  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.6k Views 58 Watching
  • n1ck1355N n1ck1355
    thx tekka for clearing this :)
    for my bootloader problem:
    i burned the 1.3mysbootloader with the 8mhz config successfully from the arduino dev ide.
    then i uploaded a little test sketch like this without errors:
      Serial.begin(57600);
      Serial.println("Setup Start");
    but there is no output on the serial monitor. it lookes like the bootloader didn't start the sketch.
    tekkaT
    tekkaT
    tekka
    @n1ck1355 Please enable logging in MYSController, reboot the node and post the log here after a few mins of recording.
    • TakeroT
      TakeroT
      Takero
      Hi, i like OTA Update :-)
      How it is possible to change the Cannel from 76 to 105?
      rollercontainerR 1 Reply Last reply
      • TakeroT Takero
        rollercontainerR
        rollercontainerR
        rollercontainer
        @Takero https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyConfig.h#L387
        TakeroT 1 Reply Last reply
        • rollercontainerR rollercontainer
          TakeroT
          TakeroT
          Takero
          Yes, i know what, but this is not there I am looking for.
          The Autor wrote:
          Attached bootloader file, compiled with these settings:
          nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
          115200 baud (16Mhz) or 57600 (8Mhz)
          I want a Bootloader file with Channel 105.
          • TakeroT Takero
            rollercontainerR
            rollercontainerR
            rollercontainer
            sorry, you are right. Since the source isnt yet available, you cant compile your custom bootloader. So, thats a no.
            • n1ck1355N
              n1ck1355N
              n1ck1355
              @tekka here is the log output:
              05.04.16 21:51:34	STARTUP	Initialize message logging
              05.04.16 21:51:34	STARTUP	1.0.0 (build 3312)
              05.04.16 21:51:34	STARTUP	FPC 3.0.0 / Lazarus 1.6
              05.04.16 21:51:34	STARTUP	still under development :) tekka 2016
              05.04.16 21:51:34	STARTUP	Load INI file...
              05.04.16 21:51:34	STARTUP	INI version NA
              05.04.16 21:52:08	INFO	Connected to 192.168.0.101:5003
              05.04.16 21:52:23	RX	2;255;3;0;15;0100
              05.04.16 21:52:23	NODE	New node discovered, node id=2
              05.04.16 21:52:23	CHILD	New child discovered, node id=2, child id=internal
              05.04.16 21:52:30	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:52:30	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:52:30	INFO	BL version=258
              05.04.16 21:52:30	INFO	No FW assigned
              05.04.16 21:52:36	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:52:36	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:52:36	INFO	BL version=258
              05.04.16 21:52:36	INFO	No FW assigned
              05.04.16 21:52:43	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:52:43	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:52:43	INFO	BL version=258
              05.04.16 21:52:43	INFO	No FW assigned
              05.04.16 21:53:00	RX	2;255;3;0;15;0100
              05.04.16 21:53:07	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:07	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:07	INFO	BL version=258
              05.04.16 21:53:07	INFO	No FW assigned
              05.04.16 21:53:14	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:14	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:14	INFO	BL version=258
              05.04.16 21:53:14	INFO	No FW assigned
              05.04.16 21:53:21	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:21	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:21	INFO	BL version=258
              05.04.16 21:53:21	INFO	No FW assigned
              05.04.16 21:53:38	RX	2;255;3;0;15;0100
              05.04.16 21:53:45	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:45	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:45	INFO	BL version=258
              05.04.16 21:53:45	INFO	No FW assigned
              05.04.16 21:53:52	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:52	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:52	INFO	BL version=258
              05.04.16 21:53:52	INFO	No FW assigned
              05.04.16 21:53:58	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:53:58	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:53:58	INFO	BL version=258
              05.04.16 21:53:58	INFO	No FW assigned
              05.04.16 21:54:16	RX	2;255;3;0;15;0100
              05.04.16 21:54:23	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:54:23	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:54:23	INFO	BL version=258
              05.04.16 21:54:23	INFO	No FW assigned
              05.04.16 21:54:29	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:54:29	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:54:29	INFO	BL version=258
              05.04.16 21:54:29	INFO	No FW assigned
              05.04.16 21:54:36	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:54:36	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:54:36	INFO	BL version=258
              05.04.16 21:54:36	INFO	No FW assigned
              05.04.16 21:54:54	RX	2;255;3;0;15;0100
              05.04.16 21:55:01	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:01	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:01	INFO	BL version=258
              05.04.16 21:55:01	INFO	No FW assigned
              05.04.16 21:55:07	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:07	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:07	INFO	BL version=258
              05.04.16 21:55:07	INFO	No FW assigned
              05.04.16 21:55:14	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:14	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:14	INFO	BL version=258
              05.04.16 21:55:14	INFO	No FW assigned
              05.04.16 21:55:32	RX	2;255;3;0;15;0100
              05.04.16 21:55:38	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:38	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:38	INFO	BL version=258
              05.04.16 21:55:38	INFO	No FW assigned
              05.04.16 21:55:45	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:45	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:45	INFO	BL version=258
              05.04.16 21:55:45	INFO	No FW assigned
              05.04.16 21:55:52	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:55:52	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:55:52	INFO	BL version=258
              05.04.16 21:55:52	INFO	No FW assigned
              05.04.16 21:56:10	RX	2;255;3;0;15;0100
              05.04.16 21:56:16	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:56:16	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:56:16	INFO	BL version=258
              05.04.16 21:56:16	INFO	No FW assigned
              05.04.16 21:56:23	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:56:23	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:56:23	INFO	BL version=258
