  3. Capacitors and switching power supplies
13 Posts 7 Posters 4.9k Views 4 Watching
  • M Offline
    M Offline
    moskovskiy82
    I am using external chargers 5V for powering my sensors (some are old branded nokia ones, others are a cheap chinese replacement).
    Power goes to arduino VCC (arduino pro mini 5V) and also the NRF24 adapter board (containing the voltage regulator and some capacitors - got it off aliexpress).
    I wonder if adding a decoupling capacitor just before power is split to arduino and NRF24 board will help in any way. If yes what is the best value for the capacitor?
    Y 1 Reply Last reply
    • M moskovskiy82
      Y Offline
      Y Offline
      What exactly is your issue?
      • M Offline
        M Offline
        moskovskiy82
        I was wondering on the best practices
        • mfalkviddM Offline
          The recommendation is to place a 4.7uF cap as close as possible to the nrf chip. I am not familiar with the adapter board but the cap should be placed after the voltage regulator.
          • O Offline
            O Offline
            Oitzu
            Well, the arduino should have some decoupling on the board itself, also the decoupling on the NRF24 adapter board should be sufficent.
            You could add a low-pass filter after the power supply (are your supplys switching regulators?) to reduce the ripple produced, but the frequency rejection of the linear regulators should also handle this fine.
            M ronnyandreR 2 Replies Last reply
            • O Oitzu
              M Offline
              M Offline
              moskovskiy82
              @Oitzu
              Thanks for the great explanation!
              • O Oitzu
                ronnyandreR Offline
                ronnyandreR Offline
                ronnyandre
                @Oitzu do you have a recipe for making such low-pass filter?
                Newbie with RPi and Domoticz, trying to automate my home.
                A 1 Reply Last reply
                • ronnyandreR ronnyandre
                  A Offline
                  A Offline
                  AWI
                  wrote on last edited by AWI
                  @ronnyandre Things are sooo easy (if you have a degree in electronics ;-) ) An effective design includes multiple filters and depends for a great deal on the switching frequency (and harmonics). A typical design could look like this. 0_1492496982218_upload-8c6d3a13-308d-48a9-9bfa-45e7ca0f30c4
                  An linear regulator (like LM7805) can be very effective for low frequencies (~ < 10kHz) but not for high frequencies.
                  In most of the cases when working with phone mains adapters the 'standard' (uno/ nano) regulator (1117) with capacitors damps sufficiently.
                  • ronnyandreR Offline
                    ronnyandreR Offline
                    ronnyandre
                    Wow @AWI that looked more advanced than I thought.. :sweat_smile:
                    • O Offline
                      O Offline
                      Oitzu
                      @ronnyandre The main reason for using a filter would be a crappy/cheap switching power supply.
                      I needed to use one of these filters on a cheap LM2596s (clone) module to filter the output to a nrf24l01+ pa/lna module.
                      Unlike @AWI 's solution i just added a second stage after the first stage (that is on the module).
                      http://blog.blackoise.de/wp-content/uploads/2016/03/lc-filter-schem1.jpg
                      L1: 3.3µH
                      C1: 220µF
                      Worked fine enough to get the nrf24l01+ pa/lna module working.
                      ronnyandreR gohanG 2 Replies Last reply
                      • O Oitzu
                        L1: 3.3µH
                        C1: 220µF
                        ronnyandreR Offline
                        ronnyandreR Offline
                        ronnyandre
                        @Oitzu Thanks! I'll try that one out :simple_smile:
                        • O Oitzu
                          L1: 3.3µH
                          C1: 220µF
                          @Oitzu I am about to buy some of those LM2596s, the values for the filter components are suitable for LM2596 in general or it is something more specific that you had to calculate? Did you make the impedance yourself?
                          • O Offline
                            O Offline
                            Oitzu
                            @gohan these values are just the ones i used and should filter lowpass at about 5.9 kHz.
                            The ripple on the LM2596s is usually arround 25-50kHz. (Depends on which clone you get. ;))
                            I'm no electrical engineer. Maybe @AWI can comment if there may be a more suitable component selection.
                            12.1k
