  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 136.7k Views 27 Watching
  • radekzmR
    radekzmR
    radekzm
    I still have a few questions:
    Use: https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
    1) Architecture: Do I understand correctly, example test:
    raspberry pi domoticz [USB] <---- USB RS232 built-in Arduino nano ----> (hardware RS232, PIN: tx/rx) Arduino Nano (Gatwey RS485) (AltSoftSerial, PIN: 2,7,8) <---- RS485 AltSoftSerial ----> (AltSoftSerial, PIN: 2,7,8) Arduino Pro Mini <------ PIN 3, DHT22
    2) Gatwey RS485 Arduino Nano:
    • USB port of the Arduino Nano plugs in to Raspberry PI and set MySensors USB gateway in Domoticz ?
    • Gatwaey to communicate with RS485 uses AltSoftSerial ? Whta PIN ? R0 / DI ?
    • Gatwey Arduino Nano to communicate with Raspberry PI (Domoticz) use hardware USB (built in RS232) ?
    • Gatweway don't have Debug mode (no free RS) ? When uploading have I must turn of debug mode in MyConfig.h when use RS485?
    • DE PIN 2 ?
    • RO PIN 8 ?
    • DI PIN 9 ?
    • PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
     * The gateway uses AltSoftSerial to handle two serial links
     * on one Arduino. Use the following pins for RS485 link
     *  Board          Transmit  Receive   PWM Unusable
     * Teensy 3.0 & 3.1  21        20         22
     * Teensy 2.0         9        10       (none)
     * Teensy++ 2.0      25         4       26, 27
     * Arduino Uno        9         8         10  <----- Form https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html .... (& other ATMEGA328)
     * Arduino Leonardo   5        13       (none)
     * Arduino Mega      46        48       44, 45
     * Wiring-S           5         6          4
     * Sanguino          13        14         12
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    3) Sensor Arduino Pro mini
    • What uses to communicate with RS485 bus ? Hardware RS232 Pin RX /TX or AltSoftSerial Pin 2/7/8 ?
    • If use AltSoftSerial: PIN 2/8/9 connected directly without pull-up resistors or current limiting ?
    • When uploading have I must turn of debug mode in MyConfig.h when use RS485?
    #define MY_RS485
    // Define this to enables DE-pin manag ement on defined pin
    #define MY_NODE_ID 15
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    unsigned long SLEEP_TIME = 2000; // Sleep time between reads (in milliseconds)
    // Initialize sensors
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    // Debug
    //#include <SoftwareSerial.h>
    //SoftwareSerial mySerial(3, 4); // RX, TX
      //mySerial.begin(4800);
      //mySerial.println("Hello, world?");
      sendSketchInfo("Falskiego LED salon", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        #ifdef MY_DEBUG
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
    Schema
    Schema
    Schema
    • P
      P
      pjr
      • radekzmR
        radekzmR
        radekzm
        wrote on last edited by radekzm
        #71
        I made a test: did the system sends data from the sensor DHT22 to the rail 485 using only library AltSoftSerial and everything works properly. So the connection is ok.
        I used the same libraries:
        #include <AltSoftSerial.h>
        The same connections:
        http://cmss.pl/arduino/MySensor_RS485_test02_a.JPG
        A ) RS485 Gatwaey (arduino nano):
        http://cmss.pl/arduino/MySensor_RS485_test02_b.JPG
        DE and RE -> Pin 2
        RO -> Pin 8
        DI -> Pin 9
        Uploaded example MySensors Gatwey 485 and own code.
        B ) RS485 Sensor DHT22 (arduino nano):
        http://cmss.pl/arduino/MySensor_RS485_test02_c.JPG
        DE and RE -> Pin 2
        RO -> Pin 8
        DI -> Pin 9
        Unfortunately, nothing works, no reaction, empty on debug console.
        Any ideas what could be wrong, what to check ???
          Sorry to hear, I still haven't verified this so there might be problems.
          It's this file that should be of interest:
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransportRS485.cpp
          Would be excellent if you had the time to debug it.
          radekzmR 1 Reply Last reply
            radekzmR
            radekzmR
            radekzm
            @hek
            Ok I will try.
            finezzaF 1 Reply Last reply
            • radekzmR radekzm
              @hek
              Ok I will try.
              finezzaF
              finezzaF
              finezza
              Hi I've tried a couple of months ago with success.
              Maybe you have to connect also the GND cable each other.
              Bye
              • MichalM
                MichalM
                Michal
                wrote on last edited by Michal
                #75
                I have tired similar configuration as radekzm.
