  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.6k Views 58 Watching
  • tekkaT tekka
    @Fabien Are you running MYSController on WINE? I updated a few things, please update to the most recent version of MYSController (build 3312, here or via update button) and post the log. Thanks.
    F
    F
    Fabien
    wrote on last edited by Fabien
    #38
    @tekka I try with build 3312 and working fine with wine
    Now I'm looking for I_PRESENTATION. With 2.0 beta it doesn't seem to work. May I use smartSleep ?
    • F
      F
      Fabien
      So after few test, wrks fine with I_PRESENTATION request and using smartSleep (with interrupts too).
      • n1ck1355N
        n1ck1355N
        n1ck1355
        @tekka : do you have any clue whats wrong with my setup?
        tekkaT 1 Reply Last reply
        • DrJeffD
          DrJeffD
          DrJeff
          Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
          • n1ck1355N n1ck1355
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            #42
            @n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
            • DrJeffD DrJeff
              tekkaT
              tekkaT
              tekka
              @DrJeff No, only the nodes
              DrJeffD 1 Reply Last reply
              • tekkaT tekka
                DrJeffD
                DrJeffD
                DrJeff
                @tekka Cool thanks, can I use Arduino as ISP to program bootloader?
                • DrJeffD DrJeff
                  tekkaT
                  tekkaT
                  tekka
                  @DrJeff Yep :)
                  • tekkaT tekka
                    @DrJeff Yep :)
                    DrJeffD
                    DrJeffD
                    DrJeff
                    @tekka , Time to try Thanks! :)
                    • n1ck1355N
                      n1ck1355N
                      n1ck1355
                      @tekka yes ota fw updates works. Tried it with the Time fw
                      • n1ck1355N
                        n1ck1355N
                        n1ck1355
                        wrote on last edited by n1ck1355
                        #48
                        @tekka i musst revert my previous post...
                        I've OTA uploaded the sketch from my first post:
                          Serial.begin(57600);
                          Serial.println("Setup Start");
                        and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
                        However the time reporter firmware works fine.
                        • siklosiS
                          siklosiS
                          siklosi
                          Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
                          • rollercontainerR
                            rollercontainerR
                            rollercontainer
                            wrote on last edited by rollercontainer
                            #50
                            I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
                            Where is my fault?
                            • rollercontainerR rollercontainer
                              Where is my fault?
                              tekkaT
                              tekkaT
                              tekka
                              #51
                              @rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
                              • Thar0lT
                                Thar0lT
                                Thar0l
                                @tekka Serial not working after uploading MYSbootloader v1.3pre. ArduinoProMini 5v16Mhz. Is it normal?
                                • Thar0lT Thar0l
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Алексей-Гусаров please provide additional information such as config and logs.
                                  Thar0lT 1 Reply Last reply
                                  • tekkaT tekka
                                    Thar0lT
                                    Thar0lT
                                    Thar0l
                                    wrote on last edited by Thar0l
                                    #54
                                    @tekka
                                    boards.txt:
                                    ######## settings for ext XTAL 16Mhz, EESAVE, BOD1V8, no lock
                                    proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
                                    proMYSBL16.upload.tool=avrdude
                                    proMYSBL16.upload.protocol=arduino
                                    proMYSBL16.upload.maximum_size=30720
                                    proMYSBL16.upload.maximum_data_size=2048
                                    proMYSBL16.upload.speed=115200
                                    proMYSBL16.bootloader.tool=avrdude
                                    proMYSBL16.bootloader.low_fuses=0xFF
                                    proMYSBL16.bootloader.high_fuses=0xD2
                                    proMYSBL16.bootloader.extended_fuses=0x06
                                    proMYSBL16.bootloader.unlock_bits=0x3F
                                    proMYSBL16.bootloader.lock_bits=0x3F
                                    proMYSBL16.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                    proMYSBL16.build.mcu=atmega328p
                                    proMYSBL16.build.f_cpu=16000000L
                                    proMYSBL16.build.board=AVR_UNO
                                    proMYSBL16.build.core=arduino
