  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • bjacobseB bjacobse
    Will it be possible for you to provide the necessary files to order from a PCB supplier? I am asking for those files: http://support.iteadstudio.com/support/solutions/articles/1000156317-gerber-files-requirements
    julissesJ
    julissesJ
    julisses
    @bjacobse
    Here you can find The instruction of creating GERBER production files
    I also added gerber files to the project.
    • cvanandelC
      cvanandelC
      cvanandel
      I have uploaded the .brd file to OSH Park pcb manufacturing company.
      you can sign up with them, and search for jModule.
      and order the board for $3.20 for 3 boards
      Hope this helps somebody.
      Regards
      cvanandel
      AWIA B 2 Replies Last reply
      • cvanandelC cvanandel
        Regards
        cvanandel
        AWIA
        AWIA
        AWI
        @cvanandel Maybe my mistake but i'm not able to find it ....on OSH park
        • cvanandelC
          cvanandelC
          cvanandel
          I had forgotten to Share, I just did, so give it a little time, and the system should update.
          • cvanandelC
            cvanandelC
            cvanandel
            @AWI
            I just checked the board is now available under shared projects.
            • F
              F
              Floca
              wrote on last edited by Floca
              Hi, really nice project.
              Are there any possibilitys to create a 5x5 PCB with perforation, so that more jmodules fits on it? That would be great when ordering from dirtypcb's, because you have more pieces from just one Slice.
              I have no skills with eagle or something, so i can't do it by myself :(.
              Regards.
              julissesJ 1 Reply Last reply
              • F Floca
                Regards.
                julissesJ
                julissesJ
                julisses
                wrote on last edited by julisses
                @Floca
                Hi, my be this film will help you: How To - Duplicate Your PCB Layout Design in Eagle.
                • D
                  dakipro
                  Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
                  Did anyone got same or similar thing?
                  DwaltD 1 Reply Last reply
                  • D dakipro
                    DwaltD
                    DwaltD
                    Dwalt
                    @dakipro
                    I got three boards from OshPark and pin 8 is connected to ground on all three.
                    • cvanandelC
                      cvanandelC
                      cvanandel
                      @Dwalt
                      Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
                      But they come out the side on the angle connector as IO
                      • DwaltD
                        DwaltD
                        Dwalt
                        Ahh, I see now. The side facing pins are mapped as follows:
                        • D
                          dakipro
                          Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
                          • A
                            aproxx
                            Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
                            cvanandelC T 2 Replies Last reply
                            • A aproxx
                              cvanandelC
                              cvanandelC
                              cvanandel
                              @aproxx
                              I have not, nor do not claim to have designed this module, the module was designed by julisses.
                              All credit for this board goes to julisses.
                              The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
                              So if there are any changes required to the board, please contact julisses.
                              Sorry if there was a misunderstanding.
                                Regards
                                cvanandel
                                B
                                B
                                bassmint
                                @cvanandel said:
                                jModule
                                can you supply osh park link. can't find it.
                                Q B AWIA 3 Replies Last reply
                                • B bassmint
                                  @cvanandel said:
                                  jModule
                                  Q
                                  Q
                                  Qu3Uk
                                  wrote on last edited by Qu3Uk
                                  #23
                                  Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
                                  OSH Park link HERE
                                  Noticed there search box doesn't come up on certain browsers as well.
                                  cvanandelC 1 Reply Last reply
                                  • Q Qu3Uk
                                    OSH Park link HERE
                                    cvanandelC
                                    cvanandelC
                                    cvanandel
                                    @Qu3Uk
                                    I do not think that pad goes anywhere either, here is the Eagle layout picture.
                                    Regards
                                    • B bassmint
                                      @cvanandel said:
                                      jModule
                                      B
                                      B
                                      bassmint
                                      @bassmint thanks for the link. just ordered some.
                                      here it is for any others who can't find it
                                      https://oshpark.com/shared_projects/62Dzi9s7
                                      • B bassmint
                                        @cvanandel said:
                                        jModule
                                        AWIA
                                        AWIA
                                        AWI
                                        @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                                        However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                                        Q Nca78N 2 Replies Last reply
                                        • AWIA AWI
                                          Q
                                          Q
                                          Qu3Uk
                                          @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
