  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 139.1k Views 27 Watching
  • radekzmR
    radekzmR
    radekzm
    In the examples, there is no information on how to disable the radio NRF24 and enable RS485, this is my main problem.
    MySensors still try init Radio NRF, because no radio connected in sending "radio init fail"
    Renovate the house and so I want to use it:
    Raspberry Pi (Domoticz) <--- USB ---> MySensor Gateway RS485 <--- RS485 (Cat5e) ---> MySensors Sensors & Actuators (x 20)
    Will show photos when I finish.
      It is this line that activates the RS485 transport (also note that no radio is activated).
      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino#L56
      I haven't had the opportunity to test this thoroughly. So there might be issues.
      • radekzmR
        radekzmR
        radekzm
        I think that constat value:
        #define MY_RS485
        It is doing nothing and changes nothing. This constat value is only on exmaple sketch. It is not a reference to the constat value in the library MySensros and mysensors-serial-transport.
        Searching 1628 files for "MY_RS485"
        0 matches
        ??? I still do not know how to use the RS485 instead of NRF24 ???
          What do you mean?
          If surely affects things here:
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.h#L237-L268
          • radekzmR
            radekzmR
            radekzm
            That's exactly what I looking for !. In my version of the library that are missing.
            In my version of the library that (supports RS485) are missing.
            I downloaded the Library https://github.com/mysensors/Arduino/archive/master.zip this is my problem.
            Should I download from https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
            The last question: Do I have just these two files download and replace from second url and that all ?
              You'll have to download replace everything in MySensors library folder.
              • radekzmR radekzm
                HELP: Please instructions on how I can run this RS485 transport class for beginners.
                Some basic questions:
                1. First point instructions: File "SerialTransport.h" and "SerialTransport.cpp" download to C:\Program Files (x86)\Arduino\libraries\MySensors[here]. is this correct ?
                2. On the second point instructions: "Add #include <SerialTransport.h> to your .ino sketch" but examples do not have this:
                  https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/MotionSensorRS485
                  https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/GatewaySerialRS485
                  way ?
                  In what file i must put this line "#include <SerialTransport.h>" ? main sketch ?
                3. The third point instructions: Replace transport class with: "Replace transport class with: " where exactly ? Maybe I have a different version MySensors because I can not find the declaration "#define MY_RADIO_RF24" and replace it with a "#define MY_RS485". I do not know how to change the NRF to RS485 in lib MySensors. Please precise instructions with examples for the current version lib MySensors.
                4. Can I get examples of sketch (confirmed that work with the physical bus RS485) Gateway and sensor.
                I use Windows, path of arduino lib is: C:\Program Files (x86)\Arduino\libraries.
                The only thing that works:
                When I connect RS485 to USB on Raspberry Pi (domoticz) and on the other side sensor (Arduino Pro Mini + DHT22) received on Raspberry:
                radek@raspberrypi $ cat /dev/ttyUSB0
                radi init fail
                It sent the sensor by the RS485 to Rasberry PI. So the RS485 is working properly.
                Sorry for my English and thank you for your help.
                L
                L
                LeoDesigner
                wrote on last edited by LeoDesigner
                #68
                You have to use a stable 1.5.2 version for my RS485 transport class. Not a development branch. You also may want to try development version too. The instruction was written for 1.5 (1.5.2) version of mysensors libs.
                ...\Arduino\libraries\SerialTransport\ [HERE]
                1. On the second point instructions: "Add #include <SerialTransport.h> to your .ino sketch" but examples do not have this:
                  way ?
                They are for development version - not for stable 1.5.2
                Yes.
                1. The third point instructions: Replace transport class with: "Replace transport class with: " where exactly ? Maybe I have a different version MySensors because I can not find the declaration "#define MY_RADIO_RF24" and replace it with a "#define MY_RS485". I do not know how to change the NRF to RS485 in lib MySensors. Please precise instructions with examples for the current version lib MySensors.
                Please check examples for version 1.5 (1.5.2)
                1. Can I get examples of sketch (confirmed that work with the physical bus RS485) Gateway and sensor.
                * MockMySensors 485
                * Barduino 2015
                #include <MySigningNone.h>
                //#include <MyTransportRFM69.h>
                //#include <MyTransportNRF24.h>
                #include <MyHwATMega328.h>
                #include <MyMessage.h>
                #define RADIO_ERROR_LED_PIN 9  // Error led pin
                #define RADIO_TX_LED_PIN    7  // the PCB, on board LED
                // Wait times
                #define LONG_WAIT 500
                #define SHORT_WAIT 50
                #define SKETCH_NAME "FakeMySensors 485 241"
                #define SKETCH_VERSION "v0.2"
                // Global Vars
                // unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
                boolean metric = true;
                long randNumber;
                // Instanciate MySersors Gateway
                //MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                //MyTransportRFM69 transport;
                MyTransportSerial transport(Serial,241,6); // serial port, node, dePin (-1 disabled)
                //MySigningNone signer;
                //MySigningAtsha204 signer;
                // Hardware profile
                MyHwATMega328 hw;
                #ifdef WITH_LEDS_BLINKING
                MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                #ifdef ID_S_DOOR
                  MyMessage msg_S_DOOR(ID_S_DOOR,V_TRIPPED);
                You have to decide which version of the library to use.