                2 x Arduino nano connected via RS485 and is looks like only rs485 is not working so my question is; How to verified that connection between to arduinos using library AltSoftSerial is ok ?
                Are this connections PIN <-> RS485 (below) OK ?
                DE and RE -> Pin 2
                RO -> Pin 8
                DI -> Pin 9
                And below example is working fine (SoftwareSerial.h library)
                https://arduino-info.wikispaces.com/SoftwareSerialRS485Example
                • MichalM Michal
                  DE and RE -> Pin 2
                  RO -> Pin 8
                  DI -> Pin 9
                  radekzmR
                  radekzmR
                  radekzm
                  @Michal
                  I'll help when I get back from work.
                  MichalM 1 Reply Last reply
                  • elmarculinoE
                    elmarculinoE
                    elmarculino
                    @LeoDesigner
                    I'm trying a Gateway & 4 relays/4 switches configuration using 1.5.2 version. As @Michal my configuration works fine with this example: https://arduino-info.wikispaces.com/SoftwareSerialRS485Example
                    Anything wrong with my sketches?
                    Gateway:
                     * LEDs (OPTIONAL):
                    #define NO_PORTB_PINCHANGES
                    #include <MySigningNone.h>
                    #include <MyTransportRFM69.h>
                    //#include <MyTransportNRF24.h>
                    //#include <MyHwATMega328.h>
                    #include <SerialTransport.h>
                    #include <MyParserSerial.h>
                    #include <stdarg.h>
                    #include <PinChangeInt.h>
                    #include "GatewayUtil.h"
                    //MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                    //MyTransportRFM69 transport;
                    MyTransportSerial transport(Serial,AUTO,2);
                    //MySigningNone signer;
                    //MySigningAtsha204 signer;
                    // Hardware profile
                    MyHwATMega328 hw;
                    #ifdef WITH_LEDS_BLINKING
                    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                    int inputPos = 0;
                    boolean commandComplete = false;  // whether the string is complete
                    void parseAndSend(char *commandBuffer);
                    void output(const char *fmt, ... ) {
                       va_list args;
                       va_start (args, fmt );
                       va_end (args);
                       Serial.print(serialBuffer);
                      // Add interrupt for inclusion button to pin
                      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                      // Send startup log message on serial
                      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                      checkInclusionFinished();
                      if (commandComplete) {
                        // A command wass issued from serial interface
                        // We will now try to send it to the actuator
                        parseAndSend(gw, inputString);
                        inputPos = 0;
                      SerialEvent occurs whenever a new data comes in the
                     hardware serial RX.  This routine is run between each
                     time loop() runs, so using delay inside loop can delay
                     response.  Multiple bytes of data may be available.
                    void serialEvent() {
                      while (Serial.available()) {
                        // get the new byte:
                        char inChar = (char)Serial.read();
                        // if the incoming character is a newline, set a flag
                        // so the main loop can do something about it:
                        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                          if (inChar == '\n') {
                            inputString[inputPos] = 0;
                            commandComplete = true;
                            // add it to the inputString:
                            inputString[inputPos] = inChar;
                            inputPos++;
                            inputPos = 0;
                    4 relays / 4 switches
                      State change detection (edge detection)
                     Often, you don't need to know the state of a digital input all the time,
                     but you just need to know when the input changes from one state to another.
                     For example, you want to know when a button goes from OFF to ON.  This is called
                     state change detection, or edge detection.
                     This example shows how to detect when a button or button changes from off to on
                     and on to off.
                     The circuit:
                     * pushbutton attached to pin 2 from +5V
                     * 10K resistor attached to pin 2 from ground
                     * LED attached from pin 13 to ground (or use the built-in LED on
                       most Arduino boards)
                     created  27 Sep 2005
                     modified 30 Aug 2011
                     by Tom Igoe
                    This example code is in the public domain.
