  3. 1.4b Radio Transmission(?) Problem Not Present in 1.3b
16 Posts 5 Posters 5.7k Views 2 Watching
  • RJ_MakeR RJ_Make
    @hek
    I'm sorry, those voltage readings are @ the radio vcc pin (the USB source I'm using an FTDI set to 3.3v to connect to the Arduino).
    I don't believe this problem has anything to do with utilizing a battery vs hardwired power source. I don't plan on running this project on battery's, but in my testing I believe I've found a strange problem in 1.4b, as I had the same communication problem with all my temps sensors while on battery power, but not on the other 2 methods after moving to 1.4b
    I think one of 2 things are happening here. The step up regulator IS causing a problem in 1.4b that is not present in 1.3b in my environment. What I'm not sure is if it has to do with the 3.325vdc or some other noise problem the regulator is creating.
    I scrounge up some old batteries, which are @ 2.842vdc and everything is still working, as soon as I use the regulator and the voltage @ the radio is 3.326 (on same batteries) it fails..
    @ServiceXp
    The radio messages is sent in bursts in 1.4. This probably uses more power for a short split of a second and the voltage drop may very well be larger.
    RJ_MakeR 1 Reply Last reply
      @ServiceXp
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @hek
      Any way to resolve?. Is there anyway you can build up a 3.3 mini pro with regulated power test bed? I've got to believe that this problem is reproducible.
      In my testing it seems that when the voltage @ the radio's vcc pin is above 3.310vdc we stop communicating properly. When I'm below that level, even down to 2.82vdc proper communication is established.
      RJ_Make
      • RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek
        Ok so it's definitely a voltage problem to the radio in 1.4b.
        Using a 1N5226B Zener Diode and a 22ohm resistor across the regulated supply, I was able to reduce the regulated voltage down to 2.901vdc. and with that we now have communication using the step up regulator.
        I don't know much about electronics and it's interaction between code, but this is the strangest thing I've seen. Not sure how one set of 'firmware' works perfectly fine with higher radio vcc, and another does not.
        If this is reproducible, I guess there will be some hardware changes required for 1.4b.
        RJ_Make
        • JohnJ
          JohnJ
          John
          Because it is send in bursts it can require more current then when not send in bursts. Can not check because have only a cheap multimeter which does not show maximum currents and is not fast enough to show even the current used.
          Also i have a device with multiple sensors and display where the radio which is getting 3.4something volts from a L78L33AC regulator which is having an regulated input of 5 volts from a power source regulator and it works almost perfectly in the beginning but now perfectly.
          I forgot to put a capacitor between the L78 Vout and RF Vin / ground. But now it is sending happily even when there is current pulled by the display (120>ma when back light is on) at the same time.
          If you have the equipment check if the supplied current is the same in all the configurations. Maybe the regulator is requesting to much current to step up in combination with the radio when sending and the batteries can not supply it.
          • JohnJ John
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @John
            Yeah I only have a Fluke 16, so I can't measure the current while the radio is transmitting either. Are there any alternative step up regulators to the one in the store? http://www.ebay.com/itm/231083181020
            RJ_Make
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Looking at the specs on the regulator I listed, I doubt the radio is exceeding 400-600MA?
              RJ_Make
              • RJ_MakeR
                RJ_MakeR
                RJ_Make
                Looks like the NRF24L01 power consumption is WAY below the regulators limit.
                11.3mA Radio TX at 0dBm
                12.3mA Radio RX at 2Mbps on-air data-rate
                RJ_Make
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  wrote on last edited by bjornhallberg
                  Yeah those regulators in the Ebay store are probably not great. Decoupling is probably a good idea, but 4.7nF wasn't enough if I recall an earlier discussion correctly. Try 22nF or something like that. Or ceramic? But you can probably run the sensors on just 2x1.5V batteries for the time being, until another regulator is available. That is what I plan to do anyway.
                  The boost modules that @axillent was prototyping can't arrive fast enough :-)
                  YveauxY RJ_MakeR 2 Replies Last reply
                    I guess you mean 4.7uF and 22uF (micro Farad instead of nano Farad)?!
                    • RJ_MakeR RJ_Make
                      @ServiceXp Looks like actual power consumtion is much less. See http://forum.mysensors.org/topic/250/how-do-i-use-the-interrupt/13
                      • JohnJ
                        JohnJ
                        John
                        It was just a wild guess, because i personally didn't have any noticeable problems haven't dived deep into to hardware (yet), only software part.
                        • YveauxY Yveaux
                          bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          @Yveaux Haha, yeah, uF. But I think I remember some thread where we tried larger capacitors with greater success. Basically, the 4.7uF was pretty much useless?
                            RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            @bjornhallberg
                            That was it!!!!! I tried 22uF, was still doggie, so I thought why not move up to 47uF ;-) and what do you know, that seems to be the winning value. I have some more testing, but looking pretty good so far.
                            Thanks everybody for all the suggestions.
                            RJ_Make