                                    proMYSBL16.build.variant=standard
                                    ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock
                                    proMYSBL8.upload.tool=avrdude
                                    proMYSBL8.upload.speed=57600
                                    proMYSBL8.bootloader.high_fuses=0xD2
                                    proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                    proMYSBL8.build.board=AVR_UNO
                                    proMYSBL8.build.core=arduino
                                    MyConfig.h:
                                    #ifdef MY_DISABLED_SERIAL
                                    #undef MY_DEBUG
                                    #ifndef MY_BAUD_RATE
                                    #define MY_BAUD_RATE 115200
                                    //#define MY_RADIO_NRF24
                                    //#define MY_RS485
                                    #ifndef MY_NODE_ID
                                    #define MY_NODE_ID AUTO
                                    #ifndef MY_PARENT_NODE_ID
                                    #ifndef MY_OTA_FLASH_SS
                                    #define MY_OTA_FLASH_SS 8
                                    #ifndef MY_OTA_FLASH_JDECID
                                    //#define MY_LEDS_BLINKING_FEATURE
                                    //#define MY_DEFAULT_ERR_LED x
                                    //#define MY_DEFAULT_TX_LED x
                                    //#define MY_DEFAULT_RX_LED x
                                    		#define MY_INCLUSION_MODE_BUTTON_PIN 3
                                    //#define MY_SIGNING_ATSHA204
                                    //#define MY_SIGNING_SOFT
                                    #ifndef MY_RS485_BAUD_RATE
                                    #ifndef MY_RF24_CE_PIN
                                    		#define MY_RF24_CE_PIN 4
                                    		#define MY_RF24_CE_PIN 27
                                    		#define MY_RF24_CE_PIN 9
                                    #ifndef MY_RF24_CS_PIN
                                    		#define MY_RF24_CS_PIN 15
                                    		#define MY_RF24_CS_PIN 3
                                    		#define MY_RF24_CS_PIN 10
                                    #ifndef MY_RF24_PA_LEVEL
                                    #ifndef MY_RF24_CHANNEL
                                    #define MY_RF24_CHANNEL	76
                                    #ifndef MY_RF24_DATARATE
                                    #ifndef MY_RF24_BASE_RADIO_ID
                                    #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                                    //#define MY_SOFTSPI
                                    #ifndef MY_SOFT_SPI_SCK_PIN
                                    #ifndef MY_SOFT_SPI_MISO_PIN
                                    #ifndef MY_SOFT_SPI_MOSI_PIN
                                    #ifndef MY_RFM69_FREQUENCY
                                    //#define MY_IS_RFM69HW
                                    #ifdef MY_IS_RFM69HW
                                    	#define MY_RFM69HW true
                                    	#define MY_RFM69HW false
                                    #ifndef MY_RFM69_NETWORKID
                                    #ifndef MY_RF69_IRQ_PIN
                                    #ifndef MY_RF69_SPI_CS
                                    #ifndef MY_RF69_IRQ_NUM
                                    //#define MY_GATEWAY_W5100
                                    //#define MY_GATEWAY_ENC28J60
                                    //#define MY_GATEWAY_ESP8266
                                    #ifndef MY_PORT
                                    #define MY_PORT 5003
                                    //#define MY_USE_UDP
                                    #ifndef MY_MAC_ADDRESS
                                    #ifndef MY_NODE_UNLOCK_PIN
                                    #define MY_NODE_UNLOCK_PIN 14
                                    In node scetch:
                                    I have no logs from node because serial isn't working at all. Which logs should I attach?
                                    • Thar0lT Thar0l
                                      @tekka
                                      boards.txt:
                                      MyConfig.h:
                                      #undef MY_DEBUG
                                      //#define MY_RS485
                                      #ifndef MY_NODE_ID
                                      #ifndef MY_PORT
                                      In node scetch:
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #55
                                      @Алексей-Гусаров I'll look into that. Seems like bootloader is not handing over to the sketch (corroborates previous reports). Can you post the OTA log (from e.g. MYSController)?
                                      • tekkaT tekka
                                        Thar0lT
                                        Thar0lT
                                        Thar0l
                                        @tekka I'm using mycotroller.org instead of myscontroller. It writes that "firmware update initiated" and nothing happens.
                                        tekkaT J 2 Replies Last reply
                                        • Thar0lT Thar0l
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Алексей-Гусаров Then I highly suggest to run MYSController to log OTA traffic for troubleshooting...
