  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • cvanandelC cvanandel
    I have uploaded the .brd file to OSH Park pcb manufacturing company.
    you can sign up with them, and search for jModule.
    and order the board for $3.20 for 3 boards
    Hope this helps somebody.
    Regards
    cvanandel
    AWIA
    AWIA
    AWI
    @cvanandel Maybe my mistake but i'm not able to find it ....on OSH park
    • cvanandelC
      cvanandelC
      cvanandel
      I had forgotten to Share, I just did, so give it a little time, and the system should update.
      • cvanandelC
        cvanandelC
        cvanandel
        @AWI
        I just checked the board is now available under shared projects.
        • F
          F
          Floca
          wrote on last edited by Floca
          Hi, really nice project.
          Are there any possibilitys to create a 5x5 PCB with perforation, so that more jmodules fits on it? That would be great when ordering from dirtypcb's, because you have more pieces from just one Slice.
          I have no skills with eagle or something, so i can't do it by myself :(.
          Regards.
          julissesJ 1 Reply Last reply
          • F Floca
            Regards.
            julissesJ
            julissesJ
            julisses
            wrote on last edited by julisses
            @Floca
            Hi, my be this film will help you: How To - Duplicate Your PCB Layout Design in Eagle.
            • D
              dakipro
              Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
              Did anyone got same or similar thing?
              DwaltD 1 Reply Last reply
              • D dakipro
                DwaltD
                DwaltD
                Dwalt
                @dakipro
                I got three boards from OshPark and pin 8 is connected to ground on all three.
                • cvanandelC
                  cvanandelC
                  cvanandel
                  @Dwalt
                  Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
                  But they come out the side on the angle connector as IO
                  • DwaltD
                    DwaltD
                    Dwalt
                    Ahh, I see now. The side facing pins are mapped as follows:
                    • D
                      dakipro
                      Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
                      • A
                        aproxx
                        Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
                        cvanandelC T 2 Replies Last reply
                        • A aproxx
                          cvanandelC
                          cvanandelC
                          cvanandel
                          @aproxx
                          I have not, nor do not claim to have designed this module, the module was designed by julisses.
                          All credit for this board goes to julisses.
                          The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
                          So if there are any changes required to the board, please contact julisses.
                          Sorry if there was a misunderstanding.
                            Regards
                            cvanandel
                            B
                            B
                            bassmint
                            @cvanandel said:
                            jModule
                            can you supply osh park link. can't find it.
                            Q B AWIA 3 Replies Last reply
                            • B bassmint
                              @cvanandel said:
                              jModule
                              Q
                              Q
                              Qu3Uk
                              wrote on last edited by Qu3Uk
                              #23
                              Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
                              OSH Park link HERE
                              Noticed there search box doesn't come up on certain browsers as well.
                              cvanandelC 1 Reply Last reply
                              • Q Qu3Uk
                                OSH Park link HERE
                                cvanandelC
                                cvanandelC
                                cvanandel
                                @Qu3Uk
                                I do not think that pad goes anywhere either, here is the Eagle layout picture.
                                Regards
                                • B bassmint
                                  @cvanandel said:
                                  jModule
                                  B
                                  B
                                  bassmint
                                  @bassmint thanks for the link. just ordered some.
                                  here it is for any others who can't find it
                                  https://oshpark.com/shared_projects/62Dzi9s7
                                  • B bassmint
                                    @cvanandel said:
                                    jModule
                                    AWIA
                                    AWIA
                                    AWI
                                    @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                                    However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                                    Q Nca78N 2 Replies Last reply
                                    • AWIA AWI
                                      Q
                                      Q
                                      Qu3Uk
                                      @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
                                      • A aproxx
                                        tjay4x4
                                        I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
                                        http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          Nice one!
                                          I really would like to see the version of it for nrf24l01+ SMD
