  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
    Slorf
    This would be the first pcb's i order, how do i know which component goes where on the pcb ?
      Slorf
      @Koresh
      How do i know it;s a polarized version ?
      There are these ( which i think are the wrong ones )
      http://www.aliexpress.com/item/Free-shipping-0805-SMD-capacitor-4-7uf-50V-475Z-100PCS/32376068362.html?spm=2114.01010208.3.40.rvV9hM&ws_ab_test=searchweb201556_9,searchweb201644_4_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6452&btsid=833ff5df-930f-4fd8-8530-cb280a1b9c7f
      and there are these:
      http://www.aliexpress.com/item/Free-shipping-100pcs-lot-475K-X7R-25V-0805-4-7UF-SMD-capacitor-Chip-Capacitor-Electronic-Components/32607720756.html?spm=2114.01010208.3.207.rx4LMW&ws_ab_test=searchweb201556_9,searchweb201644_4_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6452&btsid=0572ec4f-a6b5-44fb-aa59-70649256d584
      KoreshK 1 Reply Last reply
      • S Slorf
        @Koresh
        KoreshK
        KoreshK
        Koresh
        @Slorf OK. Use non-polarized (ceramic) capacitor 0805 4.7uF and polarized 10uf (yellow 3216) capacitor. I've changed bom.
        I've uploaded assembly pdf too :).
          Slorf
          @Koresh
          Thanks, i found everything on Aliexpress, except:
          Push Button SPDT
          Resistor 1M ( which package size )
          Alex
          • S Slorf
            @Koresh
            Push Button SPDT
            Alex
            KoreshK
            KoreshK
            Koresh
            @Slorf
            Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
            Push Button - use any buttons like these http://ru.aliexpress.com/item/10-Pcs-x-Sealed-SMD-Momentary-Tact-Tactile-Push-Button-Switch-3mm-x-6mm-x-2/32600602500.html?spm=2114.30010708.3.10.QkNxnX&ws_ab_test=searchweb201556_6,searchweb201644_3_505_506_503_504_301_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10007_10008_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_6451&btsid=efafd213-4a02-41ac-8d40-b5e9982a58f1 :wink:
              Slorf
              @Koresh
              Will search and find the cheapest offers on Aliexpress :-)
                Slorf
                @Koresh
                When I try and order the pcb's from dirtypcb I get the following error:
                PCB #17568: No board outline (.GML/.GKO/.GBR) file found.
                I made a zip file with cam.drl, main.gbl, main.gbo, main.gbs, main.gtl, main.gto, main.gts
                when I try to upload this on dirtypcb I get the error message that there is no board outline.
                regards
                Alex
                • S Slorf
                  @Koresh
                  regards
                  Alex
                  KoreshK
                  KoreshK
                  Koresh
                  @Slorf It's openhardware.io engine problem. Engine had removed some files from my zip. Use files from this complete archive (gm2 - mechanical layer, rename it if its nessesary).
                  0_1456686721977_nrf_17_01_fabr.zip
                    @Koresh
                    .gm2 was a new extension I didn't know about.
                    I've updated the file extraction engine. When you get a chance, please try uploading it again.
                      @Koresh
                      KoreshK
                      KoreshK
                      Koresh
                      @hek
                      Thanks for quick fix :)
                      gm2 = gerber mechanic layer2. So there are many variations of file extensions. I think it would be perfect to add ability to attach a file with custom extension or raw zip\rar without extraction.
                        Slorf
                        @Koresh
                        I renamed the gm2 file to gml ( see: http://jrainimo.com/build/?p=642 ), and was able to order it from dirtypcb.
                        Alex
                        • S Slorf
                          @Koresh
                          Alex
                          KoreshK
                          KoreshK
                          Koresh
                          wrote on last edited by Koresh
                          #35
                          @Slorf One detail.... If it is not so late - please change your order (sorry...). Board thikness must be 1.6mm (antenna tunned for this value). I've changed board description.
                            Slorf
                            @Koresh
                            I mailed the people at dirtypcb, hopefully they can change it for me.
                            If they cannot change it, would it be possible to get rid of the antenna and mount a pa/lna antenna ?
                            Regards
                            Alex
                            • S Slorf
                              @Koresh
                              Regards
                              Alex
                              KoreshK
                              KoreshK
                              Koresh
                              #37
                              @Slorf Do not worry. Antenna will work with any board thikness, but with 1.6mm (with current geomerty configuration) it will be optimal. Almost all china nrf modules (I've seen) have non optimal antenna geometry.
                              PS
                              I'am sorry :( I hope dirtypcb will change you order.
                              @Slorf said in MySensors Stable Node:
                              It is possible, but its very non technologically...
                              • ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                Great board.
                                Did you test the performance ? Like number of recieved packets per second ?
                                  Slorf
                                  @Koresh
                                  Let's hope the change it :-)
                                  Would it be possible to mount something like this on the pcb ?
                                  http://www.aliexpress.com/item/New-SMA-female-jack-PCB-board-mount-right-angle-RF-coax-adapter-connector-converter/32588385730.html?spm=2114.01010208.3.2.S4UqzO&ws_ab_test=searchweb201556_7,searchweb201644_2_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_6449&btsid=91e89a18-89b4-43d2-bbab-ea422e14d360
                                    Slorf
                                    @Koresh
                                    Couple of questions :-)
                                    How to mount the second Quartz crystal ?, there are no holes in the pcb
                                    The LDO regulators are mounted next to 4.7uf capacitors, is it correct that the regulators and capacitors are connected to eachother on both sides ?
                                    On the photo of the assembled pcb it looks like this, but on the photo of the plain pcb and the schematic it look different.
        | Pin 1
        IC3
        Pin2    |          | Pin 3
                                            Are pin 2 and 3 also connected to the capacitor left and right pin ?
                                                              Left pin   |    C14   | Right pin
                                    Thanks !!
                                    Alex
                                    • S Slorf
                                      @Koresh
        | Pin 1
        IC3
        Pin2    |          | Pin 3
                                      Thanks !!
                                      Alex
                                      KoreshK
                                      KoreshK
                                      Koresh
                                      @Slorf
                                      Q1? Q1 is smd quartz. Q2 can be smd too but it can be difficult to mount it (so I've placed holes).
                                      I do not understand about LDO. You can check pinout in datasheet http://www.torexsemi.com/products/voltage_regulators/data/XC6206.pdf . May be datasheet schematic model (picture) is different from my library schematic model. But schematic and layout are correct.
                                        Slorf
                                        @Koresh
                                        Hi, the bom says 2 x quartz crystal
                                        I did not know they where different and one should be smd.
                                        Could you tell me which quartz crystals I should get ?
                                        Will check out the datasheet for the LDO :-)
                                        Alex
                                          Slorf
                                          @Koresh
                                          Found the smd quartz crystals :-)
                                          Alex