                     http://www.arduino.cc/en/Tutorial/ButtonStateChange
                    //#include <MyTransportRFM69.h>
                    // this constant won't change:
                    int buttonPin[] = {9, 10, 11, 12};          // array of pins that the pushbutton is attached to
                    int relayPin[] = {3, 4, 5, 6};           // array of pins that the relay is attached to
                    int pinCount = 4;                  // number of buttons/relays attached
                    // Variables will change:
                    int buttonState[] = {0, 0};         // current state of the button
                    int lastButtonState[] = {0, 0};     // previous state of the button
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int relayState[] = {RELAY_OFF, RELAY_OFF};   // counter for the number of button presses
                    //MyTransportRFM69 radio;
                    // Message signing driver (none default)
                    // Select AtMega328 hardware profile
                    MyHwATMega328 hw;
                    MySensor gw(transport, hw);
                      gw.sendSketchInfo("Relays & Buttons", "1.0");
                      for (int i = 0; i < pinCount; i++) {
                        gw.present(buttonPin[i], S_LIGHT);
                        gw.present(relayPin[i], S_LIGHT);
                        // initialize the button pin as a input:
                        pinMode(buttonPin[i], INPUT);
                        digitalWrite(buttonPin[i], 0);
                        // initialize the relay as an output:
                        pinMode(relayPin[i], OUTPUT);
                        digitalWrite(relayPin[i], gw.loadState(i)?RELAY_ON:RELAY_OFF);
                        MyMessage msg(relayPin[i], V_LIGHT);
                        buttonState[i] = digitalRead(buttonPin[i]);
                        if (buttonState[i] != lastButtonState[i]) {
                          if (buttonState[i] == 1) {
                    //         gw.send(msg.set(relayState[i]==RELAY_ON ? RELAY_OFF : RELAY_ON));
                    //          if(relayState[i]==RELAY_ON) gw.send(msg.set(RELAY_OFF));
                    //          else                        gw.send(msg.set(RELAY_ON));
                              if(relayState[i]==RELAY_ON) relayState[i]=RELAY_OFF;
                              else                        relayState[i]=RELAY_ON;
                          lastButtonState[i] = buttonState[i];
                        digitalWrite(relayPin[i], relayState[i]);
                      if (message.type==V_LIGHT) {
                            // digitalWrite(message.sensor-1+relayPin[1], message.getBool()?RELAY_ON:RELAY_OFF);
                    L 1 Reply Last reply
                    • elmarculinoE elmarculino
                      @LeoDesigner
                      Gateway:
                       * LEDs (OPTIONAL):
                      #include <stdarg.h>
                      // Hardware profile
                      MyHwATMega328 hw;
                      int inputPos = 0;
                         va_list args;
                         va_end (args);
                          inputPos = 0;
                              inputPos++;
                              inputPos = 0;
                       and on to off.
                       The circuit:
                       created  27 Sep 2005
                       by Tom Igoe
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      MyHwATMega328 hw;
                      L
                      L
                      LeoDesigner
                      @elmarculino
                      In Gateway:
                      Should be:
                      MyTransportSerial transport(Serial,0,2);
                      In 4relay / 4 switches:
                      Personally I am assigning a static ID to nodes, so I did not tested an AUTO option in gw.init. However I think this it should work. Also make sure you are downloaded a latest Serial transport class from github with some minor corrections.
                      • elmarculinoE
                        elmarculinoE
                        elmarculino
                        @LeoDesigner
                        Thanks for the help. I made the changes you pointed out, but still no lucky. What controller are you using? This should work in a direct crossover connection too?
                          @LeoDesigner
                          L
                          L
                          LeoDesigner
                          @elmarculino
                          I am using a custom controller based on the node-red, mqtt broker and homeassitant with mqtt bindings. But this is not essential - you can use 'nc GW_IP GW_PORT' from unix command line to issue commands to gateway directly. Try to separate your basic building blocks to smallest parts and then debug it.
                          • elmarculinoE
                            elmarculinoE
                            elmarculino
                            @LeoDesigner I still could not make it work in 1.5.2 with your library, but I will keep trying. Thanks!
                            @hek I finally could make a gateway / sensor (Humidity) connection via RS485 using the development branch. Is any Controller compatible with the development branch? Thanks!
                            0;255;3;0;9;Starting gateway (RSNGA-, 2.0.0-beta)
                            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.0
                            1;0;1;0;1;44.0
                            0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.0
                            1;0;1;0;1;43.0
                            1;0;1;0;1;44.0
                            0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:27.0
                            1;1;1;0;0;27.0
                              Great to hear. Did you need to make any adjustments?
                              Yes, the serial protocol is backward compatible. So any controller should work as good.
                              • elmarculinoE
                                elmarculinoE
                                elmarculino
                                @hek None. Works out of the box. But I could not make it work with Home Assistant.
                                Pin 9 >>> DI
                                Pin 8 >>> RO
                                Pin 2 >>> DE and RE
                                INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                INFO:mysensors.mysensors:n:0 c:255 t:3 s:9 p:read: 1-1-0 s=0,c=1,
                                WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                                WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.```
                                • elmarculinoE
                                  elmarculinoE
                                  elmarculino
                                  @LeoDesigner My 1.5.2 RS485 Humidity sensor send the same messages as the example Humidity sketch, but shows a lot of 'X' and '?' characters at 115200 in Serial Console.
