  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    no that i know of. Its a virtual machine dedicated to only ha. And i have just testet if it was the virtual enviroment there was to blame. But on indigo domistic the plugin for mysensors works and can talk to the gateway.
    Im i missing something else like pyserial or?
    Is the only thing needed ha and pyserial?
    • martinhjelmareM Offline
      martinhjelmare
      Have you rebooted the machine after installing pyserial 2.5?
      You can also check that there's no remains of other pyserial versions where the python packages are installed on your machine.
      What distribution are you running?
      • ? Offline
        ? Offline
        A Former User
        yep have rebooted, many times after that.
        How do i check if there are any other version installed? I could not install pyserial just like you said, i had to run a
        pip3 uninstall pyserial
        first.
        it' a ubuntu 15.10
          martinhjelmare
          Python library files on Ubuntu are usually found in:
          /usr/local/lib/pythonX.X/site-packages
          • ? Offline
            ? Offline
            A Former User
            ls -la /usr/local/lib/python3.4/dist-packages/
            homeassistant/                  MarkupSafe-0.23.egg-info/       pytz-2015.7.dist-info/          vincenty/
            homeassistant-0.15.0.dist-info/ pip/                            PyYAML-3.11.egg-info/           vincenty-0.1.3.egg-info/
            jinja2/                         pip-8.1.0.dist-info/            requests/                       yaml/
            Jinja2-2.8.dist-info/           pyserial_py3k-2.5.egg-info/     requests-2.9.1.dist-info/
            markupsafe/                     pytz/                           serial/
            • ? Offline
              ? Offline
              A Former User
              also don't know if, it is related.
              but i had this in the configuration:
              persistence_file: 'mysensors.json'
              But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
              16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
                File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
                  if not component.setup(hass, config):
                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
                  port, persistence, persistence_file, version, baud_rate)
                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
                  baud=baud_rate)
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
                  persistence_file, protocol_version)
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
                  self._load_sensors()
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
                  self._perform_file_action(self.persistence_file, 'load')
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
                  func(filename)
                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
                  self.sensors = pickle.load(file_handle)
              EOFError: Ran out of input
              • ? Offline
                ? Offline
                A Former User
                the new config looks like this
                mysensors:
                  gateways:
                    - port: '/dev/ttyUSB0'
                      baud_rate: 38400
                  debug: true
                  persistence: true
                  version: '1.5'
                  optimistic: true
                  martinhjelmare
                  Which arduino model are you using for the gateway?
                  • ? Offline
                    ? Offline
                    A Former User
                    Its a nano.
                      martinhjelmare
                      Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
                      Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
                      • ? Offline
                        ? Offline
                        A Former User
                        no i haven't, so i have just removed the line, and restarted HA.
                        But no luck. im still getting this.
                            baud=baud_rate)
                            func(filename)
                        • ? Offline
                          ? Offline
                          A Former User
                          okay putting
                          Will get the gateway started. but will result in a file not found. if i put the correct path in like
                          persistence_file: '/var/opt/homeassistant/mysensors.json'
                          i get this in the log.
                          16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                              baud=baud_rate)
                              func(filename)
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                              self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                            File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                              parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                            File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                              return cls(**kw).decode(s)
                            File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                              obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                            File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                              raise ValueError(errmsg("Expecting value", s, err.value)) from None
                          ValueError: Expecting value: line 1 column 1 (char 0)
                            martinhjelmare
                            #22
                            If you check the content of
                            What does it show?
                            • ? Offline
                              ? Offline
                              A Former User
                              That's where all my configuration is. And there is a mysensors.json file present.
                                martinhjelmare
                                #24
                                Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
                                Edit: Also delete any pickle files, if any.
                                • ? Offline
                                  ? Offline
                                  A Former User
                                  wrote on last edited by A Former User
                                  #25
                                  full path and no file, gets me
                                  File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
                                  but will get me a gateway started.
                                    martinhjelmare
                                    #26
                                    That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
                                    • ? Offline
                                      ? Offline
                                      A Former User
                                      nope no file
                                        martinhjelmare
                                        Oh yeah, I think it will create it when the first sensor is added.
                                        Do you get the gateway started message now?
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                          Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