                My SerialTransport is written only for version 1.5.2
                It's tested and working. BTW, I will upload updated version in a few minutes to github.
                • radekzmR
                  radekzmR
                  radekzm
                  I still have a few questions:
                  Use: https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
                  1) Architecture: Do I understand correctly, example test:
                  raspberry pi domoticz [USB] <---- USB RS232 built-in Arduino nano ----> (hardware RS232, PIN: tx/rx) Arduino Nano (Gatwey RS485) (AltSoftSerial, PIN: 2,7,8) <---- RS485 AltSoftSerial ----> (AltSoftSerial, PIN: 2,7,8) Arduino Pro Mini <------ PIN 3, DHT22
                  2) Gatwey RS485 Arduino Nano:
                  • USB port of the Arduino Nano plugs in to Raspberry PI and set MySensors USB gateway in Domoticz ?
                  • Gatwaey to communicate with RS485 uses AltSoftSerial ? Whta PIN ? R0 / DI ?
                  • Gatwey Arduino Nano to communicate with Raspberry PI (Domoticz) use hardware USB (built in RS232) ?
                  • Gatweway don't have Debug mode (no free RS) ? When uploading have I must turn of debug mode in MyConfig.h when use RS485?
                  • DE PIN 2 ?
                  • RO PIN 8 ?
                  • DI PIN 9 ?
                  • PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
                   * The gateway uses AltSoftSerial to handle two serial links
                   * on one Arduino. Use the following pins for RS485 link
                   *  Board          Transmit  Receive   PWM Unusable
                   * Teensy 3.0 & 3.1  21        20         22
                   * Teensy 2.0         9        10       (none)
                   * Teensy++ 2.0      25         4       26, 27
                   * Arduino Uno        9         8         10  <----- Form https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html .... (& other ATMEGA328)
                   * Arduino Leonardo   5        13       (none)
                   * Arduino Mega      46        48       44, 45
                   * Wiring-S           5         6          4
                   * Sanguino          13        14         12
                  // Enable RS485 transport layer
                  #define MY_RS485
                  // Define this to enables DE-pin management on defined pin
                  #define MY_RS485_DE_PIN 2
                  // Set RS485 baud rate to use
                  // Enable serial gateway
                  #define MY_GATEWAY_SERIAL
                  // Flash leds on rx/tx/err
                  // Set blinking period
                  // Enable inclusion mode
                  #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                  #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
                  3) Sensor Arduino Pro mini
                  • What uses to communicate with RS485 bus ? Hardware RS232 Pin RX /TX or AltSoftSerial Pin 2/7/8 ?
                  • If use AltSoftSerial: PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
                  • When uploading have I must turn of debug mode in MyConfig.h when use RS485?
                  #define MY_RS485
                  // Define this to enables DE-pin manag ement on defined pin
                  #define MY_NODE_ID 15
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  unsigned long SLEEP_TIME = 2000; // Sleep time between reads (in milliseconds)
                  // Initialize sensors
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  // Debug
                  //#include <SoftwareSerial.h>
                  //SoftwareSerial mySerial(3, 4); // RX, TX
                    //mySerial.begin(4800);
                    //mySerial.println("Hello, world?");
                    sendSketchInfo("Falskiego LED salon", "1.0");
                    present(CHILD_ID_HUM, S_HUM);
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                    if (isnan(humidity)) {
                        lastHum = humidity;
                        #ifdef MY_DEBUG
                        Serial.print("H: ");
                        Serial.println(humidity);
                  Schema
                  Schema
                  Schema
                  • P
                    P
                    pjr
                    • radekzmR
                      radekzmR
                      radekzm
                      wrote on last edited by radekzm
                      #71
                      I made a test: did the system sends data from the sensor DHT22 to the rail 485 using only library AltSoftSerial and everything works properly. So the connection is ok.
                      I used the same libraries:
                      #include <AltSoftSerial.h>
                      The same connections:
                      http://cmss.pl/arduino/MySensor_RS485_test02_a.JPG
                      A ) RS485 Gatwaey (arduino nano):
                      http://cmss.pl/arduino/MySensor_RS485_test02_b.JPG
                      DE and RE -> Pin 2
                      RO -> Pin 8
                      DI -> Pin 9
                      Uploaded example MySensors Gatwey 485 and own code.