                                  The console with the example Humidity sketch is clean:
                                  sensor started, id=1, parent=0, distance=1
                                  send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
                                  send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                  send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                  send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:26.0
                                  T: 26.00
                                  send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:44.0
                                  H: 44.00
                                  Do you know what can be causing it? Am I doing anything wrong, again?
                                  MyTransportSerial transport(Serial,5,2);
                                  MyHwATMega328 hw;
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                    gw.begin();
                                    gw.sendSketchInfo("Humidity", "1.0");
                                      if (!metric) {
                                        lastHum = humidity;
                                    T: 26.00
                                    H: 44.00
                                    MyHwATMega328 hw;
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                      gw.begin();
                                        if (!metric) {
                                          lastHum = humidity;
                                    L
                                    L
                                    LeoDesigner
                                    wrote on last edited by LeoDesigner
                                    #85
                                    @elmarculino
                                    My library is using a standard hardware serial port of arduino - you have to disable debug option in MySensors config and use the serial port only for RS485. The 'garbage' you are receiving are actual binary communication packets intended only for RS485 bus. You have to disconnect your serial to usb adapter in case if you are using Arduino Pro. Please take a closer look to the video and schematic coming with the library. You can use and 'sniff' your serial console - but you must to disable any additional serial debug prints to the console in production mode. Remember - your serial console is a RS485 bus with this library.
                                    • radekzmR radekzm
                                      @Michal
                                      MichalM
                                      MichalM
                                      Michal
                                      @radekzm
                                      OK, what I did:
                                      on one Arduino nano I have this sketch
                                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
                                      on second arduino nano I have conbined two sketches:
                                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/DistanceSensor/DistanceSensor.ino
                                      and
                                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/MotionSensorRS485/MotionSensorRS485.ino
                                      and the results is:
                                       * Version 1.0 - Henrik Ekblad
                                       * This is an example of sensors using RS485 as transport layer
                                       * The transport uses AltSoftSerial to handle two serial links
                                       * Wiring-S           5         6          4
                                       * Sanguino          13        14         12 *
                                      #define MY_RS485
                                      #include <NewPing.h>
                                      #define CHILD_ID 1
                                      #define TRIGGER_PIN  5  // Arduino pin tied to trigger pin on the ultrasonic sensor.
                                      #define ECHO_PIN     6  // Arduino pin tied to echo pin on the ultrasonic sensor.
                                      #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
                                      unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
                                      NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
                                      MyMessage msg(CHILD_ID, V_DISTANCE);
                                      int lastDist;
                                        sendSketchInfo("Distance Sensor", "1.0");
                                        present(CHILD_ID, S_DISTANCE);
                                        int dist = metric?sonar.ping_cm():sonar.ping_in();
                                        Serial.print("Ping: ");
                                        Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                                        Serial.println(metric?" cm":" in");
                                        if (dist != lastDist) {
                                            send(msg.set(dist));
                                            lastDist = dist;
                                        sleep(SLEEP_TIME);
                                      On serial port (/dev/ttyUSB0) Controller (first nano) I see:
                                      on serial port(/dev/ttyUSB1) in node is see:
                                      Ping: 33 cm
                                      Ping: 34 cm
                                      Ping: 34 cm
                                      Ping: 33 cm
                                      Ping: 33 cm
                                      Ping: 33 cm
                                      Ping: 5 cm
                                      Ping: 91 cm
                                      Ping: 88 cm
                                      Ping: 89 cm
                                      But I expect to see some message on controller. What can I check? Do you see and mistakes ?
                                        Mariusz
                                        wrote on last edited by Mariusz
                                        #87
                                        I am new in mysensors and arduino however I already use domoticz with mysensors and rflink.
                                        Everything is working fine however now I plan to renovate my house and I would like to put wire connection using max485 and arduino. Problem is that it is now working :( I have tried 1.5.4 version and also development branch. It seems that signal is not getting to gateway. I nothing see on arduino gateway except of initalization gateway. I have started to use two nano but I also tried combination nano and mega without success. I would be very appreciate if someone who done it could more describe how to make that it works.
                                        I tried https://arduino-info.wikispaces.com/SoftwareSerialRS485Example and it works fine.
                                        I use for nano combination pins 2 (de/re), 8 (ro),9(di)
                                        • M Mariusz
                                          radekzmR
                                          radekzmR
                                          radekzm
                                          @Mariusz jak jesteś Polakiem ? Jeżeli tak to mogę Ci pomóc po polsku będzie łatwiej :)
                                          m26872M 1 Reply Last reply
