  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    yep have rebooted, many times after that.
    How do i check if there are any other version installed? I could not install pyserial just like you said, i had to run a
    pip3 uninstall pyserial
    first.
    it' a ubuntu 15.10
    • martinhjelmareM Offline
      martinhjelmare
      Python library files on Ubuntu are usually found in:
      /usr/local/lib/pythonX.X/site-packages
      • ? Offline
        ? Offline
        A Former User
        ls -la /usr/local/lib/python3.4/dist-packages/
        homeassistant/                  MarkupSafe-0.23.egg-info/       pytz-2015.7.dist-info/          vincenty/
        homeassistant-0.15.0.dist-info/ pip/                            PyYAML-3.11.egg-info/           vincenty-0.1.3.egg-info/
        jinja2/                         pip-8.1.0.dist-info/            requests/                       yaml/
        Jinja2-2.8.dist-info/           pyserial_py3k-2.5.egg-info/     requests-2.9.1.dist-info/
        markupsafe/                     pytz/                           serial/
        • ? Offline
          ? Offline
          A Former User
          also don't know if, it is related.
          but i had this in the configuration:
          persistence_file: 'mysensors.json'
          But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
          16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
              if not component.setup(hass, config):
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
              port, persistence, persistence_file, version, baud_rate)
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
              baud=baud_rate)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
              persistence_file, protocol_version)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
              self._load_sensors()
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
              self._perform_file_action(self.persistence_file, 'load')
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
              func(filename)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
              self.sensors = pickle.load(file_handle)
          EOFError: Ran out of input
          • ? Offline
            ? Offline
            A Former User
            the new config looks like this
            mysensors:
              gateways:
                - port: '/dev/ttyUSB0'
                  baud_rate: 38400
              debug: true
              persistence: true
              version: '1.5'
              optimistic: true
              martinhjelmare
              Which arduino model are you using for the gateway?
              • ? Offline
                ? Offline
                A Former User
                Its a nano.
                  martinhjelmare
                  Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
                  Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
                  • ? Offline
                    ? Offline
                    A Former User
                    no i haven't, so i have just removed the line, and restarted HA.
                    But no luck. im still getting this.
                        baud=baud_rate)
                        func(filename)
                    • ? Offline
                      ? Offline
                      A Former User
                      okay putting
                      Will get the gateway started. but will result in a file not found. if i put the correct path in like
                      persistence_file: '/var/opt/homeassistant/mysensors.json'
                      i get this in the log.
                      16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                          baud=baud_rate)
                          func(filename)
                        File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                          self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                        File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                          parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                        File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                          return cls(**kw).decode(s)
                        File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                          obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                        File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                          raise ValueError(errmsg("Expecting value", s, err.value)) from None
                      ValueError: Expecting value: line 1 column 1 (char 0)
                        martinhjelmare
                        #22
                        If you check the content of
                        What does it show?
                        • ? Offline
                          ? Offline
                          A Former User
                          That's where all my configuration is. And there is a mysensors.json file present.
                            martinhjelmare
                            #24
                            Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
                            Edit: Also delete any pickle files, if any.
                            • ? Offline
                              ? Offline
                              A Former User
                              wrote on last edited by A Former User
                              #25
                              full path and no file, gets me
                              File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
                              but will get me a gateway started.
                                martinhjelmare
                                #26
                                That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
                                • ? Offline
                                  ? Offline
                                  A Former User
                                  nope no file
                                    martinhjelmare
                                    Oh yeah, I think it will create it when the first sensor is added.
                                    Do you get the gateway started message now?
                                    • ? Offline
                                      ? Offline
                                      A Former User
                                      Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
                                        martinhjelmare
                                        Yes. Make sure you follow the presentation guide in the docs for mysensors on the HA web.
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                          thank you so much, that seem to do the trick. the gate way was started and the sensor was add, as soon as it was turned on.