              05.04.16 21:56:23	INFO	No FW assigned
              05.04.16 21:56:30	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:56:30	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:56:30	INFO	BL version=258
              05.04.16 21:56:30	INFO	No FW assigned
              05.04.16 21:56:47	RX	2;255;3;0;15;0100
              05.04.16 21:56:54	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:56:54	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:56:54	INFO	BL version=258
              05.04.16 21:56:54	INFO	No FW assigned
              05.04.16 21:57:01	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:57:01	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:57:01	INFO	BL version=258
              05.04.16 21:57:01	INFO	No FW assigned
              05.04.16 21:57:07	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:57:07	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:57:07	INFO	BL version=258
              05.04.16 21:57:07	INFO	No FW assigned
              05.04.16 21:57:25	RX	2;255;3;0;15;0100
              05.04.16 21:57:32	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:57:32	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:57:32	INFO	BL version=258
              05.04.16 21:57:32	INFO	No FW assigned
              05.04.16 21:57:39	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:57:39	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:57:39	INFO	BL version=258
              05.04.16 21:57:39	INFO	No FW assigned
              05.04.16 21:57:45	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:57:45	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:57:45	INFO	BL version=258
              05.04.16 21:57:45	INFO	No FW assigned
              05.04.16 21:58:03	RX	2;255;3;0;15;0100
              05.04.16 21:58:10	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:58:10	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:58:10	INFO	BL version=258
              05.04.16 21:58:10	INFO	No FW assigned
              05.04.16 21:58:16	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:58:16	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:58:16	INFO	BL version=258
              05.04.16 21:58:16	INFO	No FW assigned
              05.04.16 21:58:23	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:58:23	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:58:23	INFO	BL version=258
              05.04.16 21:58:23	INFO	No FW assigned
              05.04.16 21:58:41	RX	2;255;3;0;15;0100
              05.04.16 21:58:45	USER	Debug=FALSE
              05.04.16 21:58:45	INFO	*** Logging STOP ***
              05.04.16 21:58:47	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:58:47	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:58:47	INFO	BL version=258
              05.04.16 21:58:47	INFO	No FW assigned
              05.04.16 21:58:54	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:58:54	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:58:54	INFO	BL version=258
              05.04.16 21:58:54	INFO	No FW assigned
              05.04.16 21:59:01	RX	2;255;4;0;0;FFFFFFFF0800077E0102
              05.04.16 21:59:01	DEBUG	Undefined firmware/type for node=2
              05.04.16 21:59:01	INFO	BL version=258
              05.04.16 21:59:01	INFO	No FW assigned
              hope it helps finding out whats wrong ;)
              • tekkaT tekka
                @Fabien Are you running MYSController on WINE? I updated a few things, please update to the most recent version of MYSController (build 3312, here or via update button) and post the log. Thanks.
                F
                F
                Fabien
                wrote on last edited by Fabien
                #38
                @tekka I try with build 3312 and working fine with wine
                Now I'm looking for I_PRESENTATION. With 2.0 beta it doesn't seem to work. May I use smartSleep ?
                • F
                  F
                  Fabien
                  So after few test, wrks fine with I_PRESENTATION request and using smartSleep (with interrupts too).
                  • n1ck1355N
                    n1ck1355N
                    n1ck1355
                    @tekka : do you have any clue whats wrong with my setup?
                    tekkaT 1 Reply Last reply
                    • DrJeffD
                      DrJeffD
                      DrJeff
                      Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #42
                        @n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
                        • DrJeffD DrJeff
                          tekkaT
                          tekkaT
                          tekka
                          @DrJeff No, only the nodes
                          DrJeffD 1 Reply Last reply
                          • tekkaT tekka
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @tekka Cool thanks, can I use Arduino as ISP to program bootloader?
                            • DrJeffD DrJeff
                              tekkaT
                              tekkaT
                              tekka
                              @DrJeff Yep :)
                              • tekkaT tekka
                                @DrJeff Yep :)
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @tekka , Time to try Thanks! :)
                                • n1ck1355N
                                  n1ck1355N
                                  n1ck1355
                                  @tekka yes ota fw updates works. Tried it with the Time fw
                                  • n1ck1355N
                                    n1ck1355N
                                    n1ck1355
                                    wrote on last edited by n1ck1355
                                    #48
                                    @tekka i musst revert my previous post...
                                    I've OTA uploaded the sketch from my first post:
                                    and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
                                    However the time reporter firmware works fine.
                                    • siklosiS
                                      siklosiS
                                      siklosi
                                      Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
                                      • rollercontainerR
                                        rollercontainerR
                                        rollercontainer
                                        wrote on last edited by rollercontainer
                                        #50
                                        I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
                                        Where is my fault?
                                          Where is my fault?
                                          tekkaT
                                          tekkaT
                                          tekka
                                          #51
                                          @rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
