  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 139.1k Views 27 Watching
  • A andriej
    @kimot what has to be done to prepare MySensors to use CAN?
    I'm thinking about ordering some modules for tests. :-)
    K
    K
    kimot
    @andriej
    But on the other side, with simply CANbus, we have got only 8 byte payload for our data.
    A 1 Reply Last reply
    • K kimot
      @andriej
      andriej
      @kimot so the only thing that's left is TCP/IP and MQTT...
      • K kimot
        @andriej
        It is a pity that not paying more attention mysensors.org for nodes interconnected by wires. But it is very difficult to find peer-to-peer protocol for RS485. Mainly because of solving collisions on the bus when multiple sensors. But it is very difficult to find peer-to-peer protocol for RS485. Mainly because of solving collisions on the bus when multiple sensors. I think that used ICSC library does not address this matter satisfactorily and with a larger number of sensor problems arise. ICSC library uses a Serial Software library by heavyweight each node on the bus, because all must be checke every bit transmitted on the bus. Look at different implementation:
        www.mrbus.org
        I think, thet using hardware UART is absolutely necessary.
        Or why when we use a separate module for radio transmission, we use the special module for robust message transfer over the wired bus? CAN controllers are not so expensive in this days:
        http://www.ebay.com/itm/MCP2515-CAN-Bus-Module-Board-TJA1050-receiver-SPI-For-51-MCU-ARM-controller-M2-/381500570180?hash=item58d334ba44:g:OhcAAOSw3KFWfANk
        After correct CAN controller configuration, we simply write a message to the CAN controller and forgot about it. No check or bus arbitration. And through interrupt pin from the controller just pick up the incoming message with our ID or broadcast.
        I know it's not as simple as using only RS485 transmitter itself, but we are guaranteed connecting maximum of 110 nodes and various libraries for Arduino for this CAN controller exist.
        L
        L
        LeoDesigner
        wrote on last edited by LeoDesigner
        #59
        @kimot
        Thanks for pointing to mrbus.org.
        I have seen this before - it's really nice implementation of RS485 bus management.
        It's worth trying to implement it. However, I can see only one weak point of ICSC lib. It's a moment when both nodes listening a bus and starting to transmit at the same time. In this case the both packets will be lost. (This situation can occur only during the transmission of the first starting byte, so higher bus speed can make this situation rare.)
        I have both the radio and wired mysensors network. And wired network in order of magnitude is more reliable. I have a really small amount of lost packets. The packets are retransmitted only due delay in the code of the nodes.
        • radekzmR
          radekzmR
          radekzm
          HELP: Please instructions on how I can run this RS485 transport class for beginners.
          Some basic questions:
          1. First point instructions: File "SerialTransport.h" and "SerialTransport.cpp" download to C:\Program Files (x86)\Arduino\libraries\MySensors[here]. is this correct ?
          2. On the second point instructions: "Add #include <SerialTransport.h> to your .ino sketch" but examples do not have this:
            https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/MotionSensorRS485
            https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/GatewaySerialRS485
            way ?
            In what file i must put this line "#include <SerialTransport.h>" ? main sketch ?
          3. The third point instructions: Replace transport class with: "Replace transport class with: " where exactly ? Maybe I have a different version MySensors because I can not find the declaration "#define MY_RADIO_RF24" and replace it with a "#define MY_RS485". I do not know how to change the NRF to RS485 in lib MySensors. Please precise instructions with examples for the current version lib MySensors.
          4. Can I get examples of sketch (confirmed that work with the physical bus RS485) Gateway and sensor.
          I use Windows, path of arduino lib is: C:\Program Files (x86)\Arduino\libraries.
          The only thing that works:
          When I connect RS485 to USB on Raspberry Pi (domoticz) and on the other side sensor (Arduino Pro Mini + DHT22) received on Raspberry:
          radek@raspberrypi $ cat /dev/ttyUSB0
          radi init fail
          It sent the sensor by the RS485 to Rasberry PI. So the RS485 is working properly.
          Sorry for my English and thank you for your help.
          L 1 Reply Last reply
          • P
            P
            pjr
            wrote on last edited by pjr
            #61
            I think those instructions are written for older version of the library. Now you could just copy those examples and try without changing anything.... I think ;)
            • radekzmR
              radekzmR
              radekzm
              In the examples, there is no information on how to disable the radio NRF24 and enable RS485, this is my main problem.
              MySensors still try init Radio NRF, because no radio connected in sending "radio init fail"
              Renovate the house and so I want to use it:
              Raspberry Pi (Domoticz) <--- USB ---> MySensor Gateway RS485 <--- RS485 (Cat5e) ---> MySensors Sensors & Actuators (x 20)
              Will show photos when I finish.
                It is this line that activates the RS485 transport (also note that no radio is activated).
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino#L56
                I haven't had the opportunity to test this thoroughly. So there might be issues.