                      B ) RS485 Sensor DHT22 (arduino nano):
                      http://cmss.pl/arduino/MySensor_RS485_test02_c.JPG
                      DE and RE -> Pin 2
                      RO -> Pin 8
                      DI -> Pin 9
                      Unfortunately, nothing works, no reaction, empty on debug console.
                      Any ideas what could be wrong, what to check ???
                        Sorry to hear, I still haven't verified this so there might be problems.
                        It's this file that should be of interest:
                        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransportRS485.cpp
                        Would be excellent if you had the time to debug it.
                        radekzmR 1 Reply Last reply
                          radekzmR
                          radekzmR
                          radekzm
                          @hek
                          Ok I will try.
                          finezzaF 1 Reply Last reply
                          • radekzmR radekzm
                            @hek
                            Ok I will try.
                            finezzaF
                            finezzaF
                            finezza
                            Hi I've tried a couple of months ago with success.
                            Maybe you have to connect also the GND cable each other.
                            Bye
                            • MichalM
                              MichalM
                              Michal
                              wrote on last edited by Michal
                              #75
                              I have tired similar configuration as radekzm.
                              2 x Arduino nano connected via RS485 and is looks like only rs485 is not working so my question is; How to verified that connection between to arduinos using library AltSoftSerial is ok ?
                              Are this connections PIN <-> RS485 (below) OK ?
                              DE and RE -> Pin 2
                              RO -> Pin 8
                              DI -> Pin 9
                              And below example is working fine (SoftwareSerial.h library)
                              https://arduino-info.wikispaces.com/SoftwareSerialRS485Example
                              • MichalM Michal
                                DE and RE -> Pin 2
                                RO -> Pin 8
                                DI -> Pin 9
                                radekzmR
                                radekzmR
                                radekzm
                                @Michal
                                I'll help when I get back from work.
                                MichalM 1 Reply Last reply
                                • elmarculinoE
                                  elmarculinoE
                                  elmarculino
                                  @LeoDesigner
                                  I'm trying a Gateway & 4 relays/4 switches configuration using 1.5.2 version. As @Michal my configuration works fine with this example: https://arduino-info.wikispaces.com/SoftwareSerialRS485Example
                                  Anything wrong with my sketches?
                                  Gateway:
                                   * LEDs (OPTIONAL):
                                  #define NO_PORTB_PINCHANGES
                                  //#include <MyHwATMega328.h>
                                  #include <MyParserSerial.h>
                                  #include <stdarg.h>
                                  #include <PinChangeInt.h>
                                  #include "GatewayUtil.h"
                                  MyTransportSerial transport(Serial,AUTO,2);
                                  // Hardware profile
                                  MyHwATMega328 hw;
                                  char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                                  int inputPos = 0;
                                  boolean commandComplete = false;  // whether the string is complete
                                  void parseAndSend(char *commandBuffer);
                                  void output(const char *fmt, ... ) {
                                     va_list args;
                                     va_start (args, fmt );
                                     va_end (args);
                                     Serial.print(serialBuffer);
                                    // Add interrupt for inclusion button to pin
                                    PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                                    // Send startup log message on serial
                                    serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                                    checkInclusionFinished();
                                    if (commandComplete) {
                                      // A command wass issued from serial interface
                                      // We will now try to send it to the actuator
                                      parseAndSend(gw, inputString);
                                      inputPos = 0;
                                    SerialEvent occurs whenever a new data comes in the
                                   hardware serial RX.  This routine is run between each
                                   time loop() runs, so using delay inside loop can delay
                                   response.  Multiple bytes of data may be available.
                                  void serialEvent() {
                                    while (Serial.available()) {
                                      // get the new byte:
                                      char inChar = (char)Serial.read();
                                      // if the incoming character is a newline, set a flag
                                      // so the main loop can do something about it:
                                      if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                                        if (inChar == '\n') {
                                          inputString[inputPos] = 0;
                                          commandComplete = true;
                                          // add it to the inputString:
                                          inputString[inputPos] = inChar;
                                          inputPos++;
                                          inputPos = 0;
                                  4 relays / 4 switches
                                    State change detection (edge detection)
                                   Often, you don't need to know the state of a digital input all the time,
                                   but you just need to know when the input changes from one state to another.
                                   For example, you want to know when a button goes from OFF to ON.  This is called
                                   state change detection, or edge detection.
                                   This example shows how to detect when a button or button changes from off to on
                                   and on to off.
                                   The circuit:
                                   * pushbutton attached to pin 2 from +5V
                                   * 10K resistor attached to pin 2 from ground
                                   * LED attached from pin 13 to ground (or use the built-in LED on
                                     most Arduino boards)
                                   created  27 Sep 2005
                                   modified 30 Aug 2011
                                   by Tom Igoe
                                  This example code is in the public domain.
