  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/20/jModule
    • sundberg84S
      sundberg84S
      Nice! :)
      • D
        dakipro
        I was thinking of making exactly the same thing for a few weeks now!
        Thank you so much for making this. How woild it be easiest to order these? Do you have any affiliate link maybe?
        julissesJ 1 Reply Last reply
        • D dakipro
          julissesJ
          julissesJ
          julisses
          @dakipro
          There is no way to order a jModule. You can build it yourself. First you need to find a PCP manufacturer and order a few jBoards. I am form Poland. Here in Poland I can recommend: Satland Prototype
          Next follow the build instruction - 10 minutes of soldering and your own jModule will be ready. It is really easy to build. The hardest part is to solder a voltage regulator - use method pin by pin.
          • D
            dakipro
            Thanks. I will most likely print few myself, just for the additional DIY fun.
            I noticed one thing, when I open the jBoard.brd file I do not see the minus "area" of the pcb. I was thinking of printing the "protected" areas (contact with copper) of the pcb on laser printer, and then transfer it to the PCB with the iron, and then burning the pcb.
            How can I turn on that minus area to show on the print so that I can transfer it via paper?
            • D
              dakipro
              I think I have found it, it is the Ratsnest tool (Network-like icon)
              • bjacobseB
                bjacobseB
                bjacobse
                Will it be possible for you to provide the necessary files to order from a PCB supplier? I am asking for those files: http://support.iteadstudio.com/support/solutions/articles/1000156317-gerber-files-requirements
                • bjacobseB bjacobse
                  julissesJ
                  julissesJ
                  julisses
                  @bjacobse
                  Here you can find The instruction of creating GERBER production files
                  I also added gerber files to the project.
                  • cvanandelC
                    cvanandelC
                    cvanandel
                    I have uploaded the .brd file to OSH Park pcb manufacturing company.
                    you can sign up with them, and search for jModule.
                    and order the board for $3.20 for 3 boards
                    Hope this helps somebody.
                    Regards
                    cvanandel
                    AWIA B 2 Replies Last reply
                    • cvanandelC cvanandel
                      Regards
                      cvanandel
                      AWIA
                      AWIA
                      AWI
                      @cvanandel Maybe my mistake but i'm not able to find it ....on OSH park
                      • cvanandelC
                        cvanandelC
                        cvanandel
                        I had forgotten to Share, I just did, so give it a little time, and the system should update.
                        • cvanandelC
                          cvanandelC
                          cvanandel
                          @AWI
                          I just checked the board is now available under shared projects.
                          • F
                            F
                            Floca
                            wrote on last edited by Floca
                            Hi, really nice project.
                            Are there any possibilitys to create a 5x5 PCB with perforation, so that more jmodules fits on it? That would be great when ordering from dirtypcb's, because you have more pieces from just one Slice.
                            I have no skills with eagle or something, so i can't do it by myself :(.
                            Regards.
                            • F Floca
                              Regards.
                              julissesJ
                              julissesJ
                              julisses
                              wrote on last edited by julisses
                              @Floca
                              Hi, my be this film will help you: How To - Duplicate Your PCB Layout Design in Eagle.
                              • D
                                dakipro
                                Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
                                Did anyone got same or similar thing?
                                DwaltD 1 Reply Last reply
                                • D dakipro
                                  DwaltD
                                  DwaltD
                                  Dwalt
                                  @dakipro
                                  I got three boards from OshPark and pin 8 is connected to ground on all three.
                                  • cvanandelC
                                    cvanandelC
                                    cvanandel
                                    @Dwalt
                                    Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
                                    But they come out the side on the angle connector as IO
                                    • DwaltD
                                      DwaltD
                                      Dwalt
                                      Ahh, I see now. The side facing pins are mapped as follows:
                                      • D
                                        dakipro
                                        Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
                                        • A
                                          aproxx
                                          Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
                                          cvanandelC T 2 Replies Last reply