                • radekzmR
                  radekzmR
                  radekzm
                  I think that constat value:
                  #define MY_RS485
                  It is doing nothing and changes nothing. This constat value is only on exmaple sketch. It is not a reference to the constat value in the library MySensros and mysensors-serial-transport.
                  Searching 1628 files for "MY_RS485"
                  0 matches
                  ??? I still do not know how to use the RS485 instead of NRF24 ???
                    What do you mean?
                    If surely affects things here:
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.h#L237-L268
                    • radekzmR
                      radekzmR
                      radekzm
                      That's exactly what I looking for !. In my version of the library that are missing.
                      In my version of the library that (supports RS485) are missing.
                      I downloaded the Library https://github.com/mysensors/Arduino/archive/master.zip this is my problem.
                      Should I download from https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
                      The last question: Do I have just these two files download and replace from second url and that all ?
                        You'll have to download replace everything in MySensors library folder.
                        • radekzmR radekzm
                            way ?
                          radi init fail
                          L
                          L
                          LeoDesigner
                          #68
                          You have to use a stable 1.5.2 version for my RS485 transport class. Not a development branch. You also may want to try development version too. The instruction was written for 1.5 (1.5.2) version of mysensors libs.
                          ...\Arduino\libraries\SerialTransport\ [HERE]
                          1. On the second point instructions: "Add #include <SerialTransport.h> to your .ino sketch" but examples do not have this:
                            way ?
                          They are for development version - not for stable 1.5.2
                          Yes.
                          1. The third point instructions: Replace transport class with: "Replace transport class with: " where exactly ? Maybe I have a different version MySensors because I can not find the declaration "#define MY_RADIO_RF24" and replace it with a "#define MY_RS485". I do not know how to change the NRF to RS485 in lib MySensors. Please precise instructions with examples for the current version lib MySensors.
                          Please check examples for version 1.5 (1.5.2)
                          1. Can I get examples of sketch (confirmed that work with the physical bus RS485) Gateway and sensor.
                          * MockMySensors 485
                          * Barduino 2015
                          #include <MySigningNone.h>
                          //#include <MyTransportRFM69.h>
                          //#include <MyTransportNRF24.h>
                          #include <MyHwATMega328.h>
                          #include <MyMessage.h>
                          #define RADIO_ERROR_LED_PIN 9  // Error led pin
                          #define RADIO_TX_LED_PIN    7  // the PCB, on board LED
                          // Wait times
                          #define LONG_WAIT 500
                          #define SHORT_WAIT 50
                          #define SKETCH_NAME "FakeMySensors 485 241"
                          #define SKETCH_VERSION "v0.2"
                          // Global Vars
                          // unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                          unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
                          boolean metric = true;
                          long randNumber;
                          // Instanciate MySersors Gateway
                          //MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                          //MyTransportRFM69 transport;
                          MyTransportSerial transport(Serial,241,6); // serial port, node, dePin (-1 disabled)
                          //MySigningNone signer;
                          //MySigningAtsha204 signer;
                          // Hardware profile
                          MyHwATMega328 hw;
                          #ifdef WITH_LEDS_BLINKING
                          MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                          #ifdef ID_S_DOOR
                            MyMessage msg_S_DOOR(ID_S_DOOR,V_TRIPPED);
                          You have to decide which version of the library to use.
                          My SerialTransport is written only for version 1.5.2
                          It's tested and working. BTW, I will upload updated version in a few minutes to github.
                          • radekzmR
                            radekzmR
                            radekzm
                            I still have a few questions:
                            Use: https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
                            1) Architecture: Do I understand correctly, example test:
                            raspberry pi domoticz [USB] <---- USB RS232 built-in Arduino nano ----> (hardware RS232, PIN: tx/rx) Arduino Nano (Gatwey RS485) (AltSoftSerial, PIN: 2,7,8) <---- RS485 AltSoftSerial ----> (AltSoftSerial, PIN: 2,7,8) Arduino Pro Mini <------ PIN 3, DHT22
                            2) Gatwey RS485 Arduino Nano:
                            • USB port of the Arduino Nano plugs in to Raspberry PI and set MySensors USB gateway in Domoticz ?
                            • Gatwaey to communicate with RS485 uses AltSoftSerial ? Whta PIN ? R0 / DI ?
                            • Gatwey Arduino Nano to communicate with Raspberry PI (Domoticz) use hardware USB (built in RS232) ?
                            • Gatweway don't have Debug mode (no free RS) ? When uploading have I must turn of debug mode in MyConfig.h when use RS485?
                            • DE PIN 2 ?
                            • RO PIN 8 ?
                            • DI PIN 9 ?
