  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • martinhjelmareM Offline
    martinhjelmare
    Which arduino model are you using for the gateway?
    • ? Offline
      ? Offline
      A Former User
      Its a nano.
        martinhjelmare
        Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
        Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
        • ? Offline
          ? Offline
          A Former User
          no i haven't, so i have just removed the line, and restarted HA.
          But no luck. im still getting this.
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
              if not component.setup(hass, config):
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
              port, persistence, persistence_file, version, baud_rate)
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
              baud=baud_rate)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
              persistence_file, protocol_version)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
              self._load_sensors()
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
              self._perform_file_action(self.persistence_file, 'load')
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
              func(filename)
            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
              self.sensors = pickle.load(file_handle)
          EOFError: Ran out of input
          • ? Offline
            ? Offline
            A Former User
            okay putting
            persistence_file: 'mysensors.json'
            Will get the gateway started. but will result in a file not found. if i put the correct path in like
            persistence_file: '/var/opt/homeassistant/mysensors.json'
            i get this in the log.
            16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                baud=baud_rate)
                func(filename)
              File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
              File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
              File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                return cls(**kw).decode(s)
              File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                obj, end = self.raw_decode(s, idx=_w(s, 0).end())
              File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                raise ValueError(errmsg("Expecting value", s, err.value)) from None
            ValueError: Expecting value: line 1 column 1 (char 0)
              martinhjelmare
              #22
              If you check the content of
              What does it show?
              • ? Offline
                ? Offline
                A Former User
                That's where all my configuration is. And there is a mysensors.json file present.
                  martinhjelmare
                  #24
                  Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
                  Edit: Also delete any pickle files, if any.
                  • ? Offline
                    ? Offline
                    A Former User
                    wrote on last edited by A Former User
                    #25
                    full path and no file, gets me
                    File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
                    but will get me a gateway started.
                      martinhjelmare
                      #26
                      That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
                      • ? Offline
                        ? Offline
                        A Former User
                        nope no file
                          martinhjelmare
                          Oh yeah, I think it will create it when the first sensor is added.
                          Do you get the gateway started message now?
                          • ? Offline
                            ? Offline
                            A Former User
                            Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
                              martinhjelmare
                              Yes. Make sure you follow the presentation guide in the docs for mysensors on the HA web.
                              • ? Offline
                                ? Offline
                                A Former User
                                thank you so much, that seem to do the trick. the gate way was started and the sensor was add, as soon as it was turned on.
                                  martinhjelmare
                                  :thumbsup:
                                  I'll think about updating the docs at HA web, to explain things a bit more.
                                  • ? Offline
                                    ? Offline
                                    A Former User
                                    Maybe also put in about the pyserial?
                                      martinhjelmare
                                      Well pyserial should be installed automatically when you run hass the first time with mysensors activated in the config. There shouldn't be a need to do that on your own.
                                      Are you sure it wasn't installed for you?
