  3. Serial Gateway error (printing)
7 Posts 4 Posters 1.5k Views 4 Watching
  • RenatoLacerdaR
    RenatoLacerdaR
    RenatoLacerda
    Hi guys, I'm new with mysensor, but I'm having a problem.
    I'm using a Serial gateway to print a node value (LightSensor example) , which is a light sensor, but I have the follwing information from the node:
    req id
    sensor started, id=255, parent=0, distance=1
    req id
    req id
    req id
    100
    req id
    100
    req id
    and the following response from the Serial Gateway:
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    Can anyone help me??? Thanks a lot
      @RenatoLacerda
      Do not cross post!
      §1 here: http://forum.mysensors.org/topic/610/forum-user-guidelines
      RenatoLacerdaR 1 Reply Last reply
        @RenatoLacerda
        Do not cross post!
        RenatoLacerdaR
        RenatoLacerdaR
        RenatoLacerda
        Sorry about it! @hek
          Connect the serial gateway to a controller.
          • RenatoLacerdaR
            RenatoLacerdaR
            RenatoLacerda
            thanks a lot @hek ! Its working
            • RenatoLacerdaR RenatoLacerda
              I see this question over and over. Maybe the serial debug should be changed to something that people understand? Not sure what though. "Req id from controller" maybe? But will that be sufficient to make people understand that they need a controller? Having a more helpful error message would probably help a lot of people.
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                Yes, I agree with @mfalkvidd, and I also think we need a section in the API for what the s, c , t, pt etc means. Right now you can only figure that out by reading the source, or by asking in the forum. I wrote a post explaining those, a while back, but posts get lost in the flood of posts.
