  3. M_ACK_VARIABLE or M_SET_VARIABLE
3 Posts 2 Posters 1.1k Views 3 Watching
  • LyubomyrL
    LyubomyrL
    Lyubomyr
    In servo actuator sketch there is a line
    if (message.type==V_DIMMER) { // This could be M_ACK_VARIABLE or M_SET_VARIABLE
    I do not understand the comment at all. I searched, but I can't find any information about M_ACK_VARIABLE or M_SET_VARIABLE
    Please, help me to understand how can I send these type of messages, why one would like to do that and when is it necessary to use them.
    Can Domoticz sent theses messages?
    BartEB 1 Reply Last reply
    • LyubomyrL Lyubomyr
      BartEB
      BartEB
      BartE
      @Lyubomyr This M_ACK_VARIABLE or M_SET_VARIABLE looks like a left over from old releases
      but what is meant here:
      if (message.type==V_DIMMER) {  // can be a new set dimmer value form the Gateway or an acknowledge from a previous send message
      In this example there are no message send and thus not acknowledged .
      In other examples this line is seen, making the distinguish between new value or ACK
        if (message.isAck()) {
      Requesting for an ACK when sending a message is done by setting the third parameter of gw.send() to true
      gw.send(msg.set(state?false:true), true);
      • LyubomyrL
        LyubomyrL
        Lyubomyr
        Thank You very much!
