716 Posts 111 Posters 668.9k Views 93 Watching
  • Sander TeunissenS Sander Teunissen
    A Offline
    A Offline
    Alexander
    @Sander-Teunissen I have some rev6 that I am willing to sell. Let me know if you are interested.
    • O Offline
      O Offline
      Oitzu
      If someone has one of these left in germany or nearby i'm willing to buy one for daugther-board dev purposes.
      • S sundberg84
        @Dylano Im not sure if I understand what you mean. This PCB does not support 433mhz or Zwave. You need to make that a question in the forum. I have nodes with this PCB now almost running for a year, and reporting good battery level.
        As Sander told you above, remove led and voltage regulator on a 3.3v arduino and you will run a mysensor node for a year:
        L Offline
        L Offline
        lxz
        wrote on last edited by lxz
        #114
        I see that battery measuring is not working in my case.
        Can you post your sketch for a DHT22 or dallas sensor? Because readVCC.h does not work with a step up booster and 2x AA batteries connected, it seems..
        • S Offline
          #115
          @lxz This is my code (Note dev branch!) for DHT22 incl battery measuring (2xAA).
          The reason for readVCC:h does not work is that you measure after the booster = always 3.3V!
          // Enable debug prints
          #define MY_NODE_ID 15
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
          #define SKETCH_NAME "UtomhusHumSyd #15"                // Change to a fancy name you like
          #define SKETCH_VERSION "1.0"                    // Your version
          DHT dht;
          float lastTemp;
          float lastHum;
          boolean metric = true;
            present(CHILD_ID_HUM, S_HUM);
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
            batM();
             delay(500);
             // Battery monitoring reading
             delay(500);
             // Calculate the battery in %
             if (batLoop > 2) {
             if (batteryPcnt > 100) {
               batteryPcnt=100;
                 batLoop = 0;
               batLoop++;
          • pkriekP Offline
            pkriekP Offline
            pkriek
            Hi
            I also bought v8 of these boards. 2 sensors up an running perfect.
            2 others modules on the other hand, I think I fried the arduino. I am using 5v mini's. They worked when programming thru the USB port. Also communication with domoticz. They stopped working when I attached the 6v external adapter. I connected these to the ground and power connector. Now lights go on, but nothing anymore also not on the serial monitor.
            Should I have used the raw connector????
            thanks for helping
            • S Offline
              #117
              Short answer - yes you should have used RAW. But at least you learned a lesson if you want to think positive. ☺
              Try and see what happens if you change. Maybe they are still OK.
              • pkriekP Offline
                pkriekP Offline
                pkriek
                thanks!, lessons learned indeed. . Great stuff though.
                • scooter217S Offline
                  scooter217S Offline
                  scooter217
                  what size terminal blocks do you buy? I bought some and they are the wrong size.
                  S 1 Reply Last reply
                  • scooter217S scooter217
                    Samuel235
                    #120
                    @scooter217, from a quick inspection of the .brd file and a look around the internet for the datasheets it would seem that sundberg has allowed for any screw terminal block that uses a 5mm pin pitch. So you would need a 3 terminal 5mm pin pitch screw terminal. Please allow @sundberg84 some time to reply to ensure I am correct.
                    MySensors 2.1.1
                    • S Offline
                      @scooter217 : http://www.ebay.com/sch/sis.html?_nkw=20pcs+KF301-2P+2+Pin+Plug-in+Screw+Terminal+Block+Connector+5.08mm+Pitch&_id=181759858196&&_trksid=p2057872.m2749.l2658
                      scooter217S 1 Reply Last reply
                      • S sundberg84
                        scooter217S Offline
                        scooter217S Offline
                        scooter217
                        @sundberg84 Thank you, just ordered some from ebay!
                        • M Offline
                          M Offline
                          Matt
                          wrote on last edited by Matt
                          #123
                          Hi Sundberg.
                          First of all thanks for what you have done here, and hi from New Zealand.
                          I have a problem though, sorry to be a hassle.
                          I assembled my first board tonight and I dont get 3.3v across the NRF. It starts at 0.07V then falls down to 0 on my cheap meter. Same on the MYSX1.4 connector at 3.3 and gnd. Am getting 3.3 on the mini as well as VCC and GND on the MYSX area so the regulator is working. May be a short? Or a bad solder? Although they look good to me.... If so what solder joints should I redo? Any other ideas?
                          Also, Ive traced back the VCC from the NRF and I cant see where it connects to a power source, either the battery in or the boost converter?
                          Matt
                          • M Matt
                            Hi Sundberg.
                            Matt
                            @Matt Hi Matt - tnx.
                            Try to measure here: whats your reading?
                            if its 3.3v its your radio thats has some error... this is prettu much the last point before radio. Also measure VCC/GND under the pcb and not on top, what does it say?
                            Sounds like a short or bad solder...
                            • S sundberg84
                              M Offline
                              M Offline
                              Matt
                              @sundberg84
                              Ah crikey I think Im being thick, I just put a jumper across BAT connectors after tracing the lines and reading the manual, am now getting 2.8 at the NRF. Sorry for being a numpty. Still not picking up on my gateway, time to go to bed but will get the serial monitor running tomorrow....
                              Thanks for the quick reply.
                              • ValleV Offline
                                ValleV Offline
                                Valle
                                Finally got my boards. In color: Yellow.
                                If I would skip the Booster is the esiest thing to just wire Vi - Vo?
                                • N Offline
                                  N Offline
                                  nunver
                                  I have a question about using this board as a gateway. Pinout of Mini Pro and Nano are almost identical. I built an adapter board to plug in a Nano into this board. Pin by pin control shows it is OK. I checked connectivity with MYSController. The gateway boots up. When I turn on my battery powered sensor, it asks for ID, the gateway "supposedly" sends it. I watch this from the messages. The sensor does not register. It asks four more times, the gateway responds four times. But sensor could not be ID'd and of course registered.
                                  I am thinking either reception problem on sensor side, or transmission problem on gateway side? Could it be a power problem related with design of the board? Is there any way to identify?
                                  • S Offline
                                    @Valle - yes you can just put a wire between left and right pin - but it wont work for a long time (the pro mini will die when battery goes below 3v i think).
                                    @nunver - I have never used this board as gateway. What does your controller say, does it apply an ID for the request?
                                    ValleV N 2 Replies Last reply
                                    • S sundberg84
                                      ValleV Offline
                                      ValleV Offline
                                      Valle
                                      @sundberg84
                                      I'm using mfalkvidds Plant monitoring
                                      mfalkvidd said:
                                      So I will try without Booster. But for other sensors I will use booster.
                                      • ValleV Valle
                                        @sundberg84
                                        Sounds good - let us know how it works out for you. 2,34V is for a genuine Arduino so you know - I dont think a clone manages that... also the last energy (from 1,9 to 2,34v) is not used even though the radio could handle it if you used a booster.
                                        • Boots33B Offline
                                          Boots33B Offline
                                          Boots33
                                          Thanks @sundberg84 for this little board. I have just completed a sensor to monitor the state of our 12v house solar power supply.
                                          It uses an ACS712 Hall Effect Current Sensor Module to keep track of amps in and out of the battery. A voltage sensor to check battery levels and two DS18b20 temp sensors to monitor battery temp and ambient area temp. It reports back to our Domoticz server.
