  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    also don't know if, it is related.
    but i had this in the configuration:
    persistence_file: 'mysensors.json'
    But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
    16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
        if not component.setup(hass, config):
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
        port, persistence, persistence_file, version, baud_rate)
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
        baud=baud_rate)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
        persistence_file, protocol_version)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
        self._load_sensors()
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
        self._perform_file_action(self.persistence_file, 'load')
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
        func(filename)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
        self.sensors = pickle.load(file_handle)
    EOFError: Ran out of input
    • ? Offline
      ? Offline
      A Former User
      the new config looks like this
      mysensors:
        gateways:
          - port: '/dev/ttyUSB0'
            baud_rate: 38400
        debug: true
        persistence: true
        version: '1.5'
        optimistic: true
      • martinhjelmareM Offline
        martinhjelmare
        Which arduino model are you using for the gateway?
        • ? Offline
          ? Offline
          A Former User
          Its a nano.
            martinhjelmare
            Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
            Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
            • ? Offline
              ? Offline
              A Former User
              no i haven't, so i have just removed the line, and restarted HA.
              But no luck. im still getting this.
                  baud=baud_rate)
                  func(filename)
              • ? Offline
                ? Offline
                A Former User
                okay putting
                Will get the gateway started. but will result in a file not found. if i put the correct path in like
                persistence_file: '/var/opt/homeassistant/mysensors.json'
                i get this in the log.
                16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                    baud=baud_rate)
                    func(filename)
                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                    self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                  File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                    parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                  File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                    return cls(**kw).decode(s)
                  File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                  File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                    raise ValueError(errmsg("Expecting value", s, err.value)) from None
                ValueError: Expecting value: line 1 column 1 (char 0)
                  martinhjelmare
                  #22
                  If you check the content of
                  What does it show?
                  • ? Offline
                    ? Offline
                    A Former User
                    That's where all my configuration is. And there is a mysensors.json file present.
                      martinhjelmare
                      #24
                      Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
                      Edit: Also delete any pickle files, if any.
                      • ? Offline
                        ? Offline
                        A Former User
                        wrote on last edited by A Former User
                        #25
                        full path and no file, gets me
                        File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
                        but will get me a gateway started.
                          martinhjelmare
                          #26
                          That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
                          • ? Offline
                            ? Offline
                            A Former User
                            nope no file
                              martinhjelmare
                              Oh yeah, I think it will create it when the first sensor is added.
                              Do you get the gateway started message now?
                              • ? Offline
                                ? Offline
                                A Former User
                                Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
                                  martinhjelmare
                                  Yes. Make sure you follow the presentation guide in the docs for mysensors on the HA web.
                                  • ? Offline
                                    ? Offline
                                    A Former User
                                    thank you so much, that seem to do the trick. the gate way was started and the sensor was add, as soon as it was turned on.
                                      martinhjelmare
                                      :thumbsup:
                                      I'll think about updating the docs at HA web, to explain things a bit more.
                                      • ? Offline
                                        ? Offline
                                        A Former User
                                        Maybe also put in about the pyserial?
                                          martinhjelmare
                                          Well pyserial should be installed automatically when you run hass the first time with mysensors activated in the config. There shouldn't be a need to do that on your own.
                                          Are you sure it wasn't installed for you?
