  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.8k Views 16 Watching
  • GertSandersG GertSanders
    @AWI very nice, where did you buy the pins ?
    AWIA
    AWIA
    AWI
    @GertSanders I used these pins. These work for me but there are many other types in the same store which could serve your needs better.
    • alexsh1A
      alexsh1A
      alexsh1
      @GertSanders - my idea to use exactly for windows. I was thinking about z-wave ones, but £32 a pot is just way too expensive given I need quite a few. How do you power them?
      • alexsh1A alexsh1
        GertSandersG
        GertSandersG
        GertSanders
        @alexsh1 I power them similar to @m26872 , but with AAA batteries. They fit the 16x16mm cable guide by Legrand (which is a known brand for this in Belgium), available is most DIY stores.
        • Dombo71D
          Dombo71D
          Dombo71
          Dear
          I ordered a few...:-)
          Do you have a working sketch that is using less power?
          Perhaps wit a motionsensor and a DHt ore something
          I hope i get you hardware working..
          alexsh1A GertSandersG 3 Replies Last reply
          • Dombo71D Dombo71
            Dear
            alexsh1A
            alexsh1A
            alexsh1
            @Dombo71 said:
            Dear
            @Dombo71
            You can find a few working sketches in the 'Build' section of the website. However, don't you have an idea what it is exactly you'd like to build? I would be useful to know before throwing any sketch.
            FYG DHT is by far not a favourite one for a battery use in my view. There are others - SI7120 or BME280
            • Dombo71D Dombo71
              Dear
              GertSandersG
              GertSandersG
              GertSanders
              @Dombo71
              What do you mean with "using less power"?
              D 1 Reply Last reply
              • Dombo71D Dombo71
                Dear
                GertSandersG
                GertSandersG
                GertSanders
                @Dombo71
                Motion sensors are also not so low power and as mentioned before, DHT are power hungry. SI7021 is much better for low power/low voltage use.
                  @Dombo71
                  Dylano
                  @GertSanders said:
                  SI7021
                  I hope i can make a 3 in 1 sensor
                  Motion / contact.
                  temp and humanity
                  Better should be a multisensor, with a lot of option so we can choose .
                  The examples on my sensor are most 1 sensor...
                  And then work on a battery[s] for a year
                  Thanks for the SI7021 tip..
                  Domoticz, with a lot of working hardware, include mysensors :-)
                  OpenPLI, RuneAudio, Solarmeter, etc......
                  Not a great builder of software and hardware, more a user...
                  Only i try to do my best :-(
                  • D Dylano
                    @GertSanders said:
                    SI7021
                    Motion / contact.
                    temp and humanity
                    GertSandersG
                    GertSandersG
                    GertSanders
                    #40
                    @Dylano
                    This board is not meant for more then 1 function.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @Dylano Have a look at this board - this would let you program via FTDI and connect several sensors.
                      http://forum.mysensors.org/topic/2744/battery-based-atmega328p-sensor-no-smd
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        @GertSanders How snug is your enclosure? I saw @m26872 used 17x20mm for his slim node, but I was able to find in the UK 16x16mm trunking, which I think maybe a little bit small.
                        GertSandersG 2 Replies Last reply
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          #43
                          @alexsh1
                          I also use a 16x16mm cable guide and it just fits, the batteries are in batteryholders and therefor they stick out by 1mm. Without the batteryholder they fit perfectly.
                          The board is 13mm wide at the base which allows passing a few wires next to it. So 16x16 is ok for my narrow board.
                          • alexsh1A alexsh1
                            GertSandersG
                            GertSandersG
                            GertSanders
                            #44
                            @alexsh1
                            Here are some images of the very narrow node in a 16x16mm cable duct. The batteries are AAA type.
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @GertSanders - Thanks for photos. I have got 16x16mm trunking and just waiting for some spare parts. Will be posting photos shortly.
                                @alexsh1
                                Dylano
                                @GertSanders
                                This option with a pir...
                                or a magnet sensor.
                                What is the battery live?
                                alexsh1A 1 Reply Last reply
                                • D Dylano
                                  @GertSanders
                                  or a magnet sensor.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #47
                                  @Dylano said:
                                  @GertSanders
                                  or a magnet sensor.
                                  This is more a reed sensor. For PIR the size is just not right IMHO.
                                  Given that it sleeps most of the time, the battary life should be excellent.
                                  I do not know, maybe @GertSanders has got more comments?
                                  • alexsh1A alexsh1
                                    @Dylano said:
                                    @GertSanders
                                    or a magnet sensor.
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    #48
                                    @alexsh1 with a switch (reed or mechanical) i see a consumption of around 5micro amperes in sleep mode. 2 AAA should last minimum a year. We will see as my node is only started last week.
                                    A small PIR sensor is possible, see the "small AA project" and the mini PIR example.
                                    http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                                    No idea what lifetime to expect there.
                                    • T
                                      TimO
                                      I've just ordered a batch of these. Really cool, I can't wait to receive them. Thanks for the great work!
                                      • B
                                        B
                                        Bolliebol
                                        YES, my first is working. More to make. In my home now: "Big brother is watching you" Placed my first at the door of the refrigerator ;-)
                                        @GertSanders, you write:
                                        powering something with low consumption
                                        You can set both pins D2 and D3 of the processor to OUTPUT, do not mount the pull up resistors, do not activate the internal PullUPs, and by setting one of the pins to HIGH and the other to LOW you can power something. You will need to take care that a maximum of 20mA is consumed, as this is the recommended maximum amperage the pins of the atmega328 can drive or source.
                                        Sure not to mount the pull up resistors. But how do de-activate the internal PullUPs, and by setting one of the pins to HIGH and the other to LOW.
                                        Can you explain in "jip en Janneke/suske en wiske" language how to. With the help of this site I made my first one:
                                        https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5
                                        • B Bolliebol
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @Bolliebol
                                          You need to use these instructions:
                                          pinMode(2, OUTPUT);
                                          digitalWrite(2, HIGH);
                                          pinMode(3, OUTPUT);
                                          digitalWrite(2, LOW);
                                          // this makes pin 2 the "plus" side and pin 3 the "minus" side.
                                          // Connect your low power consuming thing between these two pins as if they are battery pins.
                                          // If you need to power off the device, just do
                                          digitalWrite(2,LOW);
