tbowmoT
        tbowmo
        @Pierre-P
        You just need to declare siVolt as a float type
        float siVolt = vcc/100;
        #ifdef....
        Pierre PP 1 Reply Last reply
        • tbowmoT tbowmo
          @Pierre-P
          #ifdef....
          Pierre PP
          Pierre PP
          Pierre P
          @tbowmo "call of overloaded 'set(float&)' is ambiguous"
          I don't know what it mean.
          And i don't know why the very first sketch is working for you and not for me ! :sweat_smile:
           * Parameters
              lastBattery = vcc;
              float siVolt = vcc / 1000;
          #ifdef BATT_SENSOR
          /*******************************************f```
             * Parameters
                lastBattery = vcc;
            #ifdef BATT_SENSOR
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @Pierre-P
            Sorry that was my addition and I haven't actually tested the siVolt thing yet. Everything else works though. But I don't see why it shouldn't work if you declare it properly first.
            • Pierre PP
              Pierre PP
              Pierre P
              wrote on last edited by Pierre P
              BATT_SENSOR si declared.
              ... I think msgBatt is not.
              Does it should be here ?
              // Sensor messages
              Wait not it's just under:
              #ifdef BATT_SENSOR
                // Sensor messages
                #ifdef BATT_SENSOR
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Pierre-P
                It's declared three lines below, inside the ifdefine.
                Try declaring siVolt outside the if block in the battery function.
                Edit: Scrap the last suggestion.
                • Pierre PP
                  Pierre PP
                  Pierre P
                  If I undefine: //#define BATT_SENSOR 199
                  it's working.
                  But your code still not 100% so we have to find why.
                  But... but, i think i'm making a mistake: yes i plan to use 3volts power. But, i don't want it as a sensor ! I wan't it as a battery level like the very first SensebenderMicro sketch. So... I have to undefine BATT_SENSOR ? And i will not have it set to 3Vcc=100% ?
                  martinhjelmareM iotcrazyI 2 Replies Last reply
                    it's working.
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @Pierre-P
                    Might you need to specify decimals if sending float as message. If you want to try, add a second argument with an integer number for decimals.
                    https://github.com/mysensors/Arduino/blob/1.5.3/libraries/MySensors/MyMessage.cpp#L212
                    • Pierre PP
                      Pierre PP
                      Pierre P
                      Sorry i'm lost. I'm not as good for now.
                      (you may already see that)
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Pierre-P
                            lastBattery = vcc;
                        #ifdef BATT_SENSOR
                        • Pierre PP
                          Pierre PP
                          Pierre P
                          oh...:no_mouth:
                          Just need to say use "2" decimals in the message and it's ok...
                          The compilation work !
                          I'll try this afternoon the difference between #define BATT_SENSOR 199 and //#define BATT_SENSOR 199
                          Thanks for your help !
                          • Pierre PP
                            Pierre PP
                            Pierre P
                            Voltage is not good (it's a new 3Vcc button cell) and batterie pourcentage is at 76%
                            The battery voltage is not just minus 0.3V...
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Pierre-P
                              The measurement method is not accurate at all. It relies on an internal reference that can vary in value between boards (I can't remember the accuracy of it at the moment)
                              If you don't want the battery voltage, then uncomment the #define for BATT_SENSOR in the top of the sketch, and move the float siVolt = vcc/1000; to be within the #ifdef BATT_SENSOR like:
                              #ifdef BATT_SENSOR
                              Now it should compile, and send battery percentage as the standard sensebender sketch.
                              • Pierre PP
                                Pierre PP
                                Pierre P
                                I personaly think that it's quite good. When powered by FTDI, it found 3.00V.
                                And I have only add the "//" to BATT_SENSOR and it work good.
                                (you inverted the thing in the message just above).
                                Thanks again for you help.
                                Now i work very good and very fast. I just have to check for adding an antenna to the controller.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Pierre-P
                                  The FTDI probably supplies the board with 3.3V and not 3V..
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @Pierre-P How do you find the battery life please? I am planning to fit Sensebender with nrf24l01+ SMD and CR2032, but I wonder how long the battery is going to survive? Appreciate if depends on your sketch, but given one is conservative (i.e. no need to send temp/hum every 30-60 sec, but probably every 5-10mins or so), what's your estimate please?
                                    • Pierre PP
                                      Pierre PP
                                      Pierre P
                                      I can't tell you for the moment, I haven't check the real voltage of the CR2032 at the beginning. I'll try to make two mesure between 30 days.
                                      But my sketch is 1800000ms or 30min sleeping (if no-one press the button). Because it's a redundant information, my Jeedom controler have a meteo plugin who's working good. (i'll use it for the mini-night-temperature to have a message if there is glass on my car's windows).
                                        it's working.
                                        iotcrazyI
                                        iotcrazyI
                                        iotcrazy
                                        @Pierre-P you controller image looks great . What controller is it ?
                                        • iotcrazyI iotcrazy
                                          Pierre PP
                                          Pierre PP
                                          Pierre P
                                          @iotcrazy It is Jeedom, you can find some information here: http://www.mysensors.org/controller/jeedom
                                          It use an RPI2 if you ant to make it yourself, and a major version will come during the week !