                            • PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
                             * The gateway uses AltSoftSerial to handle two serial links
                             * on one Arduino. Use the following pins for RS485 link
                             *  Board          Transmit  Receive   PWM Unusable
                             * Teensy 3.0 & 3.1  21        20         22
                             * Teensy 2.0         9        10       (none)
                             * Teensy++ 2.0      25         4       26, 27
                             * Arduino Uno        9         8         10  <----- Form https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html .... (& other ATMEGA328)
                             * Arduino Leonardo   5        13       (none)
                             * Arduino Mega      46        48       44, 45
                             * Wiring-S           5         6          4
                             * Sanguino          13        14         12
                            // Enable RS485 transport layer
                            #define MY_RS485
                            // Define this to enables DE-pin management on defined pin
                            #define MY_RS485_DE_PIN 2
                            // Set RS485 baud rate to use
                            // Enable serial gateway
                            #define MY_GATEWAY_SERIAL
                            // Flash leds on rx/tx/err
                            // Set blinking period
                            // Enable inclusion mode
                            #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                            #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                            #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
                            3) Sensor Arduino Pro mini
                            • What uses to communicate with RS485 bus ? Hardware RS232 Pin RX /TX or AltSoftSerial Pin 2/7/8 ?
                            • If use AltSoftSerial: PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
                            • When uploading have I must turn of debug mode in MyConfig.h when use RS485?
                            #define MY_RS485
                            // Define this to enables DE-pin manag ement on defined pin
                            #define MY_NODE_ID 15
                            #define CHILD_ID_HUM 0
                            #define CHILD_ID_TEMP 1
                            unsigned long SLEEP_TIME = 2000; // Sleep time between reads (in milliseconds)
                            // Initialize sensors
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            // Debug
                            //#include <SoftwareSerial.h>
                            //SoftwareSerial mySerial(3, 4); // RX, TX
                              //mySerial.begin(4800);
                              //mySerial.println("Hello, world?");
                              sendSketchInfo("Falskiego LED salon", "1.0");
                              present(CHILD_ID_HUM, S_HUM);
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                #ifdef MY_DEBUG
                                Serial.print("T: ");
                              if (isnan(humidity)) {
                                  lastHum = humidity;
                                  #ifdef MY_DEBUG
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                            Schema
                            Schema
                            Schema
                            • P
                              P
                              pjr
                              • radekzmR
                                radekzmR
                                radekzm
                                wrote on last edited by radekzm
                                #71
                                I made a test: did the system sends data from the sensor DHT22 to the rail 485 using only library AltSoftSerial and everything works properly. So the connection is ok.
                                I used the same libraries:
                                #include <AltSoftSerial.h>
                                The same connections:
                                http://cmss.pl/arduino/MySensor_RS485_test02_a.JPG
                                A ) RS485 Gatwaey (arduino nano):
                                http://cmss.pl/arduino/MySensor_RS485_test02_b.JPG
                                DE and RE -> Pin 2
                                RO -> Pin 8
                                DI -> Pin 9
                                Uploaded example MySensors Gatwey 485 and own code.
                                B ) RS485 Sensor DHT22 (arduino nano):
                                http://cmss.pl/arduino/MySensor_RS485_test02_c.JPG
                                DE and RE -> Pin 2
                                RO -> Pin 8
                                DI -> Pin 9
                                Unfortunately, nothing works, no reaction, empty on debug console.
                                Any ideas what could be wrong, what to check ???
                                  Sorry to hear, I still haven't verified this so there might be problems.
                                  It's this file that should be of interest:
                                  https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransportRS485.cpp
                                  Would be excellent if you had the time to debug it.
                                  radekzmR 1 Reply Last reply
                                    radekzmR
                                    radekzmR
                                    radekzm
                                    @hek
                                    Ok I will try.
                                    finezzaF 1 Reply Last reply
                                    • radekzmR radekzm
                                      @hek
                                      Ok I will try.
                                      finezzaF
                                      finezzaF
                                      finezza
                                      Hi I've tried a couple of months ago with success.
                                      Maybe you have to connect also the GND cable each other.
                                      Bye
                                      • MichalM
                                        MichalM
                                        Michal
                                        wrote on last edited by Michal
                                        #75
                                        I have tired similar configuration as radekzm.
                                        2 x Arduino nano connected via RS485 and is looks like only rs485 is not working so my question is; How to verified that connection between to arduinos using library AltSoftSerial is ok ?
                                        Are this connections PIN <-> RS485 (below) OK ?
                                        DE and RE -> Pin 2
                                        RO -> Pin 8
                                        DI -> Pin 9
                                        And below example is working fine (SoftwareSerial.h library)
                                        https://arduino-info.wikispaces.com/SoftwareSerialRS485Example
                                        • MichalM Michal
                                          DE and RE -> Pin 2
                                          RO -> Pin 8
                                          DI -> Pin 9
                                          radekzmR
                                          radekzmR
                                          radekzm
                                          @Michal
                                          I'll help when I get back from work.
                                          MichalM 1 Reply Last reply
