716 Posts 111 Posters 703.1k Views 93 Watching
  • D
    Dylano
    mmmm i think that al this work, for a 4 weeks working sensor is not a good solution for a home automation system....
    Why can a Zwave or 433Mhz motion sensor work for more then a year...
    Is my biggest question..
    Forum link
    Is there relay now solution for a battery live for a year...
    Other bord, other sketch, other regulator, other battery...
    or...
    Domoticz, with a lot of working hardware, include mysensors :-)
    OpenPLI, RuneAudio, Solarmeter, etc......
    Not a great builder of software and hardware, more a user...
    Only i try to do my best :-(
    Sander TeunissenS 1 Reply Last reply
    • D Dylano
      Forum link
      or...
      Sander TeunissenS
      Sander TeunissenS
      Sander Teunissen
      @Dylano Google for low power arduino mini. Or arduino mini on battery. I've got one running now for half a year on two aaa batteries. Only lost 10% or something.
      (Quickest is to remove the led and the voltage regulator)
      • sundberg84S
        sundberg84S
        @Dylano Im not sure if I understand what you mean. This PCB does not support 433mhz or Zwave. You need to make that a question in the forum. I have nodes with this PCB now almost running for a year, and reporting good battery level.
        As Sander told you above, remove led and voltage regulator on a 3.3v arduino and you will run a mysensor node for a year:
        L 1 Reply Last reply
        • Sander TeunissenS
          Sander TeunissenS
          Sander Teunissen
          wrote on last edited by Sander Teunissen
          #111
          A 1 Reply Last reply
          • Sander TeunissenS Sander Teunissen
            [[topic:post-is-deleted]]
            Alexander
            @Sander-Teunissen I have some rev6 that I am willing to sell. Let me know if you are interested.
            • OitzuO
              OitzuO
              Oitzu
              If someone has one of these left in germany or nearby i'm willing to buy one for daugther-board dev purposes.
              • sundberg84S sundberg84
                L
                L
                lxz
                wrote on last edited by lxz
                #114
                I see that battery measuring is not working in my case.
                Can you post your sketch for a DHT22 or dallas sensor? Because readVCC.h does not work with a step up booster and 2x AA batteries connected, it seems..
                • sundberg84S
                  sundberg84S
                  #115
                  @lxz This is my code (Note dev branch!) for DHT22 incl battery measuring (2xAA).
                  The reason for readVCC:h does not work is that you measure after the booster = always 3.3V!
                  // Enable debug prints
                  #define MY_NODE_ID 15
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
                  #define SKETCH_NAME "UtomhusHumSyd #15"                // Change to a fancy name you like
                  #define SKETCH_VERSION "1.0"                    // Your version
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                  boolean metric = true;
                    present(CHILD_ID_HUM, S_HUM);
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      Serial.print("T: ");
                    if (isnan(humidity)) {
                        lastHum = humidity;
                        Serial.print("H: ");
                        Serial.println(humidity);
                    batM();
                     delay(500);
                     // Battery monitoring reading
                     delay(500);
                     // Calculate the battery in %
                     if (batLoop > 2) {
                     if (batteryPcnt > 100) {
                       batteryPcnt=100;
                         batLoop = 0;
                       batLoop++;
                  • pkriekP
                    pkriekP
                    pkriek
                    Hi
                    I also bought v8 of these boards. 2 sensors up an running perfect.
                    2 others modules on the other hand, I think I fried the arduino. I am using 5v mini's. They worked when programming thru the USB port. Also communication with domoticz. They stopped working when I attached the 6v external adapter. I connected these to the ground and power connector. Now lights go on, but nothing anymore also not on the serial monitor.
                    Should I have used the raw connector????
                    thanks for helping
                    • sundberg84S
                      sundberg84S
                      #117
                      Short answer - yes you should have used RAW. But at least you learned a lesson if you want to think positive. ☺
                      Try and see what happens if you change. Maybe they are still OK.
                      • pkriekP
                        pkriekP
                        pkriek
                        thanks!, lessons learned indeed. . Great stuff though.
                        • scooter217S
                          scooter217S
                          scooter217
                          what size terminal blocks do you buy? I bought some and they are the wrong size.
                          • scooter217S scooter217
                            Samuel235
                            #120
                            @scooter217, from a quick inspection of the .brd file and a look around the internet for the datasheets it would seem that sundberg has allowed for any screw terminal block that uses a 5mm pin pitch. So you would need a 3 terminal 5mm pin pitch screw terminal. Please allow @sundberg84 some time to reply to ensure I am correct.
                            MySensors 2.1.1
                            • sundberg84S
                              sundberg84S
                              @scooter217 : http://www.ebay.com/sch/sis.html?_nkw=20pcs+KF301-2P+2+Pin+Plug-in+Screw+Terminal+Block+Connector+5.08mm+Pitch&_id=181759858196&&_trksid=p2057872.m2749.l2658
                              scooter217S 1 Reply Last reply
                                scooter217S
                                scooter217S
                                scooter217
                                @sundberg84 Thank you, just ordered some from ebay!
                                  Matt
                                  wrote on last edited by Matt
                                  #123
                                  Hi Sundberg.
                                  First of all thanks for what you have done here, and hi from New Zealand.
                                  I have a problem though, sorry to be a hassle.
                                  I assembled my first board tonight and I dont get 3.3v across the NRF. It starts at 0.07V then falls down to 0 on my cheap meter. Same on the MYSX1.4 connector at 3.3 and gnd. Am getting 3.3 on the mini as well as VCC and GND on the MYSX area so the regulator is working. May be a short? Or a bad solder? Although they look good to me.... If so what solder joints should I redo? Any other ideas?
                                  Also, Ive traced back the VCC from the NRF and I cant see where it connects to a power source, either the battery in or the boost converter?
                                  Matt
                                  • M Matt
                                    Hi Sundberg.
                                    Matt
                                    sundberg84S
                                    sundberg84S
                                    @Matt Hi Matt - tnx.
                                    Try to measure here: whats your reading?
                                    if its 3.3v its your radio thats has some error... this is prettu much the last point before radio. Also measure VCC/GND under the pcb and not on top, what does it say?
                                    Sounds like a short or bad solder...
                                      Matt
                                      @sundberg84
                                      Ah crikey I think Im being thick, I just put a jumper across BAT connectors after tracing the lines and reading the manual, am now getting 2.8 at the NRF. Sorry for being a numpty. Still not picking up on my gateway, time to go to bed but will get the serial monitor running tomorrow....
                                      Thanks for the quick reply.
                                      • ValleV
                                        ValleV
                                        Valle
                                        Finally got my boards. In color: Yellow.
                                        If I would skip the Booster is the esiest thing to just wire Vi - Vo?
                                        • N
                                          N
                                          nunver
                                          I have a question about using this board as a gateway. Pinout of Mini Pro and Nano are almost identical. I built an adapter board to plug in a Nano into this board. Pin by pin control shows it is OK. I checked connectivity with MYSController. The gateway boots up. When I turn on my battery powered sensor, it asks for ID, the gateway "supposedly" sends it. I watch this from the messages. The sensor does not register. It asks four more times, the gateway responds four times. But sensor could not be ID'd and of course registered.
                                          I am thinking either reception problem on sensor side, or transmission problem on gateway side? Could it be a power problem related with design of the board? Is there any way to identify?
