  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    the new config looks like this
    mysensors:
      gateways:
        - port: '/dev/ttyUSB0'
          baud_rate: 38400
      debug: true
      persistence: true
      version: '1.5'
      optimistic: true
    • martinhjelmareM Offline
      martinhjelmare
      Which arduino model are you using for the gateway?
      • ? Offline
        ? Offline
        A Former User
        Its a nano.
          martinhjelmare
          Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
          Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
          • ? Offline
            ? Offline
            A Former User
            no i haven't, so i have just removed the line, and restarted HA.
            But no luck. im still getting this.
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
                if not component.setup(hass, config):
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
                port, persistence, persistence_file, version, baud_rate)
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
                baud=baud_rate)
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
                persistence_file, protocol_version)
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
                self._load_sensors()
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
                self._perform_file_action(self.persistence_file, 'load')
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
                func(filename)
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
                self.sensors = pickle.load(file_handle)
            EOFError: Ran out of input
            • ? Offline
              ? Offline
              A Former User
              okay putting
              persistence_file: 'mysensors.json'
              Will get the gateway started. but will result in a file not found. if i put the correct path in like
              persistence_file: '/var/opt/homeassistant/mysensors.json'
              i get this in the log.
              16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                  baud=baud_rate)
                  func(filename)
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                  self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                  parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                  return cls(**kw).decode(s)
                File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                  obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                  raise ValueError(errmsg("Expecting value", s, err.value)) from None
              ValueError: Expecting value: line 1 column 1 (char 0)
                martinhjelmare
                #22
                If you check the content of
                What does it show?
                • ? Offline
                  ? Offline
                  A Former User
                  That's where all my configuration is. And there is a mysensors.json file present.
                    martinhjelmare
                    #24
                    Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
                    Edit: Also delete any pickle files, if any.
                    • ? Offline
                      ? Offline
                      A Former User
                      wrote on last edited by A Former User
                      #25
                      full path and no file, gets me
                      File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
                      but will get me a gateway started.
                        martinhjelmare
                        #26
                        That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
                        • ? Offline
                          ? Offline
                          A Former User
                          nope no file
                            martinhjelmare
                            Oh yeah, I think it will create it when the first sensor is added.
                            Do you get the gateway started message now?
                            • ? Offline
                              ? Offline
                              A Former User
                              Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
                                martinhjelmare
                                Yes. Make sure you follow the presentation guide in the docs for mysensors on the HA web.
                                • ? Offline
                                  ? Offline
                                  A Former User
                                  thank you so much, that seem to do the trick. the gate way was started and the sensor was add, as soon as it was turned on.
                                    martinhjelmare
                                    :thumbsup:
                                    I'll think about updating the docs at HA web, to explain things a bit more.
                                    • ? Offline
                                      ? Offline
                                      A Former User
                                      Maybe also put in about the pyserial?
                                        martinhjelmare
                                        Well pyserial should be installed automatically when you run hass the first time with mysensors activated in the config. There shouldn't be a need to do that on your own.
                                        Are you sure it wasn't installed for you?