                                   http://www.arduino.cc/en/Tutorial/ButtonStateChange
                                  // this constant won't change:
                                  int buttonPin[] = {9, 10, 11, 12};          // array of pins that the pushbutton is attached to
                                  int relayPin[] = {3, 4, 5, 6};           // array of pins that the relay is attached to
                                  int pinCount = 4;                  // number of buttons/relays attached
                                  // Variables will change:
                                  int buttonState[] = {0, 0};         // current state of the button
                                  int lastButtonState[] = {0, 0};     // previous state of the button
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int relayState[] = {RELAY_OFF, RELAY_OFF};   // counter for the number of button presses
                                  //MyTransportRFM69 radio;
                                  // Message signing driver (none default)
                                  // Select AtMega328 hardware profile
                                  MyHwATMega328 hw;
                                  MySensor gw(transport, hw);
                                    gw.sendSketchInfo("Relays & Buttons", "1.0");
                                    for (int i = 0; i < pinCount; i++) {
                                      gw.present(buttonPin[i], S_LIGHT);
                                      gw.present(relayPin[i], S_LIGHT);
                                      // initialize the button pin as a input:
                                      pinMode(buttonPin[i], INPUT);
                                      digitalWrite(buttonPin[i], 0);
                                      // initialize the relay as an output:
                                      pinMode(relayPin[i], OUTPUT);
                                      digitalWrite(relayPin[i], gw.loadState(i)?RELAY_ON:RELAY_OFF);
                                      MyMessage msg(relayPin[i], V_LIGHT);
                                      buttonState[i] = digitalRead(buttonPin[i]);
                                      if (buttonState[i] != lastButtonState[i]) {
                                        if (buttonState[i] == 1) {
                                  //         gw.send(msg.set(relayState[i]==RELAY_ON ? RELAY_OFF : RELAY_ON));
                                  //          if(relayState[i]==RELAY_ON) gw.send(msg.set(RELAY_OFF));
                                  //          else                        gw.send(msg.set(RELAY_ON));
                                            if(relayState[i]==RELAY_ON) relayState[i]=RELAY_OFF;
                                            else                        relayState[i]=RELAY_ON;
                                        lastButtonState[i] = buttonState[i];
                                      digitalWrite(relayPin[i], relayState[i]);
                                    if (message.type==V_LIGHT) {
                                          // digitalWrite(message.sensor-1+relayPin[1], message.getBool()?RELAY_ON:RELAY_OFF);
                                  L 1 Reply Last reply
                                  • elmarculinoE elmarculino
                                    @LeoDesigner
                                    Gateway:
                                     * LEDs (OPTIONAL):
                                    #include <stdarg.h>
                                    // Hardware profile
                                    MyHwATMega328 hw;
                                    int inputPos = 0;
                                       va_list args;
                                       va_end (args);
                                        inputPos = 0;
                                            inputPos++;
                                            inputPos = 0;
                                     and on to off.
                                     The circuit:
                                     created  27 Sep 2005
                                     by Tom Igoe
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    MyHwATMega328 hw;
                                    L
                                    L
                                    LeoDesigner
                                    @elmarculino
                                    In Gateway:
                                    Should be:
                                    MyTransportSerial transport(Serial,0,2);
                                    In 4relay / 4 switches:
                                    Personally I am assigning a static ID to nodes, so I did not tested an AUTO option in gw.init. However I think this it should work. Also make sure you are downloaded a latest Serial transport class from github with some minor corrections.
                                    • elmarculinoE
                                      elmarculinoE
                                      elmarculino
                                      @LeoDesigner
                                      Thanks for the help. I made the changes you pointed out, but still no lucky. What controller are you using? This should work in a direct crossover connection too?
                                        @LeoDesigner
                                        L
                                        L
                                        LeoDesigner
                                        @elmarculino
                                        I am using a custom controller based on the node-red, mqtt broker and homeassitant with mqtt bindings. But this is not essential - you can use 'nc GW_IP GW_PORT' from unix command line to issue commands to gateway directly. Try to separate your basic building blocks to smallest parts and then debug it.
                                        • elmarculinoE
                                          elmarculinoE
                                          elmarculino
                                          @LeoDesigner I still could not make it work in 1.5.2 with your library, but I will keep trying. Thanks!
                                          @hek I finally could make a gateway / sensor (Humidity) connection via RS485 using the development branch. Is any Controller compatible with the development branch? Thanks!
                                          0;255;3;0;9;Starting gateway (RSNGA-, 2.0.0-beta)
                                          0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.0
                                          1;0;1;0;1;44.0
                                          0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.0
                                          1;0;1;0;1;43.0
                                          1;0;1;0;1;44.0
                                          0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:27.0
                                          1;1;1;0;0;27.0
