  3. Water pressure struggling with sketch
7 Posts 3 Posters 2.8k Views 3 Watching
  • mikeg291M Offline
    mikeg291M Offline
    mikeg291
    Can some help with this sketch I can't seem to figure it out. I will be so happy when I get past this newbie stage.
    #define BARO_CHILD 0
    int pSensor=A0; //assigning pressure sensor to pin A0
    int readValue; //declaring our readValue Variable
    float Voltage; // declare  voltage variable
    float PSI; // declare pressure variable
      gw.begin();
      gw.sendSketchInfo("Water Pressure", "1.1");
      // Register sensors to gw (they will be created as child devices)
      gw.present(BARO_CHILD, S_BARO);
     pinMode(pSensor,INPUT); //declare psensor as a input
     Serial.begin(9600); //start serial port
      readValue = analogRead(pSensor); // read psensor and put value in read value
      Voltage = (5./1023.)*readValue; //calculating real  world voltage
      PSI = 17.78*Voltage -8; // Calculate pressure PSI
        gw.send (PSI);
    Serial.println(PSI); //print results to serial monitor
      delay(1000);   // delay one second
    • T Offline
      T Offline
      tripy
      wrote on last edited by tripy
      What is your error message?
      In your loop, this looks wrong:
      Voltage = (5./1023.)readValue;
      Are you sure you didn't miss an operator or something ?
      You are also missing a presentation of your node, and I don't see anything declaring the radio to be used.
      What are you trying to do?
      mikeg291M 1 Reply Last reply
      • T tripy
        mikeg291M Offline
        mikeg291M Offline
        mikeg291
        he error that I get is
        Arduino: 1.6.7 (Windows 7), Board: "Arduino Nano, ATmega328"
        C:\Users\repair\Desktop\Ardunio Files\my_pressure_sketch_1\my_pressure_sketch_1.ino: In function 'void loop()':
        my_pressure_sketch_1:34: error: no matching function for call to 'MySensor::send(float&)'
         gw.send (PSI);
        C:\Users\repair\Desktop\Ardunio Files\my_pressure_sketch_1\my_pressure_sketch_1.ino:34:17: note: candidate is:
        In file included from C:\Users\repair\Desktop\Ardunio Files\my_pressure_sketch_1\my_pressure_sketch_1.ino:2:0:
        C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:215:7: note: bool MySensor::send(MyMessage&, bool)
        bool send(MyMessage &msg, bool ack=false);
        C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:215:7: note: no known conversion for argument 1 from 'float' to 'MyMessage&'
        exit status 1
        @tripy
        • mfalkviddM Offline
          Change
          gw.send(PSI);
          to
          gw.send(pressureMsg.set(PSI, 0));
          • T Offline
            T Offline
            tripy
            I'm a bit blind here, but your issue seems to be that you are trying to send a raw float value, without encapsulating it inside a message.
            Looking at the example, in the 1.5 version it is:
            gw.send(pressureMsg.set(pressure, 0));
            Looking at the 1.5 API (http://www.mysensors.org/download/sensor_api_15#MyMessage), creating the message from a float should be
            MyMessage& set(float value, uint8_t decimals);
            So, you should not use
            gw.send (PSI);
            but
            //declare and init the message
            MyMessage msg(BARO_CHILD, V_PRESSURE);
            //set it's content
            msg.set(PSI,4); //float value with a 4 numbers after decimal precision
            //and send the message
            gw.send (msg);
            • T tripy
              gw.send (PSI);
              but
              //set it's content
              gw.send (msg);
              mikeg291M Offline
              mikeg291M Offline
              mikeg291
              @tripy Thanks ; Tripy your solution solve the problem and pointed me in new info . I am slowly learning the solutions are available here .
              • T Offline
                T Offline
                tripy
                Glad I was able to help.
                12.1k
