  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 70.9k Views 36 Watching
    Slorf
    @Koresh
    Will search and find the cheapest offers on Aliexpress :-)
      Slorf
      @Koresh
      When I try and order the pcb's from dirtypcb I get the following error:
      PCB #17568: No board outline (.GML/.GKO/.GBR) file found.
      I made a zip file with cam.drl, main.gbl, main.gbo, main.gbs, main.gtl, main.gto, main.gts
      when I try to upload this on dirtypcb I get the error message that there is no board outline.
      regards
      Alex
      KoreshK 1 Reply Last reply
      • S Slorf
        @Koresh
        regards
        Alex
        KoreshK
        KoreshK
        Koresh
        @Slorf It's openhardware.io engine problem. Engine had removed some files from my zip. Use files from this complete archive (gm2 - mechanical layer, rename it if its nessesary).
        0_1456686721977_nrf_17_01_fabr.zip
          @Koresh
          .gm2 was a new extension I didn't know about.
          I've updated the file extraction engine. When you get a chance, please try uploading it again.
            @Koresh
            KoreshK
            KoreshK
            Koresh
            @hek
            Thanks for quick fix :)
            gm2 = gerber mechanic layer2. So there are many variations of file extensions. I think it would be perfect to add ability to attach a file with custom extension or raw zip\rar without extraction.
              Slorf
              @Koresh
              I renamed the gm2 file to gml ( see: http://jrainimo.com/build/?p=642 ), and was able to order it from dirtypcb.
              Alex
              • S Slorf
                @Koresh
                Alex
                KoreshK
                KoreshK
                Koresh
                wrote on last edited by Koresh
                #35
                @Slorf One detail.... If it is not so late - please change your order (sorry...). Board thikness must be 1.6mm (antenna tunned for this value). I've changed board description.
                  Slorf
                  @Koresh
                  I mailed the people at dirtypcb, hopefully they can change it for me.
                  If they cannot change it, would it be possible to get rid of the antenna and mount a pa/lna antenna ?
                  Regards
                  Alex
                  • S Slorf
                    @Koresh
                    Regards
                    Alex
                    KoreshK
                    KoreshK
                    Koresh
                    #37
                    @Slorf Do not worry. Antenna will work with any board thikness, but with 1.6mm (with current geomerty configuration) it will be optimal. Almost all china nrf modules (I've seen) have non optimal antenna geometry.
                    PS
                    I'am sorry :( I hope dirtypcb will change you order.
                    @Slorf said in MySensors Stable Node:
                    It is possible, but its very non technologically...
                    • ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      Great board.
                      Did you test the performance ? Like number of recieved packets per second ?
                        Slorf
                        @Koresh
                        Let's hope the change it :-)
                        Would it be possible to mount something like this on the pcb ?
                        http://www.aliexpress.com/item/New-SMA-female-jack-PCB-board-mount-right-angle-RF-coax-adapter-connector-converter/32588385730.html?spm=2114.01010208.3.2.S4UqzO&ws_ab_test=searchweb201556_7,searchweb201644_2_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_6449&btsid=91e89a18-89b4-43d2-bbab-ea422e14d360
                          Slorf
                          @Koresh
                          Couple of questions :-)
                          How to mount the second Quartz crystal ?, there are no holes in the pcb
                          The LDO regulators are mounted next to 4.7uf capacitors, is it correct that the regulators and capacitors are connected to eachother on both sides ?
                          On the photo of the assembled pcb it looks like this, but on the photo of the plain pcb and the schematic it look different.
        | Pin 1
        IC3
                                                       Pin2    |          | Pin 3
                                  Are pin 2 and 3 also connected to the capacitor left and right pin ?
                                                    Left pin   |    C14   | Right pin
                          Thanks !!
                          Alex
                          • S Slorf
                            @Koresh
        | Pin 1
        IC3
                                                         Pin2    |          | Pin 3
                            Thanks !!
                            Alex
                            KoreshK
                            KoreshK
                            Koresh
                            @Slorf
                            Q1? Q1 is smd quartz. Q2 can be smd too but it can be difficult to mount it (so I've placed holes).
                            I do not understand about LDO. You can check pinout in datasheet http://www.torexsemi.com/products/voltage_regulators/data/XC6206.pdf . May be datasheet schematic model (picture) is different from my library schematic model. But schematic and layout are correct.
                              Slorf
                              @Koresh
                              Hi, the bom says 2 x quartz crystal
                              I did not know they where different and one should be smd.
                              Could you tell me which quartz crystals I should get ?
                              Will check out the datasheet for the LDO :-)
                              Alex
                                Slorf
                                @Koresh
                                Found the smd quartz crystals :-)
                                Alex
                                • S Slorf
                                  @Koresh
                                  Alex
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  #44
                                  @Slorf I've left the package field in bom blank, so you can use any crystal you have. All components on the board are smd, so crystal should be smd too if you have it. But it may be difficult to place smd crystal as Q2 (too small area) and I've placed holes. I have both SMD and THD crystals but I will put holes in Q1 crystal pads in the next version too. Now you can simply mount THD crystal on the pads, it's not difficult.
                                  @Slorf said:
                                  Would it be possible to mount something like this on the pcb?
                                  It's possible. But I want this board to be as compact as possible.
                                  @ahmedadelhosni said:
                                  Great board.
                                  Thanks. I've tested stability (for some months without troubles in typical applications) and RF range. I think it doesn't make sense to test performance with low performance mcu, but you can propose the sketch and I test with it.
                                    Slorf
                                    @Koresh
                                    I have both versions ( SMD and THD ) crystals on order with aliexpress now :-)
                                    As for the LDO regulators, I will wait for the PCB's to arrive before making assumptions ;-)
                                    Now I have to wait some weeks before everything arrives ........and then my first smd soldering experience !
                                    Alex
                                      Slorf
                                      @Koresh
                                      I got as reply from dirtypcb's, they changed it to 1.6 mm :-)
                                      Alex
                                      • fisherF
                                        fisherF
                                        fisher
                                        Very nice project. Do you have a plan to sell assembled piece of the boards?
                                        Soldering such small SMD is out of my skills
                                        • fisherF fisher
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          @fisher Thanks. I'm looking for good PCBA service.
                                          fisherF 1 Reply Last reply
