  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.1k Views 16 Watching
  • carlierdC
    carlierdC
    carlierd
    Very nice !!
    I just started learning Eagles to modify your board for RFM69 compatibility. The road will be long ;)
    Could be good also to add ATSHA204A but in a second time !
    David.
    • GertSandersG GertSanders
      The latest member of my growing sensor family, a reedswitch sensor with wakeup from power down by change on pin 2, wakeup every 23 hours to report battery voltage, and of course a blinky light when these things happen :-)
      Just tested and found to be OK. Next board will be set up for using a I2C module (will be my smallest temperature sensor yet). Time for a glas of WestVleeteren and rest.
      alexsh1A
      alexsh1A
      alexsh1
      @GertSanders
      Westvleteren Blonde is very nice :)
      Can you please remind me the difference berwrrn v1 and 1-1?
      I think it would be good to add FTDI connection, but the space is very limited
      GertSandersG 2 Replies Last reply
      • alexsh1A alexsh1
        @GertSanders
        GertSandersG
        GertSandersG
        GertSanders
        #28
        @alexsh1 FTDI would be nice to reprogram more easily, but in my case I have a stable sketch which is loaded 1 time, and then the node is deployed. No point in providing extra pins or using boardspace if it is only used once or twice.
        I saw that @AWI mentioned pogo-pins to make connections. Also a nice idea. In any case, my node is not designed to be flexible, and after programming I want to forget it. These nodes are sitting on doors and windows and need to do 1 thing only: show status of the reed-switched that are connected to them.
        But adding some pads so that pogo pins can make contact to RX, TX and !RESET would still be possible.
        It will be nice to see if a RFM69 radio can be connected by @carlierd . Looking forward to some pictures :-)
        AWIA 1 Reply Last reply
        • alexsh1A alexsh1
          @GertSanders
          GertSandersG
          GertSandersG
          GertSanders
          #29
          @alexsh1
          The difference between v1-0 and V1-1:
          V1-0:
          has 4 pins connected to VCC, GND, D2, D3 (in this sequence).
          LED is connected to D8
          V1-1:
          has 4 pins, of which 2 are fixed. Vcc and GND are at the outside (closest to board edge).
          The two pins in the middle (pin1 and pin2) can be connected to two different pins each by using the solder jumper.
          pin1 can be connected to SDA/A4 or to D2
          pin2 can be connected to SCL/A5 or to GND
          LED is connected to D6
            AWIA
            AWIA
            AWI
            @GertSanders A bit off a hassle, but I don't need pads... ;-)
            0_1457102582398_upload-7fc04aa0-f360-48dd-b170-601e208392ee
            • AWIA AWI
              GertSandersG
              GertSandersG
              GertSanders
              @AWI very nice, where did you buy the pins ?
                AWIA
                AWIA
                AWI
                @GertSanders I used these pins. These work for me but there are many other types in the same store which could serve your needs better.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @GertSanders - my idea to use exactly for windows. I was thinking about z-wave ones, but £32 a pot is just way too expensive given I need quite a few. How do you power them?
                  • alexsh1A alexsh1
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @alexsh1 I power them similar to @m26872 , but with AAA batteries. They fit the 16x16mm cable guide by Legrand (which is a known brand for this in Belgium), available is most DIY stores.
                    • Dombo71D
                      Dombo71D
                      Dombo71
                      Dear
                      I ordered a few...:-)
                      Do you have a working sketch that is using less power?
                      Perhaps wit a motionsensor and a DHt ore something
                      I hope i get you hardware working..
                      alexsh1A GertSandersG 3 Replies Last reply
                      • Dombo71D Dombo71
                        Dear
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Dombo71 said:
                        Dear
                        @Dombo71
                        You can find a few working sketches in the 'Build' section of the website. However, don't you have an idea what it is exactly you'd like to build? I would be useful to know before throwing any sketch.
                        FYG DHT is by far not a favourite one for a battery use in my view. There are others - SI7120 or BME280
                        • Dombo71D Dombo71
                          Dear
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @Dombo71
                          What do you mean with "using less power"?
                          D 1 Reply Last reply
                          • Dombo71D Dombo71
                            Dear
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @Dombo71
                            Motion sensors are also not so low power and as mentioned before, DHT are power hungry. SI7021 is much better for low power/low voltage use.
                              @Dombo71
                              Dylano
                              @GertSanders said:
                              SI7021
                              I hope i can make a 3 in 1 sensor
                              Motion / contact.
                              temp and humanity
                              Better should be a multisensor, with a lot of option so we can choose .
                              The examples on my sensor are most 1 sensor...
                              And then work on a battery[s] for a year
                              Thanks for the SI7021 tip..
                              Domoticz, with a lot of working hardware, include mysensors :-)
                              OpenPLI, RuneAudio, Solarmeter, etc......
                              Not a great builder of software and hardware, more a user...
                              Only i try to do my best :-(
                              • D Dylano
                                @GertSanders said:
                                SI7021
                                Motion / contact.
                                temp and humanity
                                GertSandersG
                                GertSandersG
                                GertSanders
                                #40
                                @Dylano
                                This board is not meant for more then 1 function.
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Dylano Have a look at this board - this would let you program via FTDI and connect several sensors.
                                  http://forum.mysensors.org/topic/2744/battery-based-atmega328p-sensor-no-smd
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @GertSanders How snug is your enclosure? I saw @m26872 used 17x20mm for his slim node, but I was able to find in the UK 16x16mm trunking, which I think maybe a little bit small.
                                    • alexsh1A alexsh1
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      #43
                                      @alexsh1
                                      I also use a 16x16mm cable guide and it just fits, the batteries are in batteryholders and therefor they stick out by 1mm. Without the batteryholder they fit perfectly.
                                      The board is 13mm wide at the base which allows passing a few wires next to it. So 16x16 is ok for my narrow board.
                                      • alexsh1A alexsh1
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        #44
                                        @alexsh1
                                        Here are some images of the very narrow node in a 16x16mm cable duct. The batteries are AAA type.
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @GertSanders - Thanks for photos. I have got 16x16mm trunking and just waiting for some spare parts. Will be posting photos shortly.
